Ogden & Cache Valley RR - Layout Construction
Thanks Onewolf. Retirement’s about 4 yrs away for me and my best girl and I have been talking about doing this; thx for the info, and I’m sorry if my question offended.
Dan
As expected this week was not as productive as the week I had off from work. Call it “The Revenge of the Honey-Do” week.
I installed L6-30 receptacles for the two 240v 30AMP circuits that had already been run to the workshop and this allowed me to fire up the 2HP 240v Grizzly dust collectors. I have started building a dust collection system with a vortex chip collector, a duct for my miter saw (which isn’t very effective), and the floor sweeper duct. Next I will add a duct for the table saw.
I rebuilt my benchwork assembly table so it’s taller, more sturdy, and more level. This allows me to produce better open grid benchwork assemblies.
I temporarily mounted some of the old layout benchwork assemblies to the center platform as a proof of concept to see what the three levels (42", 62", 82") sight lines would look like.
I also mounted a scrap piece of 1/8" hardboard to see how the coved corner backdrops for the center platform benchwork would work. It looks like the coved corners will work fine.
I also mounted a piece of scrap 5mm hardwood panel to the upper level benchwork to get a feel for what the ‘wall’ that drops from the ceiling and supports that outside of the upper level would eventually look like. Before the train room was drywalled I installed 2x6 blocking in the ceiling that the ‘walls’ that descend from the ceil
The room is well within NEC requirements for general living space - every 12 feet spacing, not more than 6 feet from any point along a wall to nearest outlet.
3 volt-amps pers square foot - so one 20A circuit can handle all the required outlets for 800 sq ft of space. A 15 amp circuit can handle 600 sq ft. This applies to general living areas, not special requirements of baths, kitchens and other uses.
Based on what I see, his two 20A circuits is well above the requirements of the NEC.
Sheldon
I just added one of these to my Christmas list. [A]
T e d
Continuing to work on the lower level benchwork. Along this wall is where the classification yard will be and the benchwork is 30" deep.
As we turn the corner here we start to get into the area that will contain the locomotive service terminal.
I hope to finish the basic lower level benchwork by the end of next weekend.
AMAZING work, Onewolf!!![Y]
MY entire HOUSE isn’t built THAT well…and if I didn’t do nearly constant upkeep…it wouldn’t last as long as your layout will!![:D]
May your freight ALWAYS roll smoothly…and ON TIME!!
Progress on the layout has been slow but steady.
I have started building the shelf for the 4 track staging (and ‘offsite’ passenger train service facility) that will be located in the model workshop. At some point after the layout benchwork construction is completed I plan to go through the wall on the right and add a return loop in the woodshop/workshop. The return loop will be designed so it can lift up against the wall when it’s not needed.
I wired and installed DPDT switches so the staging track can be selectively powered/controlled either by the ‘main’ layout DCC control or by the Zephyr in the model workshop. I also wired it so the closest track can function as a standalone DCC programming track.
I’m also working out the ‘kinks’ on how I plan to use 5630 SMD LED light strips to light the layout.
The view from the train room looking into the model workshop.
I have completed the lower level basic benchwork. I will be installing 5/8" plywood and 1/2" homasote in the yard and engine terminal areas and 5/8" plywood and 1" Foamular 150 (pink) ridgid foam in some of the other areas before I start to lay track.
The aisles seem nice and wide. Hopefully they will still seem nice and wide if/when I host operating sessions. :slight_smile:
I mounted some supports and a piece of 1 1/2" right angle steel bracket across the aisle to simul
Incredible.
I have some questions about the carpet squares.
Did they come with any sort of padding backing?
If not, did you put any padding down?
What did you use to attach the squares to the concrete floor?
I’m wondering about moisture and bare concrete floor with carpet directly on it.
Thanks
I am starting to work on the helix and upper return loop support structure.The helix will be double track with 37.5" and 40" radius tracks and will connect the lower level at 42" elevation to the middle level at 62" elevation. The helix will have 4.5 revolutions to climb the 20" elevation change. The upper level return loop will be at 82" elevation.
I wasn’t sure exactly how I was going to build the support structure for the helix, but so far I’m happy with how it has turned out. I knew it was going to be one of the major challenges of converting a ‘digital’ plan into a real world structure that must deal with real world laws of physics, ‘non perfect’ lumber, and my general framing/construction ignorance. :slight_smile:
The helix will have 4" rail to rail elevation rise per revolution. There is 6’ 4.5" head room under the 2x6 support beams across the top of the helix structure.
The 2x4s that are mounted to the vertical columns will support a 3/4" plywood base that will in turn support the helix. The compound miter saw got a major workout figuring out all the odd cuts required to assemble the structure.
The eight vertical support columns are lag bolted to the slab.
The 3/4" plywood helix support base is perfectly level even though the slab is not. This was one of the engineering challenges. I will use a multitude of different height riser blocks to provide the correct slope for the first revolution of the hel
Is it done yet? Is it done yet?
Can I come over and play with your trains?
How about your stuffed leopard?
ROAR
It will be done tomorrow. And it’s not a leopard, it’s a Cheeto. I mean Cheetah. Chester the Cheetah.
Onewolf:
If you have not thought of this, it might be a lot easier to add track to each circle of the helix before adding the next. Four inches isn’t much room to get hands into.
Dave
Thats how I built mine. Complete with signals in the helix. Gotta let that rail cam look at something., eh.
ROAR
I guess we could call it “Pulling a Hediger” since as Jim Hediger has related in several places, as one of the first to go double deck, he spent all day getting his helix built just right, and then his friend who was helping said “Sure looks nice, but how are we going to get the track in there?” so they had to tear it apart and put it back together, this time putting the track in as they went.
I definitely plan to lay and wire the track on the helix as I build the helix. That’s how I built the (much smaller) helix on the previous layout.
The carpet tiles have a thin pad sort of backing. I did not install any padding under the carpet tiles. I chose to not affix the carpet tiles with glue or double sided tape and so far that has worked out great. I have no problems with the tiles lifting/moving even when I roll around on my rolling chair.
I applied sealer/densifier to the concrete slab but I don’t think I will ever have a moisture issue with the slab (barring some sort of plumbing disaster).
I’m curious about this helix. What was the radius/grade? What kind of trains did you run up it? Ever have any stringlining?
The helix on the previous layout was 24" radius with 4" rail-head to rail-head separation. The grade was about 2.6%. I mostly ran 50ft rolling stock, but large articulated steam locos and 85 ft passenger cars could traverse the helix ok (but just barely). I only ran about 8 ft long trains and stringlining was not a problem. It was built with two overlapping layers of 1/4" luan plywood.
Nice, Onewolf, nice…
Thanks for sharing your progress and your fantastic work…
I used 3rdPlanit CAD software to try to figure out the optimal plywood cuts for the helix. The helix will be constructed with two overlapping layers of 15/32" sanded plywood and it will be 4.5 revolutions long. The left option would take 36 1/4 arc segments and require eight 4x8 sheets of plywood. The middle option will require 24 1/4 arc segments and 16 1/5 arc segments and it would require six plywood sheets. The far right option (1/3 arcs) will require 27 1/3 arc segments and nine plywood sheets (and waste the most plywood).
