Need some help
I am in need of some assistance to locate either part numbers or diagrams for the Lionel PA parts. Need to find some one who can supplier the can motors that are used in them as well as other manufactures.
I also need to find replacement can motors for the Thomas the train line that Lionel mad within the last 3-5 years. Not the first runs of them. I have a James the red engine we got for our son a couple of years ago.
We bought it as a parts item The boards where fried, I got the new boards. But the motor its self is bad as well so I need a new motor for it plus I would like to have some on hand. I am also in need of the wiring diagram for this as well been 2 years sitting on the to be fixed shelf and for the life of me I can not remember what wire goes where.
Tried Lionel but got no where both by phone and over the web.
Thank you.
You can try a different road name online at lionel for your PA I have had good luck with that. As far as your Thomas engine goes, it would be probably cheaper and much less aggrivating just to replace it all together. I doubt Lionel has either parts or diagrams for those.
If its modern and its not on the lionel parts website, its not likely anyone else has it.
Give Frank Timco a call 937-429-1461. He can probably help out. He has replacement motors and does aftermarket re- motoring.
Roger
sorry but if its modern and its not on lionel websie theres a few that may have what you need and tell you how to fix it. First comes to mind is Jeff kane of www.ttender.com or better yet call him at 585-229-2050
also olsen which I don’t have web address to but theres others that do. also maybe train doctor there more out there you could even contact
Bill at http://mttponline.com/ he might be able to help you.
Thomas Motor Number 610-8728-103 Lionel shows in stock.
PA Motor number 610-8953-376 Lionel shows in stock. This is only one. They used different ones.
Bill
