So I’ve been trying to find some appropriate postwar NYC streamlined equipment to put behind a Hudson. However, after looking through photos and videos I’ve had some confusion over the variety of lightweight NYC cars I’ve seen.
So some of these cars are fluted and some not. I’ve seen fluted and non-fluted roofs on the fluted cars (which I believe are part of the Budd postwar order?), with some fluted roofs appearing to be painted black, unless the lighting is just hitting them funny in the media I’ve seen. I’ve also seen smooth-side cars and those usually have black roofs but varying colors on the sides.
I’ve been using this website (http://www.canadasouthern.com/caso/NYC-MODELS-PASS-PAINT.htm) as a source, and it’s been very helpful, but I haven’t been able to find explanations for the roof colors and variations in particular. Does anyone have more information on these variations? I would appreciate it if you could share them. Thank you!
In quite general terms, you are correct that the fluted stainless steel roof is the product of the Edward G. Budd Company. Pullman Standard, American Car & Foundry, Pressed Steel and others used a flat sheet steel roof which was usually painted with an asphalt-based paint.
Over time this appeared as a grimy black. The Budd roof was not originally painted and they, too, became crusted with soot and road grime until they appeared to have a black roof coating but in reality they were not coated in any way until some developed leaks in later years.
The car cleaning machinery generally did not scrub the roof of the cars so the grime continued to build up.
Many of the post-war passenger car orders were so backed up that in some cases it took two to three years to fill an order thus the railroads bought from several builders in order to fulfill the demand for new equipment.
Budd-built cars were made entirely of stainless steel and this method proved to add considerably to their longevity, many in service even after Amtrak assumed ownership. The Pullman and ACF built cars suffered from severe corrosion beneath the stainless steel sheathing as water migrated between the sheathing and the steel side sheets. Some railroads stripped off the fluted sheathing and made repairs, others merely scrapped the car earlier than expected.
Here’s a look at three former NYC Budd cars now under Penn Central ownership. You can see that the roof “almost” looks painted but that is simply an accumulation of road grime.
NYC cars with “smooth” roofs are either Pullman-Standard or ACF built. Budd built cars have the corrugated roof. The roof color can vary from stainless steel to black, with many shades of grime in between. Checking photos of cars from all builders in Morning Sun’s New York Central Color Guide to Freight and Passenger Equipment Volumes 1 and 2, show the roof color to be a build-up of exhaust soot, road grime, and general atmospheric pollution that is not removed by the car washing machines. Most of NYC’s streamlined fleet possibly excepting the Budd slumbercoaches was old enough to have run behind steam. That is why the older Budds have black roofs in many cases. Look at the roof on most Budd RDC’s.
On many cars the roof color does not come all the way down to where the roof joins the sides, giving a good indication the roof color is not paint. Also the areas that would begin to be out of reach of the brushes show a scalloping of the roof color along the joints in the roof panels where they join the sides. Southern Railway experienced the same situation with its streamlined cars. The New York Central System Historical Society can give you a more definitive answer to your question.
All these years, I just thought the NYC had gone with a rather cool* unpainted stainless & painted black roof scheme for most of their streamlined passenger fleet, and now I learn that in most cases it wasn’t intentional, they just didn’t wash the roofs…
*Cool as in slightly cold, menancing and post-industrial look silver and black, like the Oakland Raiders uniform colors or even the high-end home sound equipment of the 1990s…
Okay, but here’s the bit I don’t get – I’ve only seen the black roofs on cars with dark gray letterboards. Cars that have no color on the letterboards sometimes have dirt on the roofs, but not to the point they look black. And while I look at way more NYC passenger cars than anyone else’s, I don’t recall seeing other roads’ cars with a roof that looked that deep black.
The Canada Southern page Mjorstad mentions notes the dark gray letterboards added after the summer of '56, and adds:
"* As car roofs began to leak - some cars had F-1 car cement applied to roof to seal leaks ( F-1 car cement is BLACK ) "
Could that be what we’re seeing?
Incidentally, Walthers reproduces some NYC and PC cars with a black fluted roof. Apparently NYC Sleeprercoaches were done with and without:
As an addendum to the question above me, when did heavyweight coaches, diners, etc receive the two-tone grey scheme? On the website it says 1953, but I see a lot of photos and videos with heavyweight cars painted in that scheme in the early 50s, and IIRC correctly some were taken before ’53. Can someone clarify this? Thank you?
While I know very little about the New York Central (or most eastern roads for that matter), I did notice that accumulated grime on roofs is reliatively common. I have seen pictures of SP&S cabooses with roofs so dirty that they appear black, when they really used to be red!
As far as modeling I’ve seen people both paint the roofs solid black or the original color, it just depends how dirty you want your cars to be!
Well, the gray letterboards came along right about the same time the Budd “Shotweld” roofing began to show signs of age — and leaking — so the roof cement was applied as needed. Seems like many of the coaches and parlor cars built for the 1941 Empire State Express were some of the first to get the asphalt cement treatment.
In 1945 the Pullman Company began applying a nearly identical two-tone gray to many of their heavyweight pool cars. The earliest photo I’ve seen so far of NYC owned heavyweight equipment wearing the simplified two-tone gray of the 1948 design was taken shortly after this date in late 1949.
Most, but not all, of the head-end cars were simply a solid dark gray.
Two good references are the Pullman Paint and Lettering Handbook by Arthur Dubin and The Cars Of Pullman by Joe Welch, Bill Howes and Kevin Holland.
One more follow-up question to your answer: so was that two-tone initially only applied to Pullmans after the divestiture, and then the rest of the heavyweight fleet (diners, coaches, etc) in 1953 onward? Or does this mean that NYC owned and operated cars also received the same scheme at the same time? And for how long could Pullmans be seen in Pullman (or Pacemaker) Green after the war?
The two-tone gray was used on pool cars well before the divestiture. I’ll have to do some digging to get exact dates. Of course there were many other pool cars, some solid gray, many Pullman green and others in UP yellow or PRR Tuscan. It depended on where Pullman had the cars located and what lines the cars spent the majority of their time on.
The actual ownership transfer didn’t take place until June 30, 1947. Not much visible change occurred, we’re talking about 609 lightweight cars and the railroads had an option to buy 3,994 heavyweights at a steeply discounted, depreciated value.
The travelling public wouldn’t have seen much of a difference, if any at all. Generally the dining cars were always run by the host railroad although Pullman did run some full diners and nearly all the club-lounge service.
The main difference in the New York Central’s case was the replacement of the 7" PULLMAN lettering on the letterboard with New York Central. Cars that were leased back to the (new) Pullman Company then had a smaller 3" PULLMAN lettered at the car ends. Later this was removed as the leases expired and the railroads assumed more of the operation.
Many of the cars ran out their lives in Pullman green paint. Traffic was declining, more lightweight cars were available, railroads weren’t going to invest in repainting heavyweights that were soon destined for the scrap line.
Again, this is all general information. There were certainly specific cars that were retained and cared for but these are the rare exception.
The black on the roofs of the New York Central cars was a substance called F-1 car cement. It was an asphaltic compound used to seal car roofs which had started to leak. All or nearly all of the Budd-built cars eventually got it. Some of the Pullman-Standard 3000-series lightweight coaches appear to have gotten
that treatment as well. It may also have been applied to other cars.
Other railroads had similar problems and used the same or a similar substance. I believe Chicago and Eastern Illinois did so and I think Seaboard Coast Line may be another one.
The original NYC “two tone” gray paint scheme was a medium gray body with a dark band through the windows. This was applied to smooth-side streamlined cars bought for the 1938 20th Century Limited, and the streamlined Hudsons were decorated to match, as were the first E-units that came in 1945.
A few years later, the railroad bought fluted-side stainless steel cars for use on the newly streamlined Empire State Express. They chose to delay the new train’s first run until a Sunday, since they figured they’d get a lot of free publicity in the Monday papers since Sundays were always slow news days. So the first run of the streamlined Empire State was Sunday, December 7, 1941. [oops]
In IIRC 1948, they reversed the 20th century paint scheme - dark gray body with medium gray through the windows. This is the most commonly thought of version of the two-tone scheme, and was used until the end of the railroad in 1968.
I don’t know if there was a specific date the railroad started repainting older heavyweight equipment into the two-tone scheme. I think some cars, particularly head-end cars, may never have been repainted from Pullman green.
For a while NYC tried to keep cars of the same type together, but by the mid-fifties it was kind of ‘mix and match’ - you could see a train with Pullman green heavyweights, two-tone gray smoothside cars, and a couple of stainless steel fluted-side cars all running together.
