Most of the larger “scale” stuff will work on 42" curves both engines and cars. If memory serves me correctly the biggest problem with the 027 track is not the track itself but the switches. Flange clearances for the scale items.
Checkout the postings by “spankybird”, all 027 and he has a link to see his layout.
The differences between O and O-27 are the rail profile and thickness of the steel sheet used to make the track and ties. O gauge track has a much higher profile to accomodate pre-war deep flange wheel sets. If you can find track/switches of the desired radius in O-27 profile, use it. It’s cheaper and looks closer to scale.
I prefer the look of O-27 track. K-Line makes excellent low-profile swithces in 27 and 42 inches. Since you don’t plan on running very large engines, you should do fine with O-27.
I too vote for 027. I never understood the criticism that 027 is a little more flimsy that regular 0. This might be a concern if you had a floor layout that was being pulled apart and put together frequently.
As said above, on a smaller layout especially, the lower height profile of 027 is much better looking. And on a comparison level, K-Line’s redesigned 027 switch is far superior to the traditional MPC design being used by Lionel for the past 35 years. Though some of the older Lionel switches like the 1024 I believe are an improvement over the MPC era ones.
You can also easily match the Gargraves switches to 027 track using their connector pins for that purpose.
And guys like Lionelsoni will wholeheartedly recommend using the older MARX switches. The only problem with the older all metal ones, is that it is a challenge to get access to the solenoid since the sheetmetal cover is tab-folded into the base. But these switches work like champs too when you can find them in excellent shape.
Not to mention the 34 inch diameter 027 track that MARX once made and can still be found with some effort. Beats me why no one (you’d think K-Line would have done it years ago) introduced the 34 inch diameter track again.
A comment about Brian’s comment of “This might be a concern if you had a floor layout that was being pulled apart and put together frequently.”
I have a Christmas-only layout meaning that I pull it apart and put it together frequently, if once every year for 30 years can be called ‘frequent’.
I have pieces of O27 track that span those 30 years and they’re still going strong - as long as I remember to tighten up the ‘hole’ that I extract the pin from.
I used to be a fan of 027, but I switched to O gauge long before the selection of 027 style switches hit the market. The main reason for the change was to get the 072 switches. I still like the features and operation of Lionel’s 022 and 072 design best. Fixed voltage operation, turnable and interchangable motors, and even the classic appearance with the lanterns are all factors that make them my choice of tinplate style switch.
My opinion regarding tinplate track is that I prefer the classic look of the Lionel 022 remote switches (O gauge) over their 027 counterparts but prefer the lower profile of the 027 track over the much taller O gauge.
The height of the rails on the ogauge track is so high that from certain low viewing angles it looses any and all resemblence to prototypical railroad trackage.
A couple of things is, price and alot of good used track out there. The K-line switches also run on fix power and has lights.
Oh yeh, you can run some good size engines thru the K-line switches
Like some others here, I, too, prefer O27 tubular track (although I’m using Atlas track almost exclusively these days). I just like the smaller rail profile. I will be using O27 tubular for the Marx all-tinplate layout that I plan to build becauseI want that layout to have a decided toy train look.
On a side note, as evidenced above, the ladies are not the only ones impressed with size of Spankbird’s locomotives.
[:D]
I suppose I may have falsely fallen for that old saying that “it’s not the size of the locomotive that matters.” I love my little K-Line S-2’s, but I gotta say, they bring me little respect.
[:D]
I claim the O27 big-locomotive prize, for running a Rail King Big Boy, a Lionel 2321 Train Master, and a Lionel 773 Hudson through Lionel O27 switches. And the big-car prize, for 15-inch Rail King Superliners, a Lionel 9100 15-inch extruded baggage car, and a Lionel 51600 16-wheel flat car. (Of course, they are all more or less modified.)
My personal preference is for standard O track. Although O27 is closer to scale, I just like the way it looks. I also love O22 switches, especially the ones that I pay $5 each for that work perfectly and look just as good as the $50/set ones with a little work.
If you should go with O, don’t overlook K-line(at least while they’re still around). Some of their sections(such as O72 curves) sell for as much as $2-3 less than a comparable Lionel piece, and the difference really adds up when you’re pricing a layout. They also offer preformed curve sizes up to O120, while Lionel stops at O72. As far as I know, K-line is the only company that makes a 14 1/4" straight section, traditionally known as an “O72 straight” to match the leg of the Lionel O72 switch. This can save you a lot of time cutting fitters, and they’re also perfect for floor layouts where two normal length straights won’t quite fit.
The most important thing, though, is what you like. If you prefer the look of one over the other, than go for it.
As for already having some O27 track, I still have a couple hundred sections of O27 in my closet that get pulled out from time to time. I switched four years ago. Much of my O track is good condition postwar that I pay $.75-1.00 a section for, as well as $5 junk bin switches that work fine. I bought one nice set of postwar O22s for $50, as well as one nice postwar UCS for $10. I picked up a couple more UCSs and O22s in a junkbox that I paid $25 for, and then resold the remaining O27 for a little over $30 on Ebay.
Good Morning Steel Rails,
For what you are doing and what you have planned, using 0-27 track will build you a fine layout. It will be a layout you will enjoy for a long time. You will have alot of fun building it and even more fun running your trains on it. Take care and have a great Tuesday.
Jimmy
I also use O-27 track with O-42,O-54 and some O-72 curves. I have changed all but 4 (hopefully will be replacing these soon) of my Lionel O-27 27" switches over to the low profile K-line O-27 27" switches. They have caused alot less derailments and look a whole lot better. I cut popsicle sticks and painted brown for extra ties and for ballast I mixed dark gray paint with sand texture and just painted it on.
I like the photo of that K-Line turnout. Unfortunately, mine are all Lionel 027 turnouts.
I’ve got a question perhaps you or others might be able to answer, although it should probably be in a separate post. Here goes.
I dislike the buzzing sound of trains running over the turnouts and wi***o make them manual. To make them manual and stop the buzzing, do I just not connect the 3-wired device switch to the turnout?
Also, thinking about removing that big bulky box that houses the magnet things as that gets in the way of some of my longer freight cars.
Has anyone tried this before? I know that question is kinda basic beginner question, but thought I’d ask anyway.
