i need a gear tower cap for a proto pa-1 truck. i am guessing that the 1000 and 2000 trucks are the same, and the caps for the 2-axle and 3-axle trucks are the same.
thanks
thanks
The gear tower caps should be the same has a bluebox which you can buy from athearn or take from a parts unit.
I have a couple I can spare. Send me an email with your address and I’ll get them to you.
I’m not aware of a 2 axle PA? Exactly what model do you have?
LifeLike_PA-parts2 by Edmund, on Flickr
No, they’re different.
I needed a worm gear cap for a Genesis F unit and had to buy the whole truck at $25 from Athearn as they would not sell the gear cap separately. Maybe the “blue-box” style are available separately? Still, they won’t fit a Proto 2000 PA.
Regards, Ed
Proto 1000 is the same has a blue box but I have never worked on a Proto 2000.
God bless you Ed for your warm generosity and caring for fellow model railroaders. You are always there to lend a hand with your endless supply of parts, some of which you and just as helpful Mike have sent my way when I was in a fix. -Rob
Thank you, Rob. I’m glad to help where I can. Now, if the OP ever comes back we can hook up and get him going again.
Cheers, Ed
