Model Power E7 and Cary Shell
I picked a couple of Model Power E7s recently, and I’m impressed with the big motor and their pulling power. A little cleaning, greasing and they run fine.
The shells look ok to my eye, except for the screw hole on top.
I found a Cary E7 shell, and I have the chance to buy another one. I thought maybe I could mount it to the Model Power frame and make a super puller, but I will need to file down the frame some in front. I like the pilot better on the Cary shell, but it’s only a single headlight so I would have to drill a headlight in the door, whereas the Model Power shell is already dual headlight.
I noticed the Cary shell is looks narrower than the Model Power. Does anyone know which one is more accurate? Any advice if I decide to do this conversion?
The Cary shells clean up nicely. A Dremel grinding tip will make quick order with the unneeded material.
I have two Cary bodies on Model Power frames and three on Athearn SD40-2 frames. Total weight of each E7 is two pounds+.
I replaced both the Model Power and Athearn BB motors with Mabuchi FK280SA-14200 motors.
Great locomotives.
Mel
My Model Railroad
Bakersfield, California
Turned 84 in July, aging is definitely not for wimps.
Thanks Mel. How did you make the Model Power Frame fit? Dremel, or just a file?
I think the Mabuchi FK280SA-14200 motor looks like this, right?
I have one, but the last time I tried to order more I was out of luck. I assume you needed to mod the driveline, too.
I’ll go buy another Cary shell, I guess.
It’s been so long I can’t remember exactly between the 10 shells I have 6 As and 4 Bs. I remember using a file and my wife remembers the Dremel.[#oops]
Mel
My Model Railroad
