My son wanted a big UP steam engine, so we picked up a UP 3985 4-6-6-4 (Paragon 3) at Timonium last Sunday. It ran very well for 4 days.
Now lights and sound (and smoke if switch is turned on) come on, but the engine will only move in the forward direction for a few inches, then stop, and the headlight flashes, but the sounds and lights continue as per normal. It will not move backwards at all.
Power supply is MRC Tech 7, plain DC.
Friend from train store is bringing dcc system by tonight to attempt reset to factory defaults.
Based on my experiance, it is just a decoder problem and a reset stands a good chance of fixing it.
If you don’t care about sound, it’s not that hard to remove the decoder and rewire. Any one who can hard wire a decoder should have no trouble un-wiring one.
Broadway typically has seven wires to the loco, 2 for the motor, two for wheel pickups, other three, headlight, smoke and sensor. Not that hard to ring them out.
In the tender, just connect the right side pickups to one motor lead, left to the other, a diode and resistor for each headlight, and you are good. Forget the smoke…
We used my friend’s NCE system to perform a reset to factory default settings, to no avail. No improvement whatsoever.
The engine begins all the startup sounds, lights come on, and it starts to move a couple revolutions, so the motor, drivetrain and valve gear all appear to be ok, but then it stops, and the headlight and backup light begin flashing. That’s it. Something in the motor control circuit is kaput, no good.
See updated post below for latest information from 3rd party repair technician.
It would be a wait if sent back to BLI, but it should be fixed right by BLI and be good for one year from the date of purchase for Johnny.
If you pull the decoder out yourself (take lots of pictures first to remember where all the wires go) and send it back, for me from Florida to Pa. about a 10 day turnaround.
I hear repairs are 10 weeks out till return time for a whole engine sent in.
I passed up on some BLI merchandise at Timonium only because I did not know or ask if the vender was a listed BLI Dealer and he had nothing to write a receipt for me if I bought something.
BLI’s turnaround is 8-10 weeks as stated above. I sent my K4 out for gearbox repairs the Friday before Christmas. Haven’t heard anything but I’m hoping to have it back by the end of february.
At one point today, there was one after another today. It’s a darn shame, no matter how good their service is, that folks have to send them back multiple times.
The locos look and run nice. It’s always the decoder. They really need to step up the wuality of their electronics. Perhaps they are just too invested in their proprietary Rolling Thunder system to do what ever other manufactuer has done and used an established decoder maker’s decoders in their products. Granted they were somewhat burned by their choice of QSI early on, but they also sold locos with Loksound - the probably shouldn’t have used a different company name for those and confused people.
A shame - because I don’t think that is their main selling point. They sell because in many cases, they are specific models of locos that haven’t otherwise been offered in plastic, with a level of detail that is as good as or better than all but the highest end brass. They’ve only made one loco I can use, and I have two of them - both are from when they were sold with ESU decoders, and both run fine some 12 years later.
Changing the decoder is not very difficult, all the wiring is easy to trace, and they’ve done nothing silly like MTH, it all follows standard DCC practice even if they didn’t color code things.
Actually what the problem sounds like is mechanical or a short. If it turns for a few revolutions, then the motor circuit is working. That it stops could be a wire binding up on the drive train and shorting - the blinking headlight is commonly an indicator of a short circuit by various decoders. Could be a short on the motor wires, or a short between a track pickup and one of the motor wires.
Before you send it back or do anything you should try doing a physical reset of the decoder. A lot of times this will correct things that just doing a reset using a DCC controller won’t do. Paragon reset https://www.youtube.com/watch?v=POeA9c8ZRkM There are three types of switches that they have used in models to to this and this is described in the video. Hope this helps.
How does one get the challenger tender apart? The exploded view diagram is poor. The instruction manual is lacking compared to BLI manuals of the past which provided more information.
I’ve looked for shorts several times, and am just not finding them.
I am looking at the YouTube videos, and am just not finding what I need to find right now.
I have one too, refurbished . It’s one of my best loco’s. If your running D.C. get yourself an M.R.C. tech 6 and see how much better it will be. And if you can find one get the more powerful 6.0 version as it will run multiple BLI steamers
Scroll down, they have the various Challenger locos as well ass various tenders for them listed. Can’t open here at work, triggers the web filter for some reason. They also have the diesel ones if you go up a level on the page.
I guess they are trying to be more tree friendly and include only the basic reference information, with the rest left to you to download.
The exploded view diagram on the website is exactly the same as the one that came with the model. It appears to be missing information, and some items do not align correctly to scale even allowing for the isometric view. In particular it does not seem to show which screws actually attach through the tender floor to the body. Is the tender body supposed to snap off like it does for some of the smaller BLI engines in the YouTube videos? The diagram also appears to show the rear of the tender as being a separate piece, which would be bad for disassembly if it is glued (some other makes go crazy with glue).
So if anybody has actually taken one of these tenders apart, I would appreciate a little more information. Thank you all.
It just snaps on, it’s not glued and there are no screws. I’m not sure what order - the back with the speaker assembly might have to come out first or something.
Um, no the challenger tender body does not merely snap off.
However, I guessed correctly and removed five screws (fifth being the coupler–one must remove the coupler or else risk breaking the cut lever). Then the body does come off.
I tried a couple times to do the hard reset, to no avail. Puff of smoke from decoder, followed by acrid burnt smell. Not good.
Why can they not put a hole through the tender floor to a reset switch? Gee wouldn’t that be a novel concept? Why hide the reset switch where it is somewhat difficult to get to?
If they will fix it under warranty, I would have them fix it.
Patience is a virture…instant gratification can be a vice…or at least a foolish waste of time and money.
If you are still not happy when it is fixed, sell a working locomotive…
Broadway Limited has never impressed me the way they have entranced so many others.
Their failure rate seems no better or no worse than any of the others, including Bachmann. Their selection of offerings has limited appeal to my needs, and they are selling sound first, and the model train second… And their prices have always seemed a little rich, until MTH came along…
I have a few, 7 to be exact. But they are all now straight DC with no decoders or sound.
Two Reading T-1’s, two N&W Class A’s, two USRA Heavy 2-8-2’s, and one USRA Heavy 4-6-2.
The T-1’s are from back in the day when they offered DC locos for a brief time. The Class A’s have had their tenders replaced with Bachmann C&O Kanawha tenders with no decoders. The Mikes and Pacific have Bachmann USRA long tenders with no decoders…
Both the Mikes had issues that required complete rebuilding of the locos, BLI was not much help with parts…
