On30 Engine sizes
Being very short on space, more so than I ussually am for a layout, I found myself counting 1/4’s of an inch trying to get as much height as possible in the shortest distance.
Then like a genius I realized I DIDN"T HAVE A CLUE HOW BIG THE ENGINES WERE<<<< AAAAARRRRGGGGHHHHHHH
sigh
Oh well. So I did some research and although I could only find Bachman I at least found something and I thought I would share it with you guys.
I needed the height but I included what I found.
Bachmann North Pole Express E-Z Mate Set On30
SPECS: Scale: On30
Steam Locomotive Size - Tender Size -
Length: 7" (182mm) Length: 4-7/8" (128mm)
Width: 1-7/8" (50mm) Width: 1-3/4" (45mm)
Height: 2-1/2" (65mm)
Bachmann Jingle Bell Express Set ON30
SPECS: Scale: On30 (1:48)
Locomotive Size -
Length: 7-1/8" (182mm)
Width: 2" (51mm)
Height: 3-3/8" (85mm)
Bachmann Spectrum 2-Trk Shay On30
SPECS: Length: 7" (17.8cm)
Width: 1-7/8" (5.6cm)
Height: 2-5/8" (6.7cm)
Scale: On30 1/48
Bachman Spectrum Class A Two-Cylinder T-Boiler, Two-Truck Shay Loco
SPECS: Scale: On30 (O = 1:48; HO = 1:87)
Length: 7" (17.8cm)
Width: 1-7/8" (4.7cm)
Height: 3" (7.6cm)
Bachmann Spectrum 28T Climax On30
SPECS: Scale: O (1:48)
Width: 2" (51mm)
Height: 3" (76mm)
Bachmann Spectrum 0-4-0 Porter On30
SPECS: Scale: O/On30 1:48
Length: 3-7/8" (9.8cm)
Width: 1-1/2" (3.8cm)
Height: 2-3/8" (6cm)
Bachmann Spectrum 0-4-0 Porter Pennsylvania Railroad On30
SPEC
Thank you very much. I did find it useful indeed when planning my universal HO gauge freelanced layout. Jingle Bell express is tall on indeed. Was it this kind of locomotive? https://www.ebay.com/c/8011380107 Apparently now Bachmann makes Northern Lights and Yuletide express, slightly renamed but it makes sense to use same mold for locomotives. Freelancing pan-HO gauge is for research reasons when finding the compromise of 1:80 scale done by Japanese model train company tomix to run models on the same track whereas prototypes use a different gauge. So for HO gauge I have standard HO which encompasses also a Russian 5ft gauge due to negligible gauge difference; [my creation] of P scale (3mm to foot or 1:101.6) for Indian Portland broad gauge; famous On30 but can also encompass prototypes from European industrial 750mm (29.5") gauge, and the new one - Sn42 (Japanese narrow Cape gauge) in 1:64 scale which would make for a correct scaling of trains to run on HO track, also encompassing AustroHungarian metre gauge.
