Need help printing my layout
I created a pdf file out of my layout using SCARM but when I brought it to the print shop they said it will not came out with the exact dimension. Do any of you have print your layout in a print shop and what did you use to do it.
Thanks for any help.
I havent used scarm, but Anyrail has a print option where you can print 1:1 or any other ratio you need to.
Old Cuban.
I used scarm for my plan. While I was waiting for allowance to accumulate for purchasing building materials, I was Bored one day so I printed 1:1 sheets. Half a tree later this is what I put together:
I looked into getting it printed to scale and estimates were in the new locomotive range.
Then I started thinking about how I’d transfer the plan to the benchwork and still don’t have a reliable answer.
Instead I used x y coordinates found with the scarm cursor. In the scarm window the coordinates are displayed in the lower lefthand corner. After zooming in on a turnout I found the coordinates of the corners of the turnouts. I Marked the turnout corners on the bench work and “freehanded” flex track in between the turnouts. I’m sure this concept could be used for long straight runs our wandering track or what have you.
You’ll need a common reference point between the plan and benchwork.
It’s possible I misunderstand the purpose of the full sized print out. As far as a guide laying track I think there are cheaper ways. The prototype doesn’t use a printout.
Either way have fun. Looking forward to seeing your progress.
T e d
I printed my plans to 1:1 scale on 11x17 paper and taped them together.
I lay them on my plywood and use and awl to punch a hole through the paper and into the plywood. I then use a ruler and a pen to connect the dots. I then laid road bed and track.
Using SCARM’s help section, I found the instructions for printing to scale. I hope this helps. I used Atlas’ RTS and created a simple layout, consisting of the turnouts and crossings I would use. I then printed them out full size, cut them and used them for templates. Using your layout’s dimensions, you can lay out your plans and go from there.
Printing to scale
