'New' Canadian National SD60s hit the road
‘New’ Canadian National SD60s hit the road
great photo… thanks
Although CN most likely plans to use the units system wide, the model, SD60 is just that, plain SD60, not the newer versions that had the “M” designation for wide safety cabs, or
what was the Canadian version,… “F’s” that had the tapered, wider car bodies that allowed crew members a little more shelter in Canada’s cold climate’s. Sure, the standard SD60’s can be used anywhere, even in the cold climates.
