Minor CSX derailment
CSX had what appears to be either a center sill failure. First though it may be truck pivot but ? Anyone know ?
http://delawarefreenews.org/2016/07/17/csx-train-derails-in-wilmington/
Somebody gonna get yelled at for bad train handling. [oops]
Private owner empty covered hopper that was moving as a ‘Home Shop’ for repairs in the middle of a 12000 foot 10600 ton train. No wheels were off the rail.
Can’t shop a shop!
Being scrpped in place.
But you can sure have one-stop shopping… just watch that first stop, it’s a Duesie… to paraphrase Daffy, they could only do it once.
I’m still trying to figure out how they got both the draft gear AND the truck to come out like that. Musta been LOTS of rust all around in there…
Not the first hopper I’ve seen do that.
When the good lord calls them to come home, it’s time!
Gee - the old rule about handling at the end of the train might have applied?
But on CSX, they might have handled it at the wrong end of the train. Didn’t they intentionally kill a couple of rusted MP54s with that stunt?
The car had been picked up at Bayview yard in Baltimore after having been rejected for loading of alumina ore for Alcoa at Massena, NY. Was the 28th car of 184 in train that was almost 15K tons. Car Dept. did not place any restrictions on the car concerning it’s placement in train.
Bet the car dept. rethinks, (with some attention getting from somewhere higher up), their decision on restrictions.
I understand over all what happened, but can someone explain to me in a little more detail? Like placement; what was it used for (looks like a grain hopper to me); and how it may have been pulled apart?
Car was a empty covered hopper that was built in 1979 and has been used most recently hauling alumina ore from Hawkins Point pier in Baltimore to the Alcoa Aluminum refienry in Massena, NY. When it was most recently spotted for loading at Hawkins Point, it was rejected account a underframe defect and was classified as a ‘Home Shop’ which caused it to be classified to return to Alcoa at Massena empty. The car was picked up by at train at Bayview Yard in Baltimore in the Selkirk classification block to move to Selkirk Yard (near Albany, NY) where it would be switched into a train for Massena; the car was 28 from the engines of a total of 184 cars in the train departing Bayview. One end of the car - truck, center plate, part of the center sill and end of the car itself separated from the balance of the car - the car was ‘pulled in two’. Off track equipment was summoned and about 10 hours after the happening, traffic was moving again on the single track line where the incident happened.
That would have caused some excitement here in the north woods if it decided to let go here on the St Lawrence sub…
Balt: That was very clear. Thank you. So - since it was to be home shopped and they knew that it had an underframe defect, this should have been place more toward the end of the train? So there wouldn’t be as much pull on the already defective car? And I won’t even ask anyone to speculate on why it pulled apart, until we get the “report”… [8)]
Why?
With four to five trains daily, we don’t have quite the potential for such mayhem as a busier route would…
Then again, there’s a lot of older cars out there, and running these monster 12,000ton+ slop freights…[#dots]
There was enough of an underframe defect for a private industry to see. What would that entail–a car off center? or, more likely, a crack in the underframe or drawbar area? This undrframe defect should not have been a surprise to anyone making up or inspecting a train in Baltimore. So someone apparently inspected the car in the yard and either missed this defect in spite of the notation, or okayed it to be carried with about 10,000 trailing tons. An inbound inspection should have revealed at least what caused the car to be rejected in the first place, and resulted in the car being bad-ordered. Instead, probably after having been switched around a bit in Baltimore, it was placed in an outbound block for pickup by a Selkirk-bound train (or, alternatively, placed into a Baltimore-to-Selkirk train). How did this defect miss an outbound inspection? How was it handled from the plant to Baltimore? Doesn’t anyone communicate?
Approximately 15 trains, including primere Intermodals had to be recrewed. The car department ‘thought’ they had applied repairs sufficient for the car to reach it’s owner’s territory - obviously they were mistaken.
