A lot depends on what you want to do, work with the trains, or work in an office.
If you go straight from school into management, you will never line a switch or ride the locomotive, you will be in the office most of the time…the closest you could get to hands on railroading would be a train master position, which is pretty much low man on the totem pole management wise.
On the other hand, if you want to learn railroading as a skill, before you move up, then apply for the operating craft.
Before you consider any of this, decide if you want to go home every night to the same home and bed, or if living out of a backpack and a suitcase, staying at a different place every night sounds more like it.
The reason is simply…if you join a Class 1 as management, you will be transferred all over the place the first few years, from one end of the system to the other, so…
And if you join a Class 1 in the operating department, the same applies, in pool service or riding the extra board, the odds of getting home more than once a week are rare.
There are 3 major classes of railroads…
Class 1 roads, the “big” railroads, UP, BNSF CSX, NS, and KCS, plus the Canadian roads.
Check out their system maps, you’re talking about a lot of ground to cover, and you will will be in your early 50s before you end up in a permanent residence.
Class 2 roads, which are local or regional roads, odds are with a local you get home most nights, with a regional, 3 to 4 times a week.
Class 3 roads, terminal and switching railroads, (I work for one, the PTRA) and I go home every night, have assigned works days with regular hours and regular days off.
At all three classes, management are salaried employees, nonunion, and most entry to mid-level managers, no matter what position, are on call 24/7…you can work 16 to 20 hour days on a regular basis.
The benefits are some type of profit sharing as a bonus, some offer
