I’m in the process of adding smoke generators and blinking LEDs to some of my factory chimneys. I believe that in the real world, these smokestacks have some kind of lightning protection on them. What would be the best way to model this in N scale? I was thinking about using either dressn shirt pins of thumb tacks minus the flat part.
For me, personally, I would be uncomfortable with sharp metal objects sticking straight up in the air. I’m sure I would poke myself at least a half-dozen times [:'(] Anyway, I would probably use a small piece of styrene painted a dark gray.
Scott
Any that I have been close to were less than a 1/2" in diameter. Even the copper mesh cable going down to the ground was only about 3/4" in diameter. Divide this by 160 to get N scale and you would probably have difficulty seeing it even when you know it is there.
Good luck,
Richard
You might try a very fine wire (one strand out of a piece of #30 stranded) cemented into a hole in the top of each chimney.
Yes, the lightning rods are there (thank you, Ben Franklin) but they are very difficult to see.
I agree having a sharp metal pin could be dangerous. If someone were to reach over it they could get a nasty scratch. Maybe a bristle from a brush. It would be flexible so it would be a lot safer.
Steve S
“Careful, you’ll put your eye out!”
[:O]
I can hear your mom saying that right now.
Better to go with a bristle or hair…or even why bother in N?
