NOT choosing between DCC and DC...
My layout only has room for small engines, and at the moment I only have 1 loco, which has a DCC decoder.I use Bachmann ez command. Ive started looking to expand my loco fleet, but some of the locos I want will probably not have room for a decoder. I wasn’t sure if I should only use dcc ready locos or go back to dc and only have 1 loco running at a time. Then it hit me,why choose? my plan is to have the track bus connecting to banana speaker jack sockets, and have my Bachmann dcc controller and a dc controller each connected to banana plugs so when i want DC opperation, I can detach the DCC controller and vice versa.my trackplan is basic, no balloon loops or anything complicated.
would that work? or in other words, can you really have cake and eat it too?
By the way, the sockets are available at radioshack here
Since you seem to be planning to change the entire layout from DC to DCC (or the reverse) at the same time, I’d say go for it. Just make sure all of your analog DC (not decoder equipped) powered rolling stock is safely off any powered section of rail before plugging in your DCC system - the constant power to the track will smoke an unprotected motor.
Chuck (modeling Central Japan in September, 1964 - analog DC, MZL system)
yeah I learned that lesson the hard way… [:(]
are all dcc decoders able to run on dc too? i hadnt thought of that.
In general, yes. Som ehave a CV that can be set to enable and disable this mode. A decoder that doesn’t run on DC will do nothing.
I don’t think all are DC compatible. You can use N and even a few Z decoders if your locos are newer and don’t draw too much amperage. There’s not a whole lot you can’t fit a decoder in these days.
My layout was DC. When I went to DCC I put a DPDT switch in so I could go back and forth. I never ghave gone back to DC once.
All my DC engines run on the DCC address of 00 (I have Digitrax). I left the old DC blocks in place and I can park my DC locos on sidings and turn those blocks off. When I want to run a DC loco, I turn that one block on, set 00 and a way it goes.
I plan to do something similar once I can afford DCC. The DPDT switch is the way to go. A lot easier than jacks and plugs. It can even be a center-off type. Just make sure that it can handle AT LEAST 5 amps. 10 would be better as some of the cheaper ones are overrated.
Karl
A decoder might not respond to DC, but unless you way overvoltage it, it isn’t going to hurt anything. A DC signal is just a DC signal that goes forward and reverse really fast.
I’m glad to see someone else is doing the same thing!! really easy to do. I was also thinking about the toggle sitch idea but went the speaker jack route.
It is my understanding that Soundtraxx decoders other than Tsunamis will not tolerate DC at all. I’m not willing to try it but that’s what my LHS warned me when I said I was building a layout that could go from DC to DCC.
In actuality, I rarely run DC any more and will probably convert to DCC only when I expand my current layout.
Mike
There is no need to switch back and forth. Your EZ Command will run one DC engine on address 10. You can even run one DC and up to 9 DCC engines at the same time.
When you are ready to move up, there are several good DCC systems. All of them will run one DC engine. Since your DC controller can only run one engine, why change back and forth?
BTW what engines are looking at that you think won’t have room for DCC?? Nowadays it’s pretty hard to find an engine that’s too small for a decoder, even tiny engines like say the Spectrum two-truck Climax is set up to accept a ‘plug and play’ 8-pin decoder.
One of the reasons for wanting to keep DC I forgot to mention is that I want to have an automatic IR shuttle system, and I read on another thread that that is harder to do on DCC, and figured it would be even harder if not impossible to do on EZ command. The reason for the jacks and not a switch is just so I can store the controllers away when not in use.
One of the locos I want in the future is a BR 0-4-0 pug:
http://www.collectiques.net/catalogue/hornby/trains/pugclass0f.html
Probably not impsossible to get a decoder into one, but difficult. and I would like to take my time with decoder conversions anyway.
I have a P2K SW8. And it’s instructions say a decoder was not included because it wouldn’t fit. But it later says to remove the weight in the engine to make room for a decoder if you want to go that route. Now removing the weight from a locomotive, even a switch engine, sounds like folly to me since it would be able to pull a toothpick without some trackion. Any advice on this?
Also, for the most part, I am starting out my collection buying locomotives without sound or DCC controllers in them. But, prefer models that are DCC ready. Believeing that when I’m ready to start operations I would like to have all the same decoder from same manufacteror etc. The spectrums come with it in there, but from reading the documentation I don’t believe there will be too many problems intergrating them.
http://kalmbachcatalog.stores.yahoo.net/12242.html
If your layout is small and you don’t need transponding or detection then the way you wire for DCC is to hook one wire from the control station to the right rail, the other to the left rail, check for short circuits and plug it in.
If you want to use it to it’s potential, then try the book at the above link.
The Bachmann system can run DCC and DC locos at the same time without the use of a separate power pack. Also for small locos, Digitrax makes several decoders for N and Z scale that are robust enough for use in HO locos and will fit almost anywhere.
Well I have a P2K switcher - I think it’s an SW8 - that I run back to back with my BLI NW-2 (which came with factory sound and DCC). I had no trouble converting it to DCC, just “plug and play” as I recall.
I have had to remove the additional weight from a couple of engines to get a decoder to fit in but we’re talking about a very small change in the engine’s weight, it still has the weight of the chassis (which I think has a weight under the motor?). Maybe an ounce?? It’s not that big.
Besides any loss in weight is made up for by the improved running properties - momentum to allow gradual starts and stops, Back EMF to allow it to run up and down hills without changing speed, setting the CV’s to allow a greater range of control at lower speeds, etc…not to mention adding sound if you want.
Remember P2K makes SW8’s with factory DCC and sound afterall, and they run and pull fine. Plus you should be able to convert any HO or OO engine to DCC, look at the N scale engines with DCC, even Z scale ones !!
