I’m a newbee looking to get into the hobby. I’m interested in building a layout simular to the Durango & Silverton narrow gauge line. From what I’ve read, to model this in HO scale, you would need to use N scale track. Is this right? How would HO scale locomotives & cars run on an N scale track?
What you need to model the D&S (and the Rio Grande that came before) on the Silverton Branch is HOn3 track (10.5 mm gauge), which is 3’ gauge in 1:1. Micro Engineering makes it in several flavors, weathered and unweathered, and Peco offers it, too. There were some others whio produced it in the past you may find, like Shinohara and PSC.
Using N gauge track for HO is HOn30, which is 9 mm gauge. That’s usually used more for industrial lines and to represent 2’ gauge prototypes (although it’s too wide for that actually, it allows use of N scale mechanisms.)
I model the Silverton Branch in a more modern and busy state.
What is HOn30? Simply put, “HOn30″ refers to HO scale models that operate on N scale track. HOn30 has been adopted by model railroaders who use commercially available N scale track products. This gauge is commonly used to represent two-foot gauge railways.
Standard gauge in the US, Europe and other places is 4’ 8-1/2", or 56-1/2". In some places, like in mountainous areas, it was cheaper/easier to build to a narrower gauge of track. The smaller trains could handle the sharp curves and such easier than full-size standard gauge equipment could. In the US, the most common narrow gauge was 3’ or 36" gauge, although there were lines built to 2’ gauge and 30" gauge also.
Scale is the size of our models - the trains, buildings, people, automobiles, etc. HO scale is a ratio of 1:87.1, or 3.5mm = 1 foot. That scale is the same whether you’re modelling a standard gauge railroad, or narrow gauge.
As it happens, N standard gauge track is about half the width of HO standard gauge, so some folks use that to represent narrow gauge trains - either 30" gauge (HOn30), or as a stand-in for 2’ gauge. Similarly, HO standard gauge track is about 30" wide in O (1:48) scale, so some O scalers use HO track when building On30 layouts.
HOn3 track, yes. But the locomotives and rolling stock must be HOn3 as well. As pointed out earlier, they are HO SCALE - that means 1/87th of the actual size, but HOn3 (narrow) GAUGE - gauge is the distance between the rails.
Your structures, cars and trucks (road vehicles), people, animals, everything else - would be HO scale.
And don’t be further confused by the mention of other narrow gauges. Yes, there are others (in HO scale), but HOn3 is by far the most popular and readily available, at least in the US.
If the OP wants to run standard gauge equipment, there’s nothing wrong with using a little modeler’s license and making it dual gauge. Assuming they’re comfortable with that.
The D&RGW had quite a bit of dual gauge in various places, often before the inside rail was removed and it was standard-gauged. Alamosa, CO was a good example.
I’ve never modeled narrow or dual gauge, but I’d think someone makes dual gauge track. If not, my strategy would be to lay the narrow gauge first using standard ties and lay the outer rail next. The biggest issue would probably be switches, but I’ve seen plenty of kitbashing with those, so building a dual-gauge turnout wouldn’t be impossible.
About HOn30, yes, it is used to model two-foot-gauge lines, but there were also prototypes using 30" gauge. Most of these were either small industrial railroads or in the theme park category, according to the info I came across. Outside of the US, this gauge was used for some government-run systems, especially on islands, as well as the typical mining or farming purposes. Interestingly, North Korea has quite a few, but good luck finding any information on these. [sigh]
Yes, more or less. Everything is in HO scale, but you have either standard or narrow gauge trucks underneath. This will match your track, being either standard or narrow gauge. With dual gauge, you can run either, just not both in the same space.
Of course, there was some NG equipment that had two sets of trucks, one SG the other NG. Some Rio Grande MOW office cars were this way, as were several rotary snow blowers and at least one wrecking crane (OZ). The RR would swap onto whatever trcuks were needed at the time.
Much older SG equipment is sized so that it could work running on NG. I discuss some options on that here:
Actually, 2 foot gauge was the narrow gauge used in Maine from the mid 1800s until the 1930s when the Depression killed them all off. The idea to use 2 foot gauge came when a group of Maine investors visited Wales and saw their 2 footers hauling slate, coal as well as passengers.
George is more correct here. I was trying to pack too many ideas together, but here’s the issues I was tryong to address there.
HOn30 when used for 30" gauge prototypes is accurate, there were just few examples and mostly industrial in the US.
HOn30 is also often used to represent 2’ gauge prototypes that were generally common carriers, but isn’t accurate for that being 6" too wide. How this affects the looks of a 2’ model varies. A boxcar will cover its trucks so that the difference is hard to see, while a steam loco has a lot of exposed undercarriage, so the extra width is harder to hide.
Another factor in how HOn30 ended up being used for 2’ gauge prototypes is that actual to scale 2’ gauge track leaves very little room for motors and other parts to fit. It can be done, but is a challenge. HOn30 provides enoiugh extra slack to do that more easily, as well as providing a source of RTR track.
You could use N scale track, but it would not look right. The ties would be too small and too close together. Peco makes track with “N scale” gauge but HO scale ties in their track range of products. N scale track will work fine for hidden trackage.
Many people use N scale diesel locomotive mechanisms to build HOn30 models. They build larger cabs and walkways onto the N scale models to accomodate HO scale people. How far you go with detailing this is up to you.
For freight cars, I have seen people buy HOn3 resin kits and narrow them just a little to look better in HOn30 track.
Again, the amount of detail and work you put into this is up to you.
Oh, and there is the Gilpin railroad in Colorado that had those cool tiny Shays. Upper North, on Anticosti Island near Quebec, there was even a small running “Decauville” that was brought in by the French owner of the Island. So many great excuses to have an HOn30 on a “could have happened” layout.
Here is my version of the Hon30 shay, a 3D print that runs on diesel frame. The gears don’t turn, but my eyes don’t see the difference at that size!
HOn3 is more of a serious modeler’s niche. Blackstone brought in quite a bit of ready to run equipment HOWEVER they are currently out of production and skyrocketing in price. Other than that you will be confined to brass locomotives and more often than not more craftsman type kits such as Labelle wood kits and Railline plastic kits (Which still require adding grab irons etc.) Track can be a bit of an issue- Peco and micro engineering make flex track and turnouts. Dual gauge was mentioned BUT since Shinohara closed dual gauge turnouts are not made right now. It is not really a beginners situation.
HOn30 or HO scale running on N gauge mechanisms and track was “popularized” by Frary and Haden as a way to model the Maine 2 foot gauge railroads although with a wider track gauge to utilize N scale chassis. Minitrains made a couple of sets that were a ready to run HOn30 (The one below) but they did not run real well and were small industrial equipment. Aside from this again it is a builders scale.
This pic shows a standard gauge 2-8-0 in the back, an HOn3 Colorado and Southern 2-6-0 in the center and a Minitrains HOn30 engine and cars in the front All three of these are the same scale but narrow gauge equipment is smaller.
There is an idea if you are thinking seriously about doing Colorado narrow gauge and wanting more ready to run. There is another option but you will go up in scale. Bachmann makes a line of On30 equipment. (again this is different that On3) On30 is using HO track but is O scale (1/48) While it may seem to possibly suffer from the idea of using a slightly narrower gauged track Bachmann took a different approach. (for a better appearance Peco makes a track with the ties correctly sized and spaced but you can use regular HO track) Their 2-6-0 is modeled after Colorado and Southern #22 and very nice (as long as they are not painting it in those horrible special run thin
Good one Mel! I just had to look up if someone made an HO/HOn30 track, and apparently Tillig made some. Not like the one shown above - more like the 3 rail approach - but an interesting option for some, like HOn30 Critter Dave…
