I recently aquired 2 O Scale locomotives. A Lionel Norfolk Southern C40-8 and A Weaver Pennsylvania 4-8-2 M1a. I am having problems with the operation of both. When I put the Lionel on the track, The locomotive flew so fast that it jumped off the rails. I have a MRC Throttlepack 1301 transformer. The Lionel locomotive can not be controlled by decreasing the throttle or increasing the throttle and only has one speed which is very fast. When I put the Weaver locomotive on the track, the bell rings twice and the lights come on but the locomotive refuses to move whatsoever. I does not even move with a little hand coaxing either. I am thinking that the problem is in the transformer for both locomotives but I can not be sure. Please advise me on what to do about this. This transformer seems to work extremely well with all my other locomotives including my Post War Lionels and my newer MTH NYC 4-6-4 and my MTH C&O 4-8-4 J3a and my Lionel N&W Class J 4-8-4. Thanks.
If your other engines work OK with the transformer, it is probably OK, But I would check the voltage output with your run-away loco on the track just to be sure. Especially check the minimum transformer output voltage with the handle just off the low end stop.
Did you buy both of your new problem locos from the same source? If so, that might mean some odd modification was made to both locos.
Regardless, he laws of physics and electricity still apply and I don’t see how a loco can fly off the track at around 5 or 6 volts input voltage.
Without more details on the locos (age, part numbers, which control system, one has to make a few guesses…
if the Lionel loco has Oddessy control system, the symptom indicates the speed sensor is not working. The speed sensor is typically a magnet flywheel on the can motors with a Hall Effect sensor ( senses rotation as the magnetic field changes on each spin of the magnet). With the Oddessye control set to ON (most locos with O have an ON/OFF switch - except for early O production). So if the sensor is bad (or the support bracket is broken) or (more common) the flywheel/magnet is gone (they have a habit of ‘exploding’ - like a friend’s diesel where fragments of the magnet went through the loco shell), then the loco’s speed control electronics think the motor is turning slow and thus it increases voltage to the can motor thinking it needs to speed up to compensate. Thus (and this is the same for an MTH loco where the speed tape on the flywheel has fallen off or the optical sensor has failed) the loco runs at full internal rectified voltage (Peak half wave rectified 6 vac is 8.5 volts DC to the 12 vdc can motor - so it is spinning pretty fast).
So you could turn the Oddessey OFF (switch on the bottom of the loco - if equipped) and see if it will run normally. No switch then you will have to have it repaired or replace the electronics (and/or flywheel).
The reason there is an Oddessey ON/OFF switch is early Oddessey locos ran erratically in conventional mode, jerking as speed was changed, irritating conventional users - thus the switch.
If the Weaver loco is a QSI sound/control system equipped loco, then the board may be toasted due to the previous owner letting the battery die and trying to run the loco or trying to run the loco on a newer Lionel ‘chopped waveform’ transformer (QSI was only for ‘pure’ sine wave AC transformers). Repair typ requires a reset chip set to repair. There is quite a bit on the Internet on how to
I think you know what I have. My locomotives are A Lionel Norfolk Southern Dash 8 - 40c Mfg # 6-18213 and a Weaver O scale Brass M1a 4-8-2 Mfg # M1a if this helps. Thanks.
The Dash 8 - 40c Mfg # 6-18213 is from 1994 and is conventional electronis E-unit.
The Weaver is from 1990 and if it has not been messed with it features two cab engineer figures, operating headlight and front marker lights, illuminated marker lights and back-up light on the rear of the tender, operating smoke unit with on/off switch, electronic reversing unit with lock-out switch, all metal wheels, axles and gears, sprung drivers, flywheel equipped motor for smooth operation and coasting, operating die-cast metal knuckle coupler on tender, real simulated coal load in tender. 1/4" Scale, overall length is 28", minimum curve is O-72 and it operates on O-gauge, 3-rail track with AC power.
Kevin if my memory is correct, back then the weaver came as you stated or with PS1 in it. If it has PS1 it’s as Roy said, Needs to be reset or possible fried.
The Lionel if someone put TMCC in it that would do that if the R2LC board is either loose and needs to be taken off and put back on or is bad. I had a NYC GP-9 that did that. but I would think it would have to be in a command invirement, but maybe not. Anyway it sure seems something in one of the boards is messed up.
Can you hold the engine in place and hit direction? if so does it go into nuetral?
That still tells me it has something to do with the elctronics, but I do agree with you that if he barely turnned the power up it should slow it down some what anyway. for some reason this engine is set at full throdel so it doesn’t take much to make it go. now how it gets say that much power out of 3 or 4 volts is a good question. but tells me that is why it was sold at a good price, as stated.
I got these trains at an auction. I will check on the PS1 reset kit, however if the board is fried does anyone have any ideas on what to use to replace it with? Any suggestions? Also, a friend told me that it may be stuck in neutral and can’t switch to forward or reverse what would control that?
