I am building a new layout and am wondering if you have any recommendations for the minimum radius needed for 89’ intermodal flat cars or large car haulers.
Obviously. . . space is limited, but I still want to be able to run long cars on my reverse dogbone. I was thinking 42" of plywood would be enough.
I have 28 inches on the inside and cannot take the foot long cars on that due to a building which Im working on. I have the 31 inches radius on the outside that will accept any lenth rolling stock.
You don’t mention scale, hopefully it’s N scale if you want to use 42" wide plywood. An 18" N scale radius or so should work and gives a 36" diameter curve in N scale (measured to the center of the track). That will leave you some room at the edge of your 42" wide sheet.
In the interest of not want to start yet another thread on this subject…
HO scale
transition era
this is going to be a switching layout in a spare bedroom representing the transfer line in an urban setting between two yards.
The loco that will do local switching and transfer duty will not be larger than a USRA Light Pacific 4-6-2
I would like to run flat cars with trailers on them, as well as gondolas of scrap, etc.
So the millions dollar question is what is the minimum radius I can use in STAGING ? the curve will be right within reach. and in plain sight, but again, in staging. So am I worried about cars looking ugly on it? No. Am I worried about stuff derailing? yes.
Here is a rule-of-thumb for minimum radius of cars (locomotives are another matter). It is based on multiples of car length, coupler to coupler.
2.0 times car length: some (I’d say most passenger) equipment won’t work reliably
2.5 times: most equipment will run reliably if coupled to cars of similar length
3.0 times: all equipment should run reliably
3.5 times: appearance begins to become less toy-like if viewed from inside the curve
4.0 times: appearance begins to become less toy-like if viewed from inside the curve (views from track level will be more realistic than from above)
5.0 times: coupling should be reliable on the curves
If couplers are truck mounted, you can usually get away with a bit smaller radius curve.
This information comes from a free electronic magazine released this month and is consistent with information contained at the Layout Design SIG wiki site.
It would have been better if you started your own thread instead of hijacking this one.
As to an answer to your question, I’d say about 22" if 50-foot cars are the maximum length and your Pacific is not a locomotive with tight tolerances like most brass locomotives.
