I’ve tried about 10 service centers and Ebay with no luck.
I need a couple lenses, preferably like 3 or 4. One is for a 2037 and the other is a 2035. i believe they are the same.
Need 2, but if they are this hard to get, I might as well get extra to have on hand.
Any help is greatly appreciated.
I am gonna attempt to use a 3mm LED in place of the old incandescents. I just need the lenses now.
heres info that a lot of us in here use it jeff@ttender.com or his web site www.ttender.com or his phone number which he prefers 585-229-2050
I can’t believe no one has these. These are the most common headlight lens for the postwar engines.
Here is the part number for them # 1666e-20.
Maybe they were just too lazy to look up the correct part for you.
Jeff has these in stock and they are about .50 cents each.
If you’re going to use an LED, don’t bother with replacing the lens. Just use a 5-millimeter LED in the headlight hole. Cut off some of the hemispherical tip, shape the end to a more-realistic bulge, and polish it with toothpaste.
