Need a Pullman Green paint
Can anyone suggest a rattle can paint for painting heavyweight cars in Pullman Green. I tried Scalecoat’s Pullman Green and while I suspect it closely matches the true Pullman Green in outdoor light, it appears as a flat black in my layout lighting. I can’t even see a hint of green in it. Ditto for their Brunswick Green. I tried their Southern Green and that is too green as is a number of shades of Tamiya paints I’ve tried. My heavyweight passenger fleet is a mixed bag of Walthers, Branchline, Athearn, and Bachmann cars. Bachmann is noticeably lighter but the other three are close matches and I would like to find something in that range. I don’t need an exact match. Just something reasonably close. I have a number of old coaches from a previous layout in a variety of liveries and I would like to use these to build up a fleet of commuter coaches after painting them and upgrading them with KD 148s, metal wheel sets, diaphragms.
Maybe you need to upgrade your layout lighting?
It would be much cheaper if I could find the right can of paint.
Except that color isn’t an absolute, but a function of reflected and absorbed wavelengths. Colors look different under different light, with most manufacturers considering sunlight to be the “true” color. I once tried two colors of spray paint that looked the same under the flourescent lights in the store, the color name was the same (although 2 different lines from the same manufacturer), yet when I got home and applied it to my cellar door, it was a noticeably different shade from the other can (which I had applied only days earlier), forcing me to repaint the rest of the door with the new color.
Krylon or Rustoleum have an flat olive drab in a rattle can. Usually in with the other colors sold to off road drivers, who are into painting their off roaders in cammo. Haven’t tried it myself, but it looks promising for Pullman Green.
I don’t need an exact match to my heavyweight passenger cars from Walthers, Branchline, and Athearn. I just need something close. It is much more important to me to match to those than to the prototype Pullman Green and much more important than simulating sunlight in my layout room. A close match to my current fleet is all I want which gets back to my original question. Does anybody know of a rattle can paint that is a close match to the brands of passenger cars I mentioned?
Can;t say I’ve ever seen Scalecoat’s Pullman Green appearing as just black, and besides my own layout, I’ve run locos with that paint at club shows with various types of lighting depending on the venue. Brunswick Green, on the other hand, is just black with a drop or two of green - even when I visited Horseshoe Curve, in brioght sunlight, I thought the loco on display was just painted black, then I managed to hit some anlges where the sun glinted off of it just right and I saw the slight green tint.
Scalecoat PG is a close match for what Bowser/Stewart paints their locos. It’s definitely darker than the color used by LL of P2K locos, but not black. Polyscale was close to the color used by Life Like, so whatever the replacement color in Model masters is for that, would be a lighter PG, although it looks more like a sun faded picture of the real locos. Much like Pennsy fans constantly debate over Brunswick Green, aka DGLE, Reading fans are always back and forth over what makes a proper Pullman Green for the first gen diesels.
Thanks. I’ve tried a shade of Krylon called Italian Olive. The cap looked about the right color but when I sprayed it on, it was just too light. That was the closest I could find at Walmart’s. I’m going to Lowe’s this week so maybe they’ll have something several shades darker.
I have used Scalecoat Pullman Green on my passenger cars and it looked very close to the proper color. You may want to improve your lighting. I just know it looked right for me.
Try Blick’s, an art supply house. They have many dozens of spray paints available that you will never find at WalMart, Home Depot, etc. You will have to work off color charts on your computer screen so it may take more than one try.
I haven’t heard of Blick’s. Hobby Lobby and Michael’s are the ones I know of in my area. If I strike out at Lowe’s I’ll give one of them a try.
I have only ordered via the web. Blick’s is at http://www.dickblick.com/
The site shows stores in Cleveland and Columbus. Maybe these are close enough for you to visit.
I might add that the spray paints I have ordered from Blick’s are some of the nicest paints I have used. No connection here…just a satisfied customer.
Thanks again. My LHS is in Columbus and I usually go there once or twice a week so it wouldn’t be that far out of the way. I’d be hesitant to try to match a paint color online given the experience I’ve had so far trying to match a color.
Pullman green is quite dark …
Trouble is, when observed in the subdued lighting of our train room, it looks even darker. That’s why the majority of model companies use lighter hues than the proto-type so the color looks more correct on our layouts.
I’ve found that problem numerous times using TruColor paint. Their paints are formulated to match the proto-type when new. This doesn’t always translate very well to our model world. I am constantly tweaking colors so they look good indoors.
Mark.
For what it’s worth, there was a discussion concerning Pullman Green recently on the Passenger Car Yahoo Forum.
Generally, it is difficult to “match” colors used by different manufacturers. I have Walthers B&O cars made in different runs that noticably differ, when the cars are coupled together. Since Floquil and Poly Scale went off the Market, the problem is magnified. My guess is that the Floquil Pullman Green is a close match for Branchline Pullmans, assuming you can still find it.
Coincidently, I have been looking for an almost black, glossy, Pullman Green, similar to the appearance of the Southern Railway Office Cars and HW coaches stored at Washington, DC terminal in the 1970s. From what has been related in this thread, perhaps Scalecoat II Pullman Green is what I am looking for.
Based on what others have said in this thread, I am wondering if the Scalecoat Pullman Green I tried was really Brunswick Green that had been mislabeled. I tried a can of each and both appeared flat black. I couldn’t tell them apart and I would never have guessed either was a shade of green had the can not been labeled that way.
I did some internet surfing and found a website that lists approximate equivalents of Testors/Floquil paints from other manufacturers. According to this, Tamiya’s Cockpit Green #71 is said to be a good subsitute for Testors Coach Green. That might be the next thing I try. I know an LHS that stocks Tamiya but I don’t remember seeing that shade last time I looked.
What you are saying doesn’t surprise me at all given my experience. I actually would prefer something a little lighter rather than fidelity to the prototype. I know that some lighting is supposed to mimic daylight but how true can that actually be. If we really could do that, we would probably need to wear sunglasses in our train rooms. Indoor lighting is just not going to replicate sunlight.
The shade that looks most correct to me is the one used by both Walthers and Branchline. I can’t tell them apart without looking really close and I have one train that has a mix of both types of cars. If I could find a rattle can paint close to either one of those, I wouldn’t care how close it is to the prototype.
The photo you posted shows a very dark shade of green but you can still tell it is green. The Scalecoat Pullman Green I used I don’t think would be distinguishable from the black roof. It almost isn’t in your photo and with indoor lighting, I’ll bet it would look like a solid black car.
Coach green is a LOT lighter than Pullman green …
Mark.
I wonder how your Scalecoat is drying to a flat black? I thought all Scalecoat paints dry to a high gloss.
From their website:
All colors dry to a high gloss finish, except Loco Black which dries to a matte finish.
I have used Scalecoat I in Tuscan Red and Black and I’m very happy with the results. I have only made a sample chip, brushed, with their Pullman Green but I like the color very much.
Ed
I re-painted some Athearn cars that where Santa Fe cars with Floquil Pullman Green, so I could re-decal in Northen Pacific livery. Floquils Pullman Green was a lighter green than what Athearn used to paint the cars with originally. However, both colors looked green under my lighting. I would say that what Athearn used on the cars looked similar to Mark R.'s photo of a paasenger car.
I’m finding this discussion timely as I’m about to paint a bunch passenger cars.
