Been thinking about this for a while, especially after looking at the specs of Union Pacific’s A-B-A E9 set (949, 951, 963B) and wondering how things could have been done differently (instead of two 12-567Cs per unit, each unit now has a single 16-645E derated to 2000 horses; all units have D78 traction motors and 55:22 gear ratio; top speed is listed at 98 mph).
As I recall, the original concept of the E-unit was as a 120-mph passenger diesel (to compete with Alco’s DL-109 with the 61:22 gear ratio), with gear ratios lowered in order to improve acceleration, at the cost of the top end. Hasn’t stopped me wondering what might be possible if modern components were made a part of the basic E-unit design (i.e. with aerodynamic body styling et cetera and possibly longer frame):[list][]Two 12-710G3C-T2 prime movers, to start with, for Tier II emissions compliance (yes, I know they don’t exist, but it’s still possible to build them…this might take a bit more room than on the old E-units? should a 79-foot frame be sufficient?)[]AC asynchronous traction motors on A1A-A1A trucks (could the Blomberg design be adapted for this, or should we go for body-mounted traction motors? of course, any other ideas for wheel trucks are welcome)…with IGBTs (why resist advances in this vein)[]Keep the 55:22 gear ratio[]No heavier than 69,000 lbs/axle (we’re going to have to do this with passenger locos, I suspect; look at how heavy our B-B diesels are, nowadays)[]800kW HEP included[]Isolated cab (like the F59PHI)[*]5,000-gallon fuel capacity[/list]Anyone want to add to the list, go ahead. I’m sure I’m setting myself up for more than a few chuckles, but at least let me know where and why. (How fast would something like this get up to, at Pueblo?)
Why not just one rated at 4300hp?
How bout C-C, would put even more of that 4300hp to the rails and you might be able to load faster.
Why not 61:22?
Agreed
800kW HEP included
As long as it works would be the main thing.
A 12 cylinder 710 is rated at 3,000 hp, considerably more powerful than the 567-12s in the E-units. That would make the engine you propose a 6,000hp loco, in the same hp range as the SD90MAC and AC6000, or even the older DDA40X double diesels, which had their engines mounted separately on the long hood. C-C trucks wold be a necessity. If you want the prime movers mounted side by side, it would probably need to be built as non-frame supporting cab body, or GE Genesis-style monocoque and not the frame-body cowls of full width EMDs built since the FP45s. Of course, the 710’s requirement for turbocharging might complicate engine placement too, which was probably another reason why the 1960s double diesels didn’t have E unit-style engine placement. If you want 6,000 hp, it might be a better idea to use a single EMD H engine, or just stick with a 4,300 hp 710. Think of it as a SD70ACe in a fantastic-looking passenger carbody. No passenger road has ordered a 6 axle engine since the 1970s. In Chicagoland, Metra tested BNSF SD75Ms in the mid 90s, but ended up ordering 4 axle engines anyway.
I find it highly unlikely. The market for passenger locomotives is incredibly thin and MPI has pretty well cornered the market for suburban service locomotives. Anyway, a new E-unit hasn’t been built since 1964.
There is no doubt in my mind that a more efficient, technologically updated E-8 could be designed and built. There are a couple of flaws in the design that are practical concerns, which is why they don’t build them anymore.
First is access to the cab. I’ve climbed up into the cab of an E-8 and it’s a chore. You are looking at a tall, narrow, ladder going straight up. If you are going up in there with a grip (I have watched this) it is not only physically tough, but it’s also dangerous.
So, my suggestion would be to stick a “porch” on the front, rather like the front end of a “Little Joe” electric, with a door in the nose- very much like a “safety cab” design. This would also give trainmen a safe platform to ride on when they are coupling up.
(Yes, I know the very same flaw exists in present day Genesis locomotives. We are talking about the E-8.)
Another flaw is the single end cab concept. To overcome that, one might design into the revised E-8 a cab on the other end. This will extend an already large locomotive- the thing goes on forever already- into something bigger. But you wouldn’t have to turn it to have it go the other way- just run it around the train. Or you could just buy another E-8 to stick on the far end facing the other way. Or rebuild a turntable, or a wye.
(Again, AMTRAK has been dealing with single end cabs forever, but the concept is to make the E-8 useable for present day use.)
There is the problem of visibility. The engineers I have talked with and a little personal experience with the bulldog nosed cab tells me that looking back over the train is not easy. This is overcome by rear view semi truck type mirrors mounted on both sides- which vibrate everything out of focus. The solution would be to design the carbody into something like the BL-9, which afforded the engineer limited, but direct, visibility back, without
Did you watch the series of DVD from Trains entitled “F Units in Action”. It has alot of information about the units history and designs. I recommend you to watch it.
As much as I like bulldog noses, I’m also aware that the compound curves involved in the nose are expensive to fabricate and are a production nightmare (lots of body putty is involved). So don’t expect more bulldog noses any time soon.
Ray Patten of GE really had a better design and production idea with the flatnose design used on Alco and GE locomotives.
Who said that they had to be passenger power? Consider the various UP gas-turbines, Erie 750 (4-unit testbed) and the E2b electrics on PRR for their take on the flatnose. Alco FA’s and DL500’s were rarely used in passenger service.
The cabs on END F59PHI’s and EMPI commuter locos seem nice. Sleeker looking than the cab on GE’s Genesis.
Now, how about modern day F units?
Santa Fe originally wanted their GP60M’s to have full width cowls which, with their cabless GP60Bs, would make them kind of like modern day F units. EMD objected because the cowl would add too much weight to the 4 axle loco with it’s safety cab and all.
Yeah, I love the bulldog nose. It really ought to be called the Bondo nose, though. I’ve seen photos of the things being fabricated on the assembly floor of EMD. It looked like the Bondo got slathered on with a shovel, then sanded into shape with a mechanical sander…
But I digress. I wouldn’t stick a shovel nose on an E-8 for a couple of reasons. First, it makes the locomotive look longer than it is, and let’s face it, it’s big enough already. Just a personal opinion, but the shovel noses reminded me of the ALCO DL-109’s- the bulldog nose says EMD all the way. And I am arbitrarily, unreasonably, foolishly perhaps, an EMD fan. I chalk it up to a badly misspent youth watching EMD bulldogs pull fast (relatively- the NHRR was not real fast back in 1968), named, passenger trains while ALCO products moved freight.
From a visibility point of view for the crew, the sight lines for the standard bulldog nose might have been a little tougher than the sloped nose of the shovel head. Then again, they might not have been. Any engineers out they have any idea?
I’ve watched and talked to maintenance guys work on F units as well as “hood” units. They have mixed opinions. They like the idea of being able to access a busted part through a side door, especially when they can spread their tools all over a catwalk. It’s not so easy to do maintenance on a cowl unit, according to them. To get to the engine components, or do electrical work, you are stuck in a really cramped space between the component needing work and the outer wall of the cowl. If you have to remove a component, it goes through the roof- a really large plate requiring a crane- or through the midget access doors on the side.
One guy told me that God intended tools to be kicked off the side of an engine, to fall onto the ground five feet below, rather than into the guts of the engine. I watched him do both… <
The Victorian Railways in Australia had EMD manufactured diesel electrics that looked like a double ended E unit with a cab at each end. These utilized a single sixteen cylinder 567B prime mover and twin six wheel trucks with traction motors on each axle. This made them C-C units. These locomotives were used in passenger service but also saw service in freight (sorry, goods) service as well. I saw them and rode them when I was in Victoria, Australia between 1969 and 1971. Some are still in service and you can find photos and information on the Victorian Railways webpage. One difference was that the gage there was wider, 5’-3" if I remember. These units did look rather neat and they solved the problem of turning at the end of a run.
Victorian Railways has several other cab units that might be of interest just to see how things have been done “down under”.
The problem of visibility to the rear on an new unit, (or an old unit for that matter) could be solved by means of a television camera incorporating anti-shake technology to assure a stable image in spite of vibration. I wonder why this isn’t done now to allow good visibility at the rear of a locomotive during switching or coupling moves? It is available on high-end automobiles to allow easier and safer backing and parking.
Union Pacific used their old E8 and E9 units for freight service after passenger service ended. The E9 A units were often coupled with an F9 B unit booster for a locomotive of 3,900 horsepower, a sizeable sum in that day. Union Pacific certainly got their money’s worth from these older locomotives. They were effective and long lives precisely because their conservatively rated twin switcher sized prime movers were not too big to service inside the hood style carbody and the reliability of the smaller prime movers was quite good.
Yes, I’ve always liked the looks of E and F hood units. I still think they are beautiful, bondo nose or no.
