New addition to my Alpine German village of Krausbach
Here is the latest addition to my german village of Krausbach. It was constructed using Coroplast corrugated plastic from some old signs that I got from a realtor. The hardest part was finding a glue that would work on this type of plastic. After trying several types of glues without any success, I ended up using a hot glue gun which worked perfectly. The shutters and door were made with wooden coffee stirrers. The windows were cut from transparencies for overhead projectors. If anyone would like, I can make some drawings with all the dimensions so that anyone who wishes can make them. It only takes a few hours to fully produce the structure as shown.
CPT STRYKER
Nice!
This style architecture is similar to many frame homes in the Georgia area.
If anyone wants the drawing, just ask and I will e-mail it to you. The drawing is nothing fancy, just made it using MS Paint.
CPT STRYKER
Hi Cpt Stryker
Looks like a very nice simple house just what you want in the garden.
If I may make an observation or two to give it a nice finished look the holes or grooves in the sheet edge really need to be filled with some sort of filler before painting to give it that properly finished look.
A stove pipe would also help a 4" possibly a 6" bullet head nail should be about the right diameter for that the top of the nail is close enough for a modern stove pipe top.
Just a couple of thoughts for you to consider
Yes please A dimentioned drawing would be nice if you can persuade it to arrive in Aus
regards John Busby
Thank you for the compliment John.
I will see what I can do about the end holes and add a proper chimney. The alpine house along with a few more structures that I plan to make are not intended as fine scale models. They are for anyone who wishes to have somewhat realistic buildings that are both inexpensive and weatherproof without being limited to modified birdhouses and birdfeeders. This type of construction also makes repairs very easy… just a hot glue gun, another piece of Coropolast some paint and you’re done ! Plus, you get to re-use the plastic signs that would just end up in a landfill which will no doubt make the Greenies happy. Not everyone can afford or may even want the plastic building kits from the big manufacturers (I wish I could afford all the beautiful kits that the big manufacturers make). I plan on making a few more structures utilizing this method of construction and will post the photos here in the forum. Additionally, I will always make the plans available free of charge for others who may wish to build the structures utilizing any materials that they wish. If anyone wants to modify them, by all means do so, but just make sure that you make the plans freely available for everyone to enjoy as that is my intention behind this in the first place.
CPT STRYKER
Hi Capt Stryker
I will be happy to share any plans received.
The following link I think proves you don’t have to buy a $100 kit to have detailed buildings I hope you will find it of interest as the builder seems to be using the same material you have chosen for the base bulding.
http://www.trains.com/TRC/CS/forums/1/288332/ShowPost.aspx#288332
But how much is the right level of detail is a very subjective thing, some like more some like less
I think looking right is more important, your building looks right and I felt had something that I can only call a sense of rightness about it again very subjective.
I have an “N” scale house that is very similar to the one you built hence the comment on the modern stove pipe.
What is interesting about that style of house was the number of possable slight variations on the same base house that are possable.
regards John
Nice looking house Dale. Is this house for an indoor layout? If not, I was wondering if you would report back on how well the hot glue holds up outdoors. I have a bunch of Coroplast left over from a greenhouse project and have been thinking about using it for buildings. FYI - Its made of polypropylene which is great stuff because little will interact with it (also used for indoor/outdoor carpeting). Its downside is little will interact with it making it tough to glue as you found out. Yogi Wallace also has a page about working with it - http://users.stratuswave.net/~wd8jik/plastic/plastic.htm
-Brian
thanks Brian !
I will be sure to give an update on how well the hot glue holds up outside in the summer. The only thing is that where I am building my layout, it’s on the shady side. I will also sit one out in the sun for a day to see what happens.
CPT STRYKER
John Busby,
How is your version of the house coming along ?
I think my next Coroplast building project is going to be a train station. I have been looking at photos of various alpine stations on the internet. As with the house, once I build it, I will make the drawings available free of charge to anyone who may want them.
Captain Stryker
Hi CPT Stryker
My house is coming along[oops].
Mission control we have a problem[#oops]
On a couple of the pieces I measured three times and managed to cut wrong[banghead][:(].
So its off to scrounge some more core flute.
regards John
PS The A frame can some one place them in the right thread if I send pictures that ones coming along OK
Here’s the second house for the village of Krausbach. Just a slight variation on the first one…
CPT STRYKER
Looks good Dale. How is the hot glue holding up?
-Brian
Thanks altterrain.
The glue is holding up just fine. I tested the first house by sitting it out in the front yard in the sun… nothing happened. I think if you use the low temperature glue, it will not hold up to the sun. Since my layout is being built in a shady area, it really isn’t a factor.
CPT STRYKER
Hi Cpt Stryker
The version with the chimney looks real nice has that complete finished look I was talking about.
The flower boxes are a very nice touch that makes the house lived in.
regards John
John so you cut it three times and it still wasn’t long enough![:D]
Hi ghelman
Lets just say it was one of those days, and I should have been smart enough to know the model making was not going to be any better[swg]
regards John
Gentlemen,
Thanks for the compliments !
John - My apologies, I think I may have inadvertently put in a wrong measurement on the drawing. The front and back of the house are 5 inches high, not 5 1/2. If you had made it 5 1/2 inches, it really should not have changed anything except the angle of the roof. Check your e-mail as I have re-sent the drawing with the correction.
What are you using to cut the Coroplast ?
As for me, I use a paper cutter like the one shown below.
By using the paper cutter, I get nice straight edges, and, the cutter has a ruler at the top edge with a grid pattern etched into the flat platform which really helps with alignment. I also use it to cut wooden coffee stirrers to length quickly.
CPT STRYKER
Hi Dale
Thanks for fresh drawing.
Any error in the drawing doesn’t account for the error I made it was length not height that I got wrong[:(].
I am cutting with a steel rule and very sharp triming knife.
regards John
