Discovered I had a very short message from a fellow on my phone today asking about my Diamond Scale turntable. It’ll try to remember to call tomorrow, but it’s kind of late to be calling people now from here. In the mean time, perhaps these pics will help. This is pretty much the documentation on the TT, a 75’ long one I use at Durango. The real Durango TT was only 65’ but that sounded pretty tight to be hostling big Ks on and off, so I went with 10’ longer.
A lot of space is needed for an engine terminal and I got mine in a fairly standard way, inside a loop of track.
A little landscaping goes a long way. Sculptamold is the secret tosmoothing everything together as seamlessly as possible.
Low angle view of C class turning
Here’s the DS bridge upside down
I made the handrails out of brassstock. It’s not exact, but closely resembles the Durango TT bridge.
Nah, I’m just mumbling along today. Got my instructions somewhere. The fellow was asking about what I’d documented on my build basically. All I really have are some pics in the backup harddrive from before I joined imageshack.
If anyone else has pics of a Dimaond Scale TT build, please post them up. The DS seems a little mystical, because you do have to build it yourself - accurately - and it’s been on and off availabiity in the market. Basically, it’s like a lot of old kits - you’re scratchbuilding with instructions.
I have a 134 foot diamond scale turntable I purchased a number of years ago from an estate sale being sold off at the Timonium train show. It was all in a big box and upon cursory inspection everything looked in good order. I left it in that original box for a number of years until it be brought out for installation on my new layout.
Yesterday I unpacked it to get ready to mount it into its place on my new layout. I’ve discovered that the composite board onto which the pit is attached appears to have some warpage, and a few small cracks in the in the pitwall sides. I looked up the description of this piece and found this, “Factory-cast pit; pit walls with ring rail ties are Hydrocal, directly cast onto a composition wood base”.
It appears as though this composite wood base got damp somewhere along the line, resulting in this warpage.
Where might I find suggestions as to how I might best remedy this situation?,…reinforce that composition board such that the pit is ‘fair’ and level, or somehow replace that composite base with 3/4 top grade plywood?? I’m not sure how I could ‘detach’ that hydrocal pit from the original composite board??
I can take some photos. Has anyone else run into such a problem??
However, with the base and pit walls compromised (warped and cracked) I would not use it but build a new one using the old one as a pattern.
The ring-rail has to run true as the bridge is actually supported on the rail. Any deviation in this rail will cause endless grief with rail alignment and electrical continuity.
I recall an article where a pit wall could be formed by making a screed which fits into the pivot hole and as you work it around the circumference of the pit it would form the wall and the ledge for the rail to sit on.
Once the MDF absorbs too much water there’s no going back.
I remember that article too. I was thinking of doing that to make the pit floor of my Bowser turntables look more like the real thing. I also hope to shorten the bridges by about 1/4" and put some texture on the brass pit walls.
Hate to be the bearer of bad news, but I doubt you’ll be able to salvage the existing composite board base at this point. Not sure what your plans are for powering it, but you need a nice flat mount on the underside so that the shaft is precisely vertical. They use composite board because it has less tendency to warp than similar plywood. I’m a big fan of 3/4" plywood, but for this application the composite board is better stuff.
Not sure if your larger TT is the same basic design, but on my 75’ there is a smaller board that is mitered on legs that attach to the bottom of the main board. This provides the mount for the lower shaft. I assume the shaft is in the kit parts you have, but a test fitting will tell you a lot. If it slides in easily and, most importantly, vertically true, then you might be able to salvage it. Odds are that won’t happen based on your description. But if it fails this test, you can rest assured you need to go with Plan B.
Now for the cast pit. You say it has small cracks in it. It might be possible to reassemble on a new base, but I’m not sure how to get the paster casting loose from the warped base. I think it’s simply cast in place on the board/base, because I see no signs from underneath that there are any nails or screws driven up from below that might have the plaster cast round them to give a mechanical bond.
If you’re satisfied the current board is too far gone, you might soak everything in water to see if it releases the bond between the wood and plaster. Not sure what results you will have, but if it’s otherwise gonna be trashed, why not? Nothing to lose then.
If you cast a new pit, it has to be really accurate in terms of it being centered on whatever you put together for a base to hold the shaft and drive. There is probably less than 1/16" clearance all around between the pit wall and the bridge end.
We have a rainy afternoon here in Fla, so photos will have to wait until tomorrow.
I did write an email to Diamond Scale,…but I believe I read somewhere on this forom that they don’t read emails,…rather you need to phone them. I think I will do a little more exploratory work before I place a call.
Been thinking about this project on-and-off for several weeks while I went about other projects. I’m building a new pit for it, and finally yesterday my friend brought his router over with the proper size bit I wanted to use. I’m making my new pit out of cellular PVC rather than any type of casting plaster, etc. I’ll add some photos and description soon.
First time I seen this thread, you could have used a thick ply undeneath and screwed the composite wood to it, you had nothing to lose. You could save the pit wall by cutting it free with a multi tool if that didn’t work. Might be interesting to try even if your already building the new pit. I had a diamond but sold it off once I go a deal on a RTR walthers for $50. One gear had a flaw in it but was able to score two bridges for $20 on e-bay and one was the right size.
I tried something like you suggested,…bolting it back onto the strong, straight plywood I extracted it from. That helped a little bit, but I was satisfied it would be enough. Here are a few photos of the damaged one, and my attempt to ‘draw it’ back flat with those HD bolts.
Worked to a fair degree, but I was still not happy with it, nor just getting another plaster one.
I think you going to like my solution for building a new turntable pit,…NO plaster
New Turntable Pit
I spend a fair amount of time thinking about how I might construct a new pit for my turntable. The two primary pieces would be the pit floor itself, …then the pit wall. One thing for sure I was NOT going to utilize plaster. So here is what I came up with.
Pit Floor:
Good grade ½” to 3/4” thick plywood was a top choice in my mind, painted to limit any moisture absorption.
I happen to have a nice square piece of 1/2” thick piece of black Sintra board (cellular PVC) I had collected up from the scraps being discarded by a local sign shop. Why not experiment with this first, then I can always return to the plywood alternative. I decided my pit wall was going to be 1/4” thick material, cut out of several different options, and bent into a circle to fit that round trench I would cut into the floor.
I got out the router, installed a ¼” dia bit, and cut my ‘trench’ into the flat floor board.
Here I will note that I had 2 options,…cut that ‘trench’ (partial depth into the floor pit),…or just just cut all the thru the pit floor piece forming an inner disc, and an outward retaining hole in that square floor piece of PVC. Either way, both methods would support my ¼” thick vertical pit wall.
Pit Wall:
I had another scrap piece of the black PVC that was 1/4” thick 9” wide, and about 5’ long. I needed a strip of it about 1+3/8” wide, the full length to bend around to form my 'p
Not all your pics showed but I get the jest. Looks like the original was warped more than I thought. Still after all done and said I would multi tool the plaster off the wood just to see if it would work, might help someone else.
Nice save with that neat idea on making a good pit wall.
I’d say you have to be very, very lucky to have fudged the original mess into shape to make it operational. A turntable needs things to be right on, not sloppy on. Once MDF or similar chip board gets wet, game over, as it swells and warps, not consistently but in several directions at once.
I purchased a 135’ turntable a while back and somehow misplaced the instructions somewhere. If you could send me a copy (pdf) of yours, that would be great.
