NYC GP40
Hi,
here is a picture.
I want know what´s about the cylinder on the right side of the nose.
What company makes a detail part inHO?
I believe it is an Automatic train stop motor / generator.
I cannot find a model source for it at this time.
John R
Christian, it looks like the ATS Generator for the ATS Shoe on the front truck. This part is available from Custom Finishing #208.
Rick J
[quote user=“EmpireStateJR”]
John R
Check notes below on NYC GP40s.
John R
EMD GP40 — 25 units
B-B; 16-645E3 engine; 61:16 gear ratio; 3,000 horsepower; 277,000 pounds operating weight
Road
Number
First
Number
Second
Number
Third
Number
Builder
Date
Builder
Number
Date
Retired
Notes
5500
NYC 3010
PC 3010
CR 3010
Dec 1965
30947
5501
NYC 3011
PC 3011
CR 3011
Dec 1965
30948
5502
NYC 3012
PC 3012
CR 3012
Dec 1965
30949
5503
NYC 3013
PC 3013
CR 3013
Dec 1965
30950
5504
NYC 3014
PC 3014
CR 3014
Dec 1965
30951
5505
NYC 3015
PC 3015
CR 3015
Dec 1965
30952
5506
NYC 3016
PC 3016
CR 3016
Dec 1965
30953
5507
NYC 3017
PC 3017
CR 3017
Note also the ATS shoe mentioned by one or two people above (looks like a funky brace below the bearing for the first axle on the front truck).
I do believe these two things are related; pretty sure I’ve seen detail parts for these from either Details West or Details Associates. Having no particular need for these details as the railroad I model never used any form of ATS, I’ve not looking into this very closely.
Yes it is Automatic Train Stop equipment. I use the Custom Finishing part mentioned, as well as the shoe on the first axle. I also use the ground mounted inductor that passes the signal to the ATS equipment on the locomotive, along with a small junction box. It makes for interesting wayside details. ATS would apply the air brakes if the engineer passed a signal that indicated stop, and then he had some splanin to do about why he ran a restritive signal aspect. There was an electrical cabinet on some NYC locomotives, such as the one in the same location on the following Pennsy unit. Some NYC units had the other components hidden from view with no ancillary cabinet, and some had the cabinet. They were also applied to steam locomotives, but the pick up shoe was mounted on the tender trucks, with the equipment box usually up by the water hatch. There is a little round gizmo mounted on the frame, directly under the 4 in the unit number, with a flexible cable going down to the shoe that is also part of the ATS.
Paul
Dayton and Mad River RR
