I’ve had Athearn Genesis DCC-ready Mikado on my shelf for the longest time waiting for a decoder installation. I finally decided to go ahead with it. It requires a 9-pin JST decoder and one of my RS-1s had died had a 9 pin DH123 in it so I inserted that. Nothing to it but this was just temporary because I wanted sound. This loco only gets electrical pick up from the drivers, not from the tender. I noticed it would hesitate when passing over the insulated frogs of my Atlas turnouts. For that reason I decided to get a sound decoder with a Keep Alive and the WOW101-Steam-KA was just what I needed. Given my poor soldering skills, it was nice to be able to just plug it in. I did need to solder the twin sugar cube speakers and I didn’t do the neatest job of that but managed to get a good connection. Since the tender is just an empty shell, that gave me plenty of room for the decoder, the Keep Alive, and the speakers. The sound is excellent. I did notice at first the sound would cut out when passing over the frogs but that went away after a short time. I’m guessing the Keep Alive needed to get charged up. After that it ran fine with no hesitations or sound interuptions.
I do have one gripe. This decoder has function keys for applying the brakes and releasing them. It automatically releases the brakes when you throttle up but does not apply the brakes when you throttle down. You have to hit function key 7 to bring the loco to a stop. Each press of the key applies 20% braking. If you just throttle down, the loco seems to coast indefinitely with no slow down. It won’t stop unless you apply the brakes. While this is a more realistic way of stopping a loco, it seems like they are being too clever. All my other locos brake automatically when the throttle is turned down. I played around with it and it was very difficult to get the loco to come to a stop where I wanted. This was especially a problem when I tried to make stops at my coaling and sand towers. I had planned to use this loco on my peddler
It sounds to me like the decoder is set at maximum momentum.
I can change that on the fly with my NCE Power Cab. Try programming CVs 3 & 4 (acceleration/deceleration) to a value of “1” and see if that helps. If they are set way higher than “1” then that was your problem.
I generally set my momemtum no higher than “3”. And I only use the throttle buttons or encoder wheel for speeding up and slowing down.
I ran into the momentum issue with the Loksound 5 decoder that I installed in my C-liners. They took a while to stop but eventually they did after about 2 or 3 feet depending on the speed. With this decoder, if I don’t hit the brakes, it doesn’t look like it will stop at all or at least not for a very long time. I know it went at least 20 feet after I turned the throttle all the way down and I had to grab it by hand because it was about to enter my hidden staging yard and I couldn’t remember which was the brake key. The instructions seemed to indicated that this is a feature that cannot be shut off simply by adjusting CV4. I’m going to reread them to see if I missed anything, but based on what I have read so far, this decoder requires manual braking. If I want to stop the loco immediately, I have to press F7 five times real fast.
I have never experienced what you describe with either of my TCS WOW decoders - steam or diesel; nor has it required me to use F7 to stop. I’m curious if you tried a decoder reset whether you would still see this issue.
Probably so. The instructions are quite explicit that the F7 key MUST be used to stop the loco. It sounds to me like this is a new design feature. Here is what it says, word-for-word:
“In the TCS WOWSound decoders we have reinvented the way we think about model locomotive operation to reflect that of the prototype. Currently, most model trains operate without a brake seperate from the throttle speed. We call this kind of operation “Traditional” because your locomotive operates like a slot car (directly controlled by the throttle). With our new default “Prototype” operation users are expected to apply and release the brakes seperately from adjusting the throttle just like the real thing, though the brakes will automatically release when the throttle is increased.”
This makes it seem to me like this is a design feature hardwired into the decoder and not one that can be turned off by adjusting the CVs.
Edit: I’ve gone through the menu in the printed instructions and under the Throttle Menu there is an item for selecting the loco’s operational mode. Maybe that will allow me to switch to what they call “Traditional” which is what I would prefer.
If prototype operations is the “default” then I’m guessing there’s another option(s) - at least that’s what I read into that. And I would think that the WOW! manual would list those options somewhere, as well. I don’t have it in front of me to look so I can’t check.
Check CV 61. It controls headlight dimming when stopped and button control of motor. Download the comprehensive programming guide from the TCS website.
All I got with this decoder is a 4 page instruction sheet. It tells me there are options but doesn’t tell me what the options are. It says the decoder comes with an Audio Assist menu that I am guessing will tell me what my throttle options are. I’ll have to check it out to find out if I can switch to “Traditional” operation as opposed to “Prototype”.
By default Throttle mode is enabled, meaning that CV 4 is set to 96 (and CV 3 to 32). If you want that your locomotive responds more quickly on your throttle, CV 4 should be set considerably lower, e.g. 15. If you really want it to react like slot car, then set it at 1.
Personally, I like 5 step brake very much, because you can stop your locomotive exactly where you want, and have the impression, you are driving a real thing. You can drive locomotive fast, then press brake for a moment or two, then release it to let it coast a bit, and then press again until it stops.
But this is a matter of personal preference - therefore, you have both options.
Interesting stuff but I didn’t see where it allows me to switch to traditional mode so I don’t have to apply the brake manually. It mostly dealt with how the chuffing can be modified. I did notice that the chuffing volume goes down once the loco gets up to speed and the manual did confirm that is by design. I also observed this regarding stopping without applying the brake:
"The locomotive will also take a very long time to come to a stop without the use of the “Brake” defaults to button 7 and “Brake Release” defaults to button 6. When you close the throttle the loco will coast while you hear Rod Clank and/or the Snifter Valves. "
“a very long time is an understatement”. While that might be realistic, it’s also a nuisance. I go back to what I said earlier that they are being too clever. I’ve never gotten involved with the advanced features available in DCC and for my tastes, it is an unnecessary complication. I spent my working life as a mainframe programmer and the last thing I wanted to do in my retirement hobby is have to read through manuals and learn a new programming language which essentially is what CV programming is all about. I’m happy with very basic functions. I want my steam engines to chuff and my diesels to hum. I want a bell and a whistle on my steamers and a horn on my diesels. I’d be perfectly happy with generic sounds for all my locos. I don’t know the difference from one diesel horn to the next or if the sound is authentic. I’ve been in DCC for over 15 years and I can’t recall ever modifying a CV. I’d have to go read my Lenz manual t
I don’t believe there is a “traditional mode” per se. As mentioned earlier, the stopping momentum in CV4 is just set very VERY high. It’s just like momentum on any other decoder; the higher the amount, the longer the engine will take to stop. If you set CV4 to zero, the engine will stop as soon as you power down to zero.
I find putting the momentum on CV4 to around 20-30 allows me to press the brake once and the engine stops about as quickly as just turning the throttle down to zero. You may need to try different settings to see what works for you.
I used the Audio Assistant feature that talked me through it. It does allow you to switch between Traditional and Prototype modes. Even when I switched to Traditional, it appears it still has a fairly high CV4 setting because it took several feet to come to a complete stop without using the brake. When I went back to Prototype mode and I turn the throttle from top speed down to zero it will coast over 20 feet easily. I think I’m going to set it to Traditional mode and then reduce the CV4 setting so it operates more like the rest of my loco fleet.
I would much rather be able to use the throttle to make gradual start ups and braking. It’s not a hard skill to learn to do. Even I figured out how to do it. I do like the braking sound it makes when the brake is applied by pressing F7. I haven’t figured out if that’s still present in Traditional mode.
The value entered into CV 3 is multiplied by a factor of 8. So my “3” would fit into your momentum window, Stix. And, IIRC, CV 4 is multiplied by 1/2 that or a factor of 4.
I have just fitted a WOW Steam decoder into a Proto 2000 Heritage 0-6-0. I was initially a bit dubious about the “Prototype” mode and F7 braking, but having played for a while I rather like it now, and I am no longer thinking about changing to “Traditional” mode.
In fact, I am rather thinking about fitting the same decoder into a couple more DCC-ready locos I have so that they all operate the same way.
I haven’t completely given up on Prototype mode. Now that I know how to do it, it’s easy to switch back and forth. I’m still going to play with it to see if I can get the hang of it and stop it where I want it to stop. I do like the way the brakes squeal as it stops but since this loco is going to do a lot of switching, I don’t want it slamming into the cars it is coupling to.
Glad to see that programmers from the NAJPTC project have finally found employment in the software field again, although it seems they have learned comparatively little.
A non-moron programmer considering ‘prototype’ operation will comprehend the presence and effect of machine friction or train resistance in operation, and at least design a default ‘bleed-off’ of applied power to simulate this – it doesn’t seem to me to take much to get a ‘prototypical’ default. Just because slot cars have ridiculous voltage slew means you throw the whole premise out, let alone replace it with something harebrained like ‘infinite frictionless momentum’… or even some non-Davis train-resistance approximation taken only from steel-wheel-on-steel-rail “friction” vs. very large assumed inherent momentum.
Now, if I were doing this sort of thing, I’d tie the F7 response ‘programming’ to what actual one-pipe Westinghouse brakes do – early pushes give you different degrees of service, four pushes give you emergency, five gives you immediate stop, etc. Put the application after first F7 on the encoder wheel if you like to simulate gradual application, or put appropriate support in if you want some modeling of graduated release (aga
Well, if there was a vote, count me in the “slot car” category. Operations with long braking are very tedious, especially when the layout is on the smallish size, with many cars and switches bunched up in tight spaces. We are very far from the prototype, brake button or not… In all events, it should be easy to program the CVs on one or the other.
That’s a good point and one I hadn’t thought of. It applies even to large layouts. It requires a lot of distance to bring a real train to a stop and we just don’t have that kind of space even on big layouts. Stopping distance doesn’t scale down well. My longest mainline run between towns is about 15 feet. By the time I’d get a train up to speed it would be time to start braking again. Another problem extending braking presents is hidden staging yards. It would be quite easy to overshoot if you can’t stop in a very short distance.
