Movable point frog
Sprung frogs (or should that be sprung wing rails?) are only used where a seldom used (and low speed) track joins a highly used (and usually high speed) track.
There is such a thing at Lyle, WA. On the river side of the main, there is a siding that used to go around the back of the station. On the east end of the siding, there is a switch with a sprung frog. It’s different than the drawing of one, above, in that there’s only a spring on one side, not both.
Traffic can only leave by that switch. It cannot enter. The siding is used for MOW equipment and/or car storage. The OTHER end cannot be a sprung frog, of course; because then you couldn’t enter the siding at all.
On examining a photo of the frog, I see that there’s a groove worn into the top of the closure/wing rail, parallel to the main, and about a rail width BEYOND the outer edge of the main track rail. This implies some pretty badly worn wheels, where the area of the wheel adjacent to the flange has been worn down below the level at the outer face of the wheel. About 1/4" on the wheel radius, or 1/2" on the diameter is my guess. And it ain’t just one wheel.
The switch is also remotely locked, as I saw a guy “phoning home” to get it unlocked (so he could leave, using that switch).
Ed
There are places where spring frogs are used at turnouts with higher speeds on both routes. I know of at least one 40 mph turnout that was a siding switch but now is the switch at the end of two main tracks.
Jeff
So, what’s it sound like when a train goes through that spring frog at 40 MPH? I’m thinking “impressive”.
Ed
Usually fitted with a hydraulic retarder to slow down the closure of the wing rail
The Union Pacific double mainline right smack thru the middle of Boone, Iowa has movable frogs on both mains. By coincidence I was thru there just yesterday (!) and took pictures of these exact objects because I was wondering what the heck they were…
EDIT:
Just found this photo from the location I’m referencing. This is facing east towards the yard and shops. The UP office is out of frame to the right. This grade crossing location is Story Street between 9th and 10th.
https://www.flickr.com/photos/jterry618/51171294761/in/photolist-2kXQg9M-Tze3z5-2gMrfuj-2gToSCL-2iYi2wU-2jZaMVM-2jZ65xk-2jZ6fSP-vrmhYN-2gx2RqH-2gBNviq-uM8WLt-2kXQgbL-2iZM5hC-dVC5ze-2gYzJwj-2gyUH3d-2dXDyja-2gFCPYM-2iSzuZF-pnzS19-2gG8yF5-2bLCvVy-2gLxBGT-Tze3Hm-2jZaB8Q-k5PKM2-2gEtzLC-mDiVN9-2gzD3dn-23eNXrU-2jZaBdK-23hqn4k-2krYbtE-2jZ9Mux-21Vg23p-2kXUjUC-2gF7bud-27m2AHY-2jZ65Lg-24BBG89-pbzqw8-vHVqg6-vrsxUX-q6dWU9-pQVEJU-q89E2n-pbzmrz-pbzseX-EYcLiF/
UP has more than all class 1’s combined (excluding Amtrak northeast corridor)
All the turnouts, except for the one going into the yard are 40 mph. The one for the yard, not a moveable point frog, is for practical purposes a 10 mph. The speed allowed on the yard lead.
Jeff
No, the Long Island Rail Road has been placing these on all of their new construction. Manufacture’s websit says that they are made from #6 to #32.7 wich is good for trains moving at 65 miles per hour. That photo on UP looks like it is longer than that. I suspect there is no top end that you could build for a high speed railroad.
