My control stopped functioning suddenly. When I turn it on and increase the throttle the first two red indicators light without the train moving then all the re indicators start to blink at once.
I have connected another controller and the trains are working fine.
What could be the problem with the Tech 4?
Any suggestions?
Welcome to the forums.
Do you still have your sheet of instructions? Even though I do I still am not sure of all the stuff I do, but it still seems to work OK.
It sounds to me like you are in Program mode. If that doesn’t fix the problem, I’d check the MRC site or call them. The question I had got a prompt, understandable answer.
Sorry I missed this earlier, mush have just missed it Thurs and last night son was on the computer when I normally check…
Good luck,
Here is MRC’s on-line link to the manual:
http://www.modelrec.com/resources/trainSound/AB140.pdf
Jim
I hope you have found your problem by now, but have a new experience to add. Last night mine had lights flashing in strange fassion. Investigations found that there were still paint cans holding down a newly layed and wired track causing a short. Cans off, flashing over, train moved. Whew! I thought maybe programmed obsolence had hit both of us.
Have fun,
