Installed Tsunami sound decoder (hard wired) in a Intermountain F7. I added front led for headlight and used the green wire for the numberrboards as I want them independent from the head lights as it is dimmable.
Problem. When dimming head light the numberboard go out (green wire turns off). I could use the purple wire but would rather add truck lights to it later.
Question…can I remap so that the number board function can be fully independent from any other function
Was my first install and went rather well. On another project I had seperate number board, dimmable headlight, truck light and mars, Like the apearand of just haveing the numberboards lit when in the engine terminal.
It appears that if you want to have the number boards on F6, program CV 40 to 4. FYI, my Intermountain ES44AC with DCC/Sound came from the factory with the number boards on F5 and the ditch lights on F6, which are all independent of the headlights on F0.
If it doesn’t work, let us know and we’ll work through it. At the very least, a phone call to Tech Support at Soundtraxx will get 'er done!
Thank you Penncentral99, Yes it was a Tsu 1000. I think I have got it and thanks alot for the help. I did this for a friend and Im takeing it back to him this morning. Wa my first install with sound and learened a lot…so I guess an old gezzer can learn a few new tricks LOL
Again Thank You all for your kind replys and have a great day.
