Hello all
Im going to buy a power pack for n scale but it does NOT come with that pieces that connects it to the track. What is the piece i need to buy to connect the power pack to the N Scale trakc
many thanks
pavariangoo[^]
Hello all
many thanks
pavariangoo[^]
You can buy wired terminal joiners for a few dollars. They’re basically regular terminal joiners with wires soldered to them. If you are good with a soldering iron you can do it yourself.
Go to Atlas’ website and search for “terminal joiners”.
Thanks!
Pavariangoo!
Def, go with the powered rail joiners, there like 2.69 but without them der aint gonna be no trains runnin, word of advise ; unless ur a good solder, or however u spell it, dont go with soldering n scale track, you have to be perfect with your flux , and with n scale it picks up any little bump or jump. stick with the standard rail joiners, and if i dont have one, yet, get an track gauge, !
and most of all , good luck!!!
Would a N Scale Power connecting clip work?
Thanks
Pavariangoo
