Need advice on tools and setting up workbench
Santa brought some gift cards…
What tools would you recommend for someone that is new to the hobby? I am just getting started in HO, and I’d like to starting setting up a work area. I have some basic power tools (jigsaw, circular saw, drill) but really have nothing as far as tools for modeling, painting, or detailing. Do you have some tools that are absolutely essential? If anyone has a list of some sort, that would be great.
And if I was to get an airbrush, what brands would you recommend?
Thanks
Buy one of everything and you’ll be safe.
No, really:
A jewelers screwdriver kit
A Xuron rail nippers pliers
A Sprue nipper
A coupler pin bending pliers
A pin vise and drill kit
Small needle nose pliers
Soldering iron- both regular and small
scale ruler
just to name a few that are kinda Model Railroad specific.
Xacto has several kits that are good for basic modeling (knifes, razor saws, etc). I got along with that for 15 years. Lowes has several package kits with mini screwdrivers, small pliers, nippers, etc that are perfect for modeling. My wife just gave me for Christmas a Lowes set that included multiple hobby knifes and small screw driver bits. Unless you get into some pretty sophisticated detail model building, you don’t need a huge selection of jewelers tools. I’d estimate 70% of the model building I do is with an Xacto knife, razor saw, nippers, and needle nose pliers.
I’ve been using a pretty basic Badger entry level airbrush (forget the model number) for 25 years. Only know getting to the point where I’m thinking of upgrading it, Unless you get into a lot of model painting, probably don’t need the super artists quality airbrush.
One other tool to get is a rail nipper. You’ll use it all the time for cutting track to fit and it works much better than wire cutters.
Your jig saw, circ saw, and drill will do most of the work you’ll need for building benchwork, unless you decide to get into cabinet making, but that’s a whole 'nother hobby itself. You didn’t say if your drill is a cordless or not, but if not, one of the best investment I made was a cordless drill/driver. Makes putting in benchwork screws a piece of cake.
[#welcome]
Needle nose tweezers - I use these alot.
Dremel motor tool, I like the cordless 10.8v I have. I thinks there’s a 12v out.
Optivisor 2 or 2.5 power
Lots of light for your work space.
Xacto knife set - the one with three handles
Emery Boards for sanding.
Needle files - one set for metal, one for everything else.
Scale ruler
Standards gauge for your scale
Razor saw and miter box
Small screwdrivers - get a set that has flat and phillips
Fishing tackle box to hold them all
Others as you need them
Enjoy
Paul
Because I like styrofoam for scenery:
Serated steak knife
Low temp hot glue gun
Tubes of cheap acrylic paint in earth colors
Cupcake pan for the paint and water supply.
Old 1 inch paintbrush
Because I like to do wood buildings I made a razor blade based cutting tool
I also made a vacum cleaner attachment to lay ballast. I saw one at our Division meeting and it worked well. The one I made also works well and I have finally ballasted some track…
You can get most of what you need at www.micromark.com Caution! This site can be addictive.
Get the jeweler’s screw driver set
plenty of super glue ( both gel and liquid )
dremel with plenty of extras. I have the cordless 8.5 which works great and you can recharge it and take it anywhere.
kadee pin adjustment pliers
kadee drill bit and tap set for mounting kadee’s to your cars. Glue never lasts long or holds up well enough for long term service.
a nice selection of Athearn screws in various lengths for the coupler mounting projects.
a scale rule
rail nippers
a good cordless drill
a jig for mounting your cordless drill to use it as a drill press
a bench mounted vice
an organizer to keep all of your small parts and extra parts in
a miter box
a lazy susan to put your work on so you can spin it around to get to it without having to pick it up all the time. Plus tis works well when you are painting your equipment too.
as far as air brushes go, look around and read up on different ones to see which one is the best choice for what you want to do.
I can’t believe that nobody recommended a NMRA gauge and a Kaydee coupler height gauge.
Here is a link to a question posted a couple months back asking a similar one to yours. http://cs.trains.com/TRCCS/forums/t/180909.aspx
Safety glasses, and the willpower to use them every time you use a rail nipper or dremel, at least.
I use a plain old utility knife a lot when working on the layout. It also seems like a good handsaw is handier for me than a circular saw or jigsaw unless I am doing a lot of cutting, less mess as well.
A cheap drill press is nice to have as well.
As far as advice on setting up a workbench, I’m pretty sure you don’t want any from me. This is the mess that I call a workbench.
Jim
Actually a standards guage was mentioned. A lot of what you need depends on how deep intot he hobby you want to get but my list of basics is:
sheet of 1/2 inch plywood and a table to set it on or 1x4 for framing and legs
white glue (lots of it)
super glue
plastic cement (testors isgood)
xacto knife set with extra blades which has lots of uses besides modling
rail cutters I like Xuron
small tack hammer if you are nailing down track or
latex caulk and a decent caulk gun if you intened to glue your track down
patience
reading material: how to books, track planning books etc
I’ve gotten by for 30 yrs without a dremel or jewelers files or any other delicte/specialty tools.
Most important thing about a work bench, is that it be yours, and yours alone. You want to be able to leave a project spread out on the bench with some assurance that it will still be there tomorrow. Sharing with the laundry, or the kitchen table, can be very frustrating, and lead to strained relations with your significant other. Good strong lighting can make the difference between an enjoyable hobby and eyestrain. Model railroading parts are molded from dead black plastic and fit into dead black assemblies. Those magnifying lights on booms and an optivisor are well worth their cost. Small parts will fall off the bench to the floor. A clean, smooth, light colored floor makes recovery possible. A rough unpainted concrete floor awash in wood shavings and sawdust and your part is gone for good. Vises are very important tools. I have a wood workers vise, a machinist’s vise, a Pantronics vise and a drill press vise, and I use them all. I do a lot of modeling work with ordinary carpenter’s tools. I do have an Xacto knife set, needle files, jewelers screwdrivers, and a pin vise and drill bits, and a Dremel. I don’t buy a tool until I start a job that needs that tool. This keeps my tool collection down to a reasonable size.
I asked the same thing a few months ago and received quite a few good responses:
Jim: Isn’t that what a well used work bench looks like?
Dave
