Old Champ decals
Hi all, I have some old (like about 20 years or so) Champ decals mainly for number boards wcih I would like to use for some updates I have done. Trouble is the first few I did seemed to dissolve in water! Is there a way of retrieving decals such as painting them with a solution first? I thought I had read about this some time ago.
Alternatively, I thought about using a laser printer and printing number boards on A4 paper and gluing them on in F7 number boards in particular. Has anyone reading this actually done it?
Regards from Down Under
Trevor www.xdford.digitalzones.com FYI
I print my own decals, including number boards, on Air Mail paper. I then cut them to size and apply them to the models using a little white glue and a pair of tweezers.
Microscale makes Liquid Decal Film - 460-117 for just such purposes.
Hi Jeff, Do you print heralds as well for say boxcars using that method? I had not thought of airmail paper etc but it is extremely logical and for number boards ideal… thanks for that!
I followed your links on the page but came up with a forum… Is that what was intended?
Kind Regards from Down Under
Trevor
HI Jso, That stuff is getting harder to get here in Australia! There is a local similar stuff but I am probably not very good with my decalling anyway!
Cheers
Trevor
I print heralds, roadnames, number boards, etc. I print 98% of the decal stock I use. Very rarely do I purchase a pre-printed decal. And yes, the link does go to a forum. There’s a lot of helpful advice there.
I remeber reading somewhere that you can spray them with Tester’s Gloss coat It sounds like it might work but I have never tryed it…Cox 47
If you have a photo quality printer, you may want to consider using Permium Glossy Photo Paper. You will get a lot sharper detail than with printer paper, but it will be thicker. The back can be sanded down to reduce the thickness.
