Need Atlas N scale B30-7 & B36-7 Parts sheets
I need the Atlas N scale B30-7 & B36-7 parts sheets. I use these for reference purpacis and do have thses. They are the only two that I am missing. If anyone has a copy and would be willing to share them with me please emai lthem to me at igoldberg1@comcast.net.
Thanks In Advance
Ira
http://www.atlasrr.com/nparts.htm
Jim
You didn’t look … the B30-7 and the B36-7 aren’t listed - unless the B23-7 would suffice.
Mark.
That is correct. According to Atlas, they do not put up the parts lists locomotives that they do not have parts for. The B23-7, B30-7 and B36-7 are each different shells.
Ira
Ira,
Might help people to better understand what You need by changing Your wording in Your post by Editing…You’re saying You do and You don’t. Could be confusing.
Just saying.
Take Care! [:D]
Frank
To clarify what I do want. I would like to have the Atlas parts sheets for their N scale B30-7 and B36-7 locomotives. They do not make them available when they are out of parts for these engines.
Ira
Ira,
Try asking Your question on the Atlas rescue Forums, on the N-scale forum.
http://atlasrescueforum.proboards.com/
Take Care!
Frank
The differences between the B23-7 and B30-7 should be very small. The main body casting having either 6 or 8 engine doors on each side should be it. The B30-7 and B36-7 should be identical. I have one that says “B30-7/B36-7” on the packaging. The train-nut diesel books I own say the same about no external difference.
Now I’m wondering about what old documentation I have knocking around…
Hmmmm “GE B30/36-7 DIESEL LOCOMOTIVE”. Guess that would be the sheet. Now to finally use the scanner on the printer…
