Good morning to all, after after many years of collecting a few locos, rolling stock and a memorabilia I am finally taking the leap and starting my first layout in the upstairs of my garage. I built three 4x8 tables a few years back so my layout will be the shape of an L. So much to do now and it’s turned into an onion with the many layers left. I think I’m gonna use the NCE DCC system, and I know I want the perimeter of my layout to have a double main with 22” outer and 18” inner radii with a minimum of 2 turnouts. My vision is to have two trains running on the mains while I use the interior for switching industry and short car movements in a small town. I am searching the forums for answers and I have questions. First, which is better? Foam board on table top to modify as scenery or track on table top with foam board as an elevation for scenery?
If you place your L-shaped layout against the wall, you will find your arms are significantly shorter than the reach to the track next to the wall.
For larger engines, modern passenger cars and freight, 18" may not look right or cause significant overhang.
I use 1 and 2 layers of 2" foam on table top. My old layout was L-girder with cookie cutter plywood topped with homosote and was significantly easier to create grades with the track than trying to carve a grade into the foam, not to mention the mess.
I think Woodland Scenics sells foam wedgies to elevate your track, if you go with straight table top. A couple layers of foam allow you to create negative elevation. What is that? The pond is in negative elevation.
More foam complicates below track turnout machines and wiring. Ken Patterson works with multiple layers of foam and tunnels his wires to the front of the benchwork. You can find him on Youtube. He does demonstration builds for another magazine.
Your posts are delayed by moderation and the holidays. Rack up a few more posts and it goes away.
Hi sc_offroad,
Welcome to the forums!!! [#welcome]
I am using 2" foam over 1/4" luan plywood on 1 x 4 open benchwork. I want to be able to carve ditches beside the track and I want to have a shallow river scene and the 2" foam allows me to do both. If all you want is somewhat deeper ditches, then 1" foam would be fine. Otherwise, the subroadbed will form shallow ditches just fine.
Most people would say that the luan is not necessary but I want to be able to mount Tortoises and other items solidly to the underside of the layout (I tend to overbuild![swg]). In your case I’m assuming that you already have plywood table tops so there is no reason for the luan.
Depending on the length of your rolling stock and how far the ends overhang on the curves, you could probably get away with a 19" inner radius. The NMRA (National Model Railroad Association) has a lot of recommendations about clearances. It’s worth having a look.
https://www.nmra.org/standards
Have fun!!
Cheers!!
Dave
Hello All,
[#welcome] to the forums and this great hobby!
Your first few posts will be reviewed by the moderator so there will be delays in seeing them.
What is the size of the space you are planning on occupying?
How much overhead space do you have before you hit the the rafters?
With the three (3) 4’x8’ tables, rather than an “L” you could make an “H” or “T” shaped pike.
With those size curves, it will limit the length of locomotives and rolling stock you can reliably run.
If you increased the size of each table by 6 inches; 3 inches per side- -creating a 4-1/2’ x 8’- -you could increase the radii to 22- and 24-inches respectively.
On my 4’x8’ pike I use 1" foam on a 1/4" plywood base with 1"x4" open grid bench work on 32- x 24-inch centers.
My pike is based on a coal branch loop located on the Western Slope of Colorado.
Despite being mountainous terrain the loop is “carved” out of the landscape so the actual space is relatively flat.
Any features are built up rather than carved down.
There is a curved 3% grade up t
Are you using foam compatible caulk? If not, it may be reacting with the foamboard.
Evening
Welcome to the group Offroad[:)]
Wow! Got only one 4x8 slab over here, in N scale that is. There will be 11 Bridges when it’s complete, I’m building #9.
Couldn’t even imagine how many more there could be, with two more pallets on my plate.
Extruded Foam is good, and more than durable enough, to support our Tinker Toys[;)]
Silicone is more suited for bathroom tub & tile, as Alex Plus caulk is foam’s best friend, and easily reversible, if you ever change your mind on anything[Y] Loctite Polyseamseal, when ya need something a little more perminent. That stuff’s like super elastic, bubble plastic[:^)]
You’re off to a good start. With 64 more square feet of Real Estate to play with, on top of the 32, sounds like your gonna have a really fun garage upstairs.
Good to hear from ya. Hang in here with us, and keep us posted[Y]
TF
I agree with the recommendation to go wider than 18" radius on a mainline, for the stated reasons. Much better to go something like 24" & 21.5"; and also use easement curves at every place where straight and curved tracks meet.
I’m a fan of 1/2" plywood subroadbed on risers over grid or L-girder benchwork, sometimes called “cookie-cutter”; mainly because it offers more opportunity for height differential with a strong base for track roadbed and buildings. I can lean on the track for support anywhere on the layout. But if you plan for modest height differential (for creeks and gullys, etc.), then foam starts to look better.
Jim
Hello All,
Yes…
GE brand “Clear Silicone I Caulk” and “Clear Silicone II Caulk” are what I use- -apparently, the difference is the Silicone II is “Rain Ready” in 30 minutes- -whatever that means.
I have found no discernible difference in the actual curing time between the two.
The silicone caulk is cured for a full 24 hours before attaching the track to the roadbed.
Actually, quite the opposite…
The beauty of using silicone caulk to adhere the Woodland Scenics foam roadbed to the Dow extruded polystyrene closed-cell foam board is if the roadbed needs to be repositioned it peels up cleanly and quickly without damaging either material.
A quick scrub with fingers removes any residue from both surfaces and actually “cleans” the foam base.
Some people don’t like the smell of the curing silicone caulk and for that reason don’t use it.
I have not used silicone caulk with cork or Homasote® roadbed so I cannot comment on how it reacts with those materials.
Oh, please don’t call the “Adhesive Police” on me! (See my signature.)
Hope this helps.
Don’t use silicon caulk that has lived in a garage where it was exposed to freezing temps for a couple years. It never hardens. DAMHIK
Dap 320 works fine to adhere cork to foam.
Thank you!
Good luck to you as I am new to the forum as well.I am trying to build a large scale (1:29) railroad in my basement (16 x 50) and while I finished the benchwork I need help with the track laying and wiring (I’m 74 years old). If any of you know of someone in the Chicago or northwest Indiana area who can help me, I would most appreciate contact information. Thanks.
Hi CSLTRAIN,
There are several professional layout builders in the US and most of them will travel to you to do the work. I googled “Professional model train layout builders” and got several hits.
I recently tried to hire a professional layout builder to help me lay track and do the wiring. Unfortunately the Canadian Labour Laws required that he get a work permit to come from Tennessee to work in Ontario, and the cost just for the permit was absolutely horrendous!! Of course, you won’t have that problem, but a pro builder may have some requirements regarding the benchwork that you have already built. Specifically, if the benchwork is not stable, either because of construction errors or environmental issues like temperature and humidity changes, the layout builder will be very unlikely to guarantee their work. The best tracklaying in the world won’t stand up to shifting benchwork.
You should also be prepared for sticker shock!
There is an alternative, and that is to seek out train clubs in your area and join one. Once a person has proven themselves to be a respectfull and supportive member, you may find members who are willing to help with your layout for the price of donuts and coffee. Just don’t expect them to do all the work, and do organize operating sessions on your layout as soon as trains can be run and often thereafter. It doesn’t matter if your layout is still a ‘plywood paradise’. Model railroaders are quite capable of using their imaginations!
Cheers!!
Dave
Just 2" foam here for base, never a problem.
