My Solution to Creating Realistic-Looking Brick Walls from a Plastic Kit
Hi Folks,
I thought I’d share an approach I’ve just perfected for creating great looking brick walls.
As many have suggested in the past, I first sprayed my plastic brick walls with a brick-colored spray paint (I used a flat primer made by Krylon but obviously, any brand of spray primer in a color you like will do). Just make sure it has a flat finish rather than glossy.
After the paint had dried for a a few days, I brushed all the brick with the following: I mixed joint compound (the kind used for finishing sheetrock walls}, with water. You can experiment with the ratio but I used about 1 part sheetrock compound to about 6 parts water. In other words, I filled an empty peanut butter jar with about 1 inch of compound and then filled the rest of the jar with water. My new approach is to add enough Woodland Scenics "Earth Color Liquid Pigment…the Slate Gray color, item number C1219, to make the solution look more like concrete. I would expect that some of you might prefer to use Woodland Scenic’s Concrete color, item C1217, but you might want to experiment. I tried the Concrete and it was too light-colored. I also discovered that if you add about a half teaspoon of liquid dish detergent to the solution (I used Palmolive), it helps break the surface tension of the liquid, enabling it to spread more freely on the brick walls. Another note here: Don’t shake the jar to mix all this solution…it ends up with too much foam at the top. Just gently stir the solution each time with whatever brush you’re going to use to apply it. It took me a while to realize I shouldn’t shake the jar…Duh. I’m real happy with the end result because the mortar lines look more realistic than when you use just the white joint compound without the added gray color.
After the mortar dries, I use Q-tips dipped in plain water to wipe off any excess on the surface of the bricks. You can “play” with the walls, adding more solution, letting it dry, and then wiping some off until you get
Sounds like a method worth trying.
I’ve acquired a Walther’s HO Car Shop kit that I’m going to use as a Locomotive service shop. Of course, it’s a nice looking brick building that would fit in any layout from the 1930s thru today.
Looking forward to weathering after putting it together.
Thanks!
Mondo,
This does, indeed, look like an interesting method to try. I, also have the Walthers Roundhouse and Powerhouse kit that needs to be built and I have kind of been waiting for a detailed method to “appear” in order to paint the brick surfaces and this looks like a dandy one to try. I am assuming the best way to do this is to paint all the brick surfaces before assembly. If I am wrong about this, PLEASE someone stop me before it’s too late.
Again, thanks to Mondo.
Richard
Thanks for the idea and the detailed write-up. Even I could understand the method, and that’s saying something. Just happen to have some joint compound and some unbuilt brick wall pieces laying around, so I may have to try this.
Ed
Hi Richard,
You are correct…definitely paint the walls before assembly, either while they are on the sprues or after you remove them from the sprues. The main reason is because if your building has windows, it’s much easier to install the windows before assembling the walls.
Good luck and most of all, enjoy yourself. While the finished product will be fun…enjoy the journey.
Mondo
