new transformer for me.
I bought a TAC 2001 by Troller Industries at a flee market yesterday and it looks like a kit type transformer. Has two differant voltage settings, 0 to 9 and, 0 to 18 volts. Just checked it with a multimeter and it seems to work, before I put it with my trains I want to know if there is any cautions to be taken with this transformer? Also has accessory outputs as well, and should control 2 trains at one time, and has whistle controls for each train.
From what I can see, it looks like I may use it for my Williams engines.
Lee F.
The transformer works pretty good with one of my Williams engines and B unit that has a True Blast 2 horn unit installed. Only one minor problem and that was having to reverse wires at the track to get the other sound from the T.B. 2 horn unit.
Just wondering what I should try to sell this transformer for? It is a Troller model TAC 2001, 150 watts and has differant voltage taps for accessory hookups. Would $40.00 be low or high for this transformer?
Lee F.
I have a few of these, maybe 4. The most I’ve paid is $41.00, shipping included. So you are in the right ballpark.
The TAC 2001 has some nice features - a wide range of accessory outputs including 24v if you need it. As you have discovered, the switchable voltage range is quite handy for Williams(or K-Line) engines that still have their motors wired in parallel.
And the power output is a better continuous rating than a 175 watt KW.
At that price ($40/) why not keep it around for PW trolleys, or static lighting, or operating accessories, or bias for switch machines/signaling, or lit shelf cars, or… [*-)]
Which is exactly what mine are for. Their versatility for accessories and lighting will go a long way in taking the loads off the transformers for the trains.
As I mentioned in my first posting, I bought it at the flea market in a box of stuff for(hold on to your socks!) $20.00. The transformer case has not been opened, as the rivots are still in it from the factory. It was with a bunch of 027 track, five bridges, six 027 switches and a few plastic buildings. I had to junk the 027 straights and curves as they were too rusty, there is always scrap metal, so I can get a few pennies for the rusted out tracks. At the time(10:45 am.) I bought the box of track and other stuff most of the good bargains were gone, guess nobody knew what the value of some of that stuff was.
Lee F.
