Needs Traction Wheels for Kato Steamer
I recently purchased a Kato USRA 2-8-2 Heavy Mikado Engine. It is a fine looking piece of railroad equipment and I am very happy with the way it sounds and runs except for one problem. The engine will only pull about 3 cars up a 2.0 % grade before spinning out. This is a problem that has plagued this engine and requires a driver with traction tire to correct it. Unfortunately, I now find that Kato does not have them in stock and other suppliers I have contacted also don’t have them.
Does anyone out there know where I might purchase the Mikado driver with traction tire (part # 11-604)?
Thank you
Have you considered “Bullfrog Snot?” It’s a liquid which you can paint on a set of drivers to create a traction tire effect.
I’ve never used it myself, but others have said it works. I’d assume it needs occasional re-application, but it’s a lot easier than dis-assembling a steamer and replacing drivers.
Sounds interesting. I’ll give it a try. Actually, as you may know, replacing the driver on this particular engine is easy but painting sounds good too. Thank you
Have you tried calling Kato USA? They will be able to help you out.
David B
I called Kato and the person I talked to said there were no plans at this time to manufacture more of the traction drivers. Just to make sure I also followed up with a letter to them and am waiting for a reply.
Thanks much
