I put all connections into the pcp panel plug it in and no red light on panel but the contoller is on. Cant do a thing. Advice
Which socket is the PowerCab plugged into? It makes a difference.
You should change the title of this thread. It is NCE, not NEC.
I am a PowerCab user myself. You need to plug the cab into the left port on the panel with the flat cable, not the coiled one. Only the flat one can provide track power. The remote should fire up into ProCab mode, then change over to PowerCab mode and activate track power.
