Are the 8 notches the only points on the controller where power changes, like an electric motor on a fan where there are only a finite number of speeds or is it a variable control where you could put it between notches to vary the power slightly (less than it would at the next fixed notch)?
Short answer, yes. At one time, I think it was GE that came out with a 16 notch throttle. If connected via MU to an 8 notch locomotive, the 8 notch loco simply ignored the ‘in between’ notches.
The key here is the 8 notches require only a few wires between locomotives (via the MU cable). Think octal/base 8.
Changing the throttle varies both the electrical power to the traction motors and the Diesel prime mover.
It’s always satisfying to have a train “settle in” without having to vary the throttle.
The PRR GG-1 electrics had 32 notch throttles, I believe.
There are a couple of earlier threads that provide some background information, namely:
‘diesel notch power settings’, at: https://cs.trains.com/trn/f/741/t/283879.aspx?page=1;
and:
‘Locomotive MU systems’, at: https://cs.trains.com/trn/f/741/t/291088.aspx?page=1.
Cheers,
The GE 16 notch throttle only had 8 engine speeds, but with each speed having two generator load settings.
Early Baldwin locomotives (and others) were equipped with air throttles that acted as a continuous variable speed throttle.
It may help for you to read up on Frank Sprague’s design of MU control, and modified Ward-Leonard control of gas-electrics, as a background for how diesel-electric locomotives with AAR 8-notch control are set up. You should also review previous posts here about series/parallel and EMD’s later use of permanent parallel with stages of field weakening.
The eight notches basically control the rotational speed of the diesel engine, with a system of solenoids controlling the engine speed governor to within a few rpm. As load on the engine at a particular speed increases or decreases (by varying the field of the traction alternator/generator) the governor automatically adjusts fuel flow to the engine so it makes greater or less power at that rpm.
This is not intended to work like the accelerator on a road vehicle: when the additional fuel ‘maxes out’, the train will accelerate up to where the train resistance (e.g. approximated using the Davis formula) balances the power delivered at the railhead by the traction motors. To ‘go faster’ you’ll select a higher notch, where the engine will have more power strokes per minute to be ‘maxed out’ in fuel feed, and therefore produce more power. (Note that the amount of exhaust volume determines the effectiveness of turbocharging, and this is usually nonlinear notch-to-notch, which is something to be aware of).
The electrical load varies with applied field, as noted above, and this is done automatically rather than with an additional power control. The GE ‘fifteen-notch’ throttles modulated the field differently to give the effect of the ‘half-notches’; the system fundamentally defaulted to AAR 8-notch when anything but a 15-notch GE was in the power consist.
This is very different from the ‘throttle’ control used on PRR electrics. The GG1 famously had a 22-notch controller that worked by tap-changing – the highest 5 positions were blank
The newer GE’s (Wabtech’s now I guess.) still have that half notch setting, but only when the Trip Optimizer (Energy Management System with auto throttle/dynamic brake control) is engaged. A human engineer only has the 8 notches.
I believe only the lead engine is so enabled. Any trailing GE’s are run only in the 8 notches.
Jeff
Amtrak’s F40PH’s had a notchless throttle when the diesel engine was running at its maximum rpm to supply headend power to the train. They reverted to a standard 8 notch throttle when not supplying headend power.
The E-44 had 29 tap-changing motoring notches, and 17 dynamic braking notches.
I have seen it said (right now I can’t find where) that the E-44 fleet was equipped to MU with diesels, but I have not been able to confirm this. If so, one might expect an additional MU jumper socket at each end, but none of the pictures I have seen show more than the paired electric jumper sockets at each side.
Nonetheless, had that mixed MU capability actually existed, one may derive the required notch mapping by indirect means, from the work that GE did for the DoT in modifying one E44 to incorporate chopper control. The modified E44, referred to as an E44/E60, had a standard eight notch controller (as I think did the Amtrak E60CP) that conferred MU compatibility with diesel locomotives. But the E44/E60 was intended to be used in MU Trail behind an unmodified E-44. The notch-mapping matrix for this was given as:
Standard E-44 notch range mapped to E44/E60 notch in each case.
Logically this map could also have been used for the E-44 plus diesel case.
I don’t think that the E-44 was set up for backward MU compatibility with earlier PRR electric types. The E2b prototypes though were setup to MU with the P5a fleet. This is probably why they had 32 volt rather than the expected 74 volt auxiliary electrical systems. Differing control voltages is not a barrier to mixed MU working – and it has been done - but typically it does require voltage conversion relay sets both ways.
Cheers,
Re the GE 16-notch control, I have not found a single source that describes this in detail. Thus what follows is constructed from several sources, along with some deductions, so might not be correct in all respects.
It was used, with three-field excitation, on the U25B/C, U28B/C and U50 models, and with electronic/PWM excitation on the U30B/C and early U33B/C models, and also on the Alco C855.
With a 16-notch locomotive leading a consist, then any other 16-notch locomotives trailing in that consist also operated in the 16-notch mode, even if they were separated from the lead locomotive by one or more eight-notch locomotives.
When a 16-notch locomotive was trailing in a consist led by a standard eight-notch locomotive, then it defaulted to the eight notch mode.
As already said, the engine had the customary eight operating speeds, which notchwise were shared as follows:
Notches ½, 1, 1½ 1st speed
Notches 2, 2½ 2nd speed
Notches 3, 3½ 3rd speed
Notches 4, 4½ 4th speed
Notches 5, 5½ 5th speed
Notches 6, 6½ 6th speed
Clarify something for me. The F40PH had two distinct methods of HEP. One involved running the diesel engine at 843rpm (a precise number, related to the number of poles in the special HEP alternator and the HEP line frequency). The other involved running the engine at 720rpm to get 60Hz off the traction alternator, probably the same as the U34CH.
In either case, the diesel engine rpm would be governed within very close limits, so “locomotive road speed” control would have to be done with variable field… which would inherently be stepless PROVIDED there were some way to trainline a proportional signal to trailing units. I am not familiar with how that would be (or was) done.
I’m going to try to add and or simplify.
8 notches? Three solenoids in the Woodward Flyball Governor. 2^3 = 8 distinct engine speeds. (Purists will note that there are actually 4 solenoids in there - the 4th for shutdown from the control stand. Later used to get low idle and low-low idle speeds). Three (four!) wires plus ground for MUing.
U25s and their funky 16 notches? My recollection was it gave the engineer some control over turbo lag and engine smoke. He could do the half notch and get the next engine speed without the accompanying load. Let the engine and turbo spool up a bit before putting the full juice to it. Most U25s I ran across in the late 1970s had the half notches wired out. The controller would notch, but it did nothing.
A basic difference between EMD (up through Dash 2) and GEs was how HP was regulated.
EMD let the governor have control using the load regulator. Put it in notch 8 and the engine would come up to speed and increase the fuel rack to a set point, using the load regulator (controlled by the governor) to get the fuel rack setting to the set point.
GEs run with load regulator at max. Excitation is regulated by the locomotive’s control system.
EMD will balance at a set fuel rack point. GE will float the rack to get the HP.
Consequently, a GE would always try to do it’s rated HP, while an EMD might do more or less depending on fuel temp (and other things).
This difference allowed GE to do all sorts of whacky things over the years.
Some U boats had 1-5-8 speed schedules. (but 8 notches of power). When you notch out from 1 to 2, the engine goes to notch 5 speed, then when you notch from 5 to 6, you get notch 8 speed.
Later, there was “skip 3 double 6” on some Dash 7s. Notching 1 thru 8 got you 1, 2, 4, 5, 6, 6, 7, 8 engine speed.
These were all about smoke and trying to min
Know that some AEMs had notchced and others called “P?” Riding clocker Engineer complained train sluggist with 2 AEMs. RFE went back at stop and cut second unit out. Performance better with just the lead unit. Some one who understands it please explain.
None of those problems with Diesels if using an electric motor(s). The ICTs certainly will work well under wire. How are the QSKs handling these known lags?
Sure the RFE cut the 2nd unit out, or did he correct a improper connection. I know you can only go by what he said - but the truth has been know to be a rare commodity for some individuals.
That was is Cunningham (*), on p.67. In describing the PRR E-44. It was said:
‘Dual controls for bidirectional operation were included, as were dynamic braking and a capability of multiple operation with diesel locomotives equipped with standard control systems.’
(*) Joe Cunnningham; New Haven EP-5 Jets; NJ International, 1991; ISBN 0-934088-26-8
Cheers,
EMD had developed a notchless power control option for its GM6C and GM10B prototype electric locomotives, so presumably had worked out its own method for relaying electrically a continuously variable signal to trailing units. Presumably the same could have been used for diesels, although that would probably make them incompatible with standard eight notch diesels for MU purposes. On the other hand, the electrics had the option of eight notch control for diesel MU compatibility.
In worldwide electric locomotive practice since the mid-1960s, one method used for conveying a continuously variable control signal to trailing units in MU was to convert the variable voltage into a PWM signal that was sent down the jumper cable (possibly on a screened wire) and decoded locally in each trailing unit.
Cheers,
PWM for control makes sense as the duty cycle (i.e.pulse width) can be recovered with all sorts of voltage drop from the lead locomotive to the final trailing locomotive.
There was a recent thread over on the MR forum which is highly amusing in this context, regarding whether certain modern full-scale locomotives use DCC…
The signal for the MU wires comes from the control stand. The throttle lever is connected to cams with switches. That is standard. What the locomotive does with that information can vary…
