You need Union Pacific and Pennsylvania passenger cars. The Union Pacific cars need to be heavyweights, and the Pennsylvania could be either heavyweights or streamliners. Check Internet sites such as 1st Place Hobbies, IHC, etc.
Depends how realistically you want and how much you want to spend. The PRR E7 could use Bachman P70 coaches for a traditional look at about $15-20 each on EBay or Centralia car shop P85BR coaches at $50.00+ for a post war intercity look. UP I can’t help you with. If you just want matching cars you can the UP gray and PRR Tuscan red from Rivarossi on EBay for about $20.00 per car
For the UP cars look into Bachmann Spectrum Heavyweight passenger cars and the Rivarossi Union Pacific passenger car sets. Both are apropriate for your UP FEF-1.
The UP set should be streamliner cars, while the Pennsy E unit can have either streamliners, heavyweights, or a mix of the two.
What are your curves like? If less than 24", I’d suggest using all Athearn cars, or maybe the Bachmann Spectrum heavyweights. Con-Cor, AHM, Rivarossi, Branchline, Intermountain, Walthers and others generally make scale length cars, which means 80-footers, which will be too long for tight curves.
As for the Overland cars, buy any old Roundhouse cars you can find, strip 'em with 91% denatured alcohol, and paint and letter them yourself. It’s not hard. Pullman Green and black out of Floquil spray cans, decals by Champ or Microscale, and glosscoat by Testors, and you’re done. Passenger cars wih simple lettering make for great first decalling/painting projects, since they don’t have a lot of lettering on them.
Without more info it is hard to say. Were did you see them? Typically Athear=n passenger cars are in the $6.50 range and are shorter than in real life so they can handle 18" radius curves. Concor, Rivarossi, Walthers, Centralia and others that are full 85’ length require bigger curves like 22" and preferably 30" to look right. Generally the higher the price of the car the more accurate are its details and paint job.
Does anyone manufacture the old, shorter passenger trains (like those built in the late 19th century) that would fit in Spacemouse’s 1880 theme and radii? How about MDC Roundhouse? I know that they have more of the older steam rolling stock than most anyone else.
Try http://www.trainsetsonly.com for MDC-Roundhouse for 34’ Overton SP cars. I recently purchased some from them, also P.E. (Pacific Electric-a subsidiary of the SP), as Xmas gifts to son and grandson.
Passenger cars ran $8.62 each and box cars, 2 in a set, at $14.03. S&H I believe was included in the price. I don’t see it on the invoice, anyway.
Note that as Athearn only recently bought out MDC-Roundhouse that these cars may not continue to be available and that might be why you’ve had a hard time finding them. So, I’d sorta hurry to see if they still have any in stock. You might try e-mailing them if you don;t see what looking for online?
The thing to remember about Athearn passenger cars is that you can get them in 72 scale foot length… as pointed out almost all other brands come in 80’~85’ and are really too long to negotiate a less than 24" radius nicely (their ends stick out too far going around a curve and longer trains have a tendency to derail by pulling themselves apart across the curve). Athearn Ready-To-Rolls are pretty nice and come with knuckle couplers instead of the old horn-hooks… and DOUBTLESS you can find them for the Pennsy in either heavyweight O.D. (olive drab I calls it) with six wheel trucks or in the more modern streamlined ‘lightweights’ with 4 wheel trucks. I dunno about the Bachmann Spectrum heavyweights as far as scale length goes… except that they are sid to be quite good for the money…
These are my new (old) passenger cars made by Frateschi in Brasil very nice cars metal wheels and plastic old style couplers, I changed them to knuckle couplers.
I just got a 4 car set of the 85’ Bachman Spectrum Heavyweights from a local discount house, $60 for the set. I have had Riverossi heavyweights in the past, and like them just as well. Riv have taglo trucks, and easily go 'rond 18" curves. Bachman Spectrum have coupler pockets that pivot. In all cases, I think good value. For $40/car, I expect prime quality, and get ONLY a FEW. Walther’s new Heavyweights recomend min. 24", unless you are prepared to take a knife to the centercill.
MDC also has a 50’ set of open-platform wooden style. I have no problems negotiating 18" curves. Athern’s old 70’ heavyweights too.
There is also LaBell and Ambroid/Northeastern, but they are craftsman kits. I have even scratchbuilt using those designs.
Before you make a ‘Newbie’ mistake, realize that tight radii require shorter cars and engines to look, and to run right.
18" R and 85’ cars are asking for trouble. 85’ cars should have 48" radii to look circular. Cetainly there is compromise., as few of us have 8’ X 16’ boards.
MDC ‘Overton’ cars will fit both your SP Mogul and a tight raidus.The UP 4-8-4 will give you more concerns. (Stay under 72’.) Athearn and ConCor make 72’rs.
‘Shorter’ is better, or in the immortal words of designer Mies VanderRoh …“Less is More”.
Listen to Don… I have some IHC smoothsides(needs weight) and even on 30" radius curves, they do not
look right. Any of the long cars will give you trouble on tight radius curves. Good luck, Dave
You must be looking for trouble. IHC cars are 80 - 85 footers, and cheap imitations or Rivarossi passeger cars - a line they formerly had.
If you want some cars that are too long and too light to stay on the track, buy these. They also come with TALGO trucks with 31" (undersized) wheels on NEM axles (short European) but ARE ON SALE!
Be advised that Hobby Shops were selling these @ 6.98 - and making a profit!.
If you buy JB NEM wheels, KD’S, JB body mounts, enough weights, they will come up to other cars - but then they are no longer $9.98.
CONCOR - & Every car I know of - are superior to these. Remember, Advice is only as good as your use of it.
I am not prepared to spend $50 per car at this point, but if I could find a few in the $20-30 range I would buy them.The problem is that I haven’t found them. Athearn seems to have discontinued the Pennsylvania line. As you can see, the Concors seem to be a different color scheme. Also none of the above list the length–I seem to be expected to know it,–which I don’t. If you know of a place to buy the right car, I’m pretty much out of ideas.
I am going to be using these cars on long straight tracks with large radii.
