I just received a Lionel 442 Milwaukee Road 8305 steamer from the 1973 Milwaukee Road passenger train set.
Since I don’t use smoke, I was going to turn the smoke unit off before I give it a test run, but there is no apparent off switch for the smoke unit.
Were the smoke units in these locomotives robust enough to survive without smoke fluid, or should I dissassemble the loco and disconnect the smoke unit internally if I want to run this loco for extended periods?
---------------------- Bill
