This will be fairly lengthy, so by all means feel free to skip ahead to the posted track plans in the next posts if you’re not interested in the background and/or bored to tears.
For the last 6 months or so, I’ve been in the process of redesigning my spare-bedroom layout to rectify several fundamental issues with my current N scale layout. Some major design criteria for the new layout were: 1) Less cluttered track plan, 2) Better scenic opportunities afforded by a less cluttered track plan, 3) Operations focus, and 4) Longer trains (20-25 cars, vs the 10-12 of the current layout) on a longer mainline run.
I’ve been through a few major iterations of a new plan, but I think I’ve now zeroed in on an overall track plan, which I present here in order to get some first impressions and, hopefully, criticisms/concerns from the community.
It’s effectively a 3-deck point-to-point layout in a G-shape around 3 1/2 walls of the room, with balloon tracks at each end to facilitate continuous running. N-scale, code 55 for the most part, with some code 80 in hidden areas. Minimum mainline radii is 16" on the scenicked portions of the layout, about 12 1/2" in hidden areas and some sidings. Due to the small-ish size of the layout room (9 ft by a hair over 11 ft), in order to get the longer mainline stretches I desired I utilized two main scenicked decks, with a third deck on the bottom for staging. Decks are connected by dual-tracked helixes, which had to be narrow with 12.5" and 13.75" radii in order to keep a minimum aisle width (about 25", which works well for me as a lone-operator); to keep the grade as low as possible, I stretched each helix into an oval by inserting 24" of straight sections between the end, resulting in 1.57% uphill grades on the outer track and 1.67% downhill grades on the inner track. Testing has determined that double-headed trains of 25 average-rolling cars is not a problem with such an oval incline.
Lower deck staging yard. Orange track is northbound uphill mainline, purple southbound downhill mainline. Lots of space to add extra stub tracks if needed. Basic storage tracks about 110".
Middle deck, scenic run up Lehigh River gorge. Orange northbound main, purple southbound. Non-labelled track in Penn Haven closest to the aisle is the CNJ mainline, which had a freight station at the south end of the junction in real life, but I’ve not been able to determine if it had interchange ability with the LV mainline, either directly or via shared platforms.
Liberties were taken at Penn Junction. The trackage as I’ve modeled it is close to real world, but the interchange track which disappears into the southern wall was in reality the start of the Hazelton Branch, with the mainline crossing the CNJ and the river to the east side. In my model, I reversed this so my branch line goes over the curved through plate girder bridge over the river, and the mainline vanishes. The odd structure at the CNJ/LV diamonds is the tower as it appeared before burning in the 1910s or 20s.
Weatherly may or may not get model as a small town. Black Creek Junction is a simple spur track to stage some hidden loaded coal heading south.
Crossovers and interchange trackage not 100% determined just yet. Any suggestions, particularly for Penn Haven, are welcomed.
This area is only partially completed. Hazelton yard and the primary trackage I’m pretty well set on. The blue tracks are the 2 A/D tracks. I could get away with one given that I have only two classification tracks, but I plan to use one of the A/D tracks as part of a hands-free continuous run scheme. The A/D and class tracks are all about 120" in length or more, so no doubling-up will be needed for 20-25 car trains. The yard lead stretches around the lower right corner alongside the orange mainline, with a secondary lead that leads to a small industy at the north end of the right wall (maybe; if it seems I won’t bump my head on it coming in the door). The red track is a caboose track, which will have associated servicing structures alongside in the bigger gap.
The industries along the wall and it’s feeder trackage (light green) are still very alterable. The industry lead is separated by about a 2-lane road width from the classification tracks to provide some visual separation scenically. I haven’t yet decided on what I’ll model as industries, so the track has been left with plenty of wiggle room pending structures, etc. I’ll probably have more substantial industries in the lower left and right corners, with one-three backdrop industries along the left wall.
A hillside for the coal conveyor creates a tunnel on the northside of the breaker facility primarily to hide a portion of the balloon track.
I’m happy to receive any criticism of my basic yard plan, but a few things to keep in mind. I put the yard lead on the southern and eastern wall end of the yard intentionally. I’d really prefer not to put anything in the far northwest corner since the benchwork for the helix is 32" wide and reaching in there would be a problem. I may still drop from 2 A/D and 2 class tracks to 1 A/D and 3 class tracks … haven&#
Here’s a modified upper deck with reorganized Hazleton Yard.
I can extend the true double-train mainline all the way past the yard to the breaker balloon track, so I went with a single A/D track for Hazelton Yard. Five classification tracks with about 250" total storage, about the same as in the first plan I posted. This method would allow more modeling of the industries on the south wall, and clearly separate the yard from breaker visually, but at the cost of a half-length yard lead (in yellow, now at the north end of the yard). So yard operations wouldn’t be quite as efficient, but there are zero impacts from occassional “traffic” trains, so it might be a net neutral impact. I could always add a turnout connecting the yard lead to the northbound main at the west end of the helix, allowing temporary extensions of the switcher onto the main during operations.
Again, the industries tracks are nowhere near settled, and depend somewhat on what industries I choose to model. But it’s a basic idea of an alternative Hazleton yard. I don’t know, let me know what you think.
Jason, I cannot see any of your trackplan pictures that you posted.
Your unhappiness with your N scale railroad seems very much in-line with the unhappiness I had with the last N scale layout I was building before switching to HO scale.
I was also unhappy with my most recent HO scale layout, also built in a spare bedroom.
I was able to see the images since this thread was opened. The images still don’t show up alongside the text, but the links have always worked.
I am reading the narrative. And looking at the plans.
Have you mentioned the deck heights? The aisles are narrow. Lone Wolf, I understand. Skinny Lone Wolf? Tall Lone Wolf? Tall, skinny Lone Wolf? Reach-in distances are a consideration, as are sight lines and vistas. Can you reach in, see in, and bend down and reach in and see in all three levels?
Have you mentioned the grid spacing? It appears to be 6 inches. MRR layout plans use a 24-inch grid because that illustrates the personal space a person needs to operate and maneuver around. Nothing to do with Covid social distancing; just standard human kinemetrics. Can you copy-and-paste any to-scale human figures in various postures and attitudes around the layout? Particularly one of your particular caliber?
Thanks all. Yeah, I can’t get the thumbnail to show either, but the links seemed to work when I tested them after submitting the post so I let them slide. I know there’s a more preferred image hosting site this forum recommends, I just haven’t sat down to create an account there yet.
Robert: Sorry, I was going to mention it was a 6" grid but forgot during the course of posting. Those aisles are indeed skinny; about 25" at the tightest. Not ideal, but I can work with that without much pain and suffering. It’s better than the current layout, which has three pinch points at about 14".
The primary decks are only 12" deep (west and south walls), with tracks set at roughly shoulder level or a smidge higher for the upper deck, and the tracks of the middle deck roughly 15-16 inches below that at about navel level (roughly 1ft separation between bottom of the upper deck and tracks of the middle deck). Lowest deck will probably be another 10-12" below the middle deck (still to be determined based on under-layout storage needs and the overall thickness of the middle deck determined by the vertical deep of scenery below track level). So the range of track elevations are something like 62", 46" and 32-36", give or take. Reaching in anywhere on upper and middle decks from a relaxed standing position for me is not an issue. Lower deck only really requires reach-in servicing between operating session, and I have a rolling stool to sit on for those chores.
The main upper and middle decks work ergonomically for me (6’1", slender to average build) with great sight lines of the middle deck for all but the back of the southwest and southeast corners of the room, and the northwest corner to the left of the helix, but there’s nothing to do deep in those corners anyway. The view still isn’t bad in the southwest and southeast, I just don’t see as much of the backdrop. The northwest corner scenery as I have it drawn is highly flexible,
I started in model railroading in HO when I was a kid. I’d have preferred to stay with that scale, to be honest, just for the detailing available in the modeling. But I started my adult collection in N scale to get the type of railroading I was looking for in the space that was/is available to me. By and large, it wasn’t N scale itself that caused my frustrations with my current layout, but almost entirely my own design choices back before I learned better. In short, I started the current layout with one idea in mind, which was basically to just get trains rolling. I then discovered how much operations really appealed to me, and I made the modifications to incorporate that into my layout. Then I reappraised my layout with this new perspective, and asked “What the heck was I thinking?”
The layout works and trains physically run well, but because of the modifications based on changed priorities, it accomplishes neither the original goal (display running, I suppose) nor the afterthought operations goals particularly well. Fortunately, I think this new design largely addresses the issues I have with my current layout, although of course there are still significant compromises that had to be made, due purely to the space limitations.
Unfortunately, my space limitations aren’t likely to change any time soon. At least, not until the in-laws invite us to move in … then I’ll have a nice 30 ft by 15 ft finished (and empty) basement space all to myself, with another 10 x 15 ft space negotiable for expansion. So for now, I’m sticking in N scale. I figure I’m o
Let’s try these pictures, reconfigured on a 24-in grid with 1:1 scale human for perspective.
The added figures shows in gross terms the aisle spacing well, I think, but obviously I don’t hold my arms out like Frankenstein’s monster to run my trains so take them with a grain of salt. The figure I placed with arms extending over the middle deck (top image) shows the approximate reach well.
Narrow aisles certainly aren’t my ideal either. This is the smallest I will take them in this plan, and I very well might widen the aisles a little to 27 or 28 inches by modifiying the dimensions of the peninsula coming off the east wall. Unfortunately, that would be about the best I could do, short of scraping the southern helix between the lower and middle deck, and balloon track on the upper.
But, needs must and all that. It’s a compromise I’m willing to make and can work with.
Just a quick question, and an update. Update first.
I had the materials on hand to begin my rebuild for a while. Turns out, it was quite a mental challenge to actually start removing my current layout. Spent a lot of time on the old layout, warts and all. But eventually, I removed the first component, and then the deconstruction picked up pace rapidly. I have about 50% removed, enough to begin with the northern helix … because I’m lazy and didn’t want to pack up all the rolling stock, which now is sitting everywhere possible in the remaining half of the old layout. I’m telling myself it’s really because I need to keep stuff handy for testing during the new build. Yeah, I can almost convince myself that’s the real reason!
Anyhow, I’m pretty well settled on my middle and lower decks except for minor tweaks here and there as needed. But my upper deck has some options based around where I place the terminal branch yard of Hazleton.
Here’s option 1:
The orange track at B to the right of Ashmore Yard is the ascending northbound track. The blue track at Halzelton Yard on the west wall is the A/D track. Currently, there are 5 stub tracks offering about 300 inches of class trackage, which is really quite a bit more than I need. The green tracks on the south wall are industry tracks. If I shorten the main stub tracks 6 inches or so, I can extend that industry into the southwest corner and add more modeled structures, etc, to make it quite a large industry. The brown and green polygon on the south side is a joint passenger-freighthouse and platforms, and the aisle-side inbound track in purple let me develop a proper, independent switching lead for the coal breaker. Overall I like it, but the industries are a little cramped as its drawn.
Used to do space planning and 30" was the min but I have found that if you are average build 28" will work “I had a pinch point on my current build that could not be avoided”.
On my current layout, which is around-the-walls with a central peninsula coming off the south wall, I have three pinch points around 16" around the end of the peninsula. Well, I did until about 2 hours ago; just pulled the peninsula out in preparation for this rebuild. Needless to say, it was not great. Fortunately, it was at mid-chest height, so I could turn sideways and pass through without rubbing the benchwork, but just barely. Certainly couldn’t do any work while standing in those pinch points.
The way the doors in my apartment are set up, it’s exactly 28" between the door frame and the door itself when full open. I won’t be dancing any jigs in the doorway or the trainroom, but there’s plenty of elbow room. I have extra benchwork margins currently drawn on that east peninsula of the new plan, it’ll just take a little tweaking when the rebuild makes it to that side of the room to make my narrowest aisle points 28".
