I know there’s going to be a flurry of suggestions about where to put what new track and where to rerun a track. There’s not room.
I like the one you posted on the other side better.
What other one? It’s the same one.[(-D]
Gotcha, or did you Gitchme?
Jeff:
Looks good to me. I gather that your radius at the loop by your maintenance facility is about 18 inches, which is pretty tight, but I think I’ve noted on some of your other threads that your locos can handle, or you’ve modified to handle tight curves, so if so I realize this might not be an issue.
Jim
The only loco I’ve had issues with on the 18" radius curves is an Athearn AC4400. It would jerk the lead car off the track. I fixed that by modifing the couplers so that they can swing about 50 +/- degrees either way. This means I have to center the coupler manually but that’s no biggie. All my P’s (except the Athearn models, which have truck mounted couplers) and E’s have swinging coupler pockets.My SW,SD’s, F’s and GP’s have no problem with it whatsoever.
Jeffrey, I think your’s looks very neat. It looks good.
