I have two of the brilliant spectrum 2-8-0’s - one is sidelined to be converted to a Cuban Sugar Cane loco, the other is screaming out for something else to be done with it?
Anyone else had a bash and modifing the On30 2-8-0s, and if so, would you mind posting some photographs for a bit of inspiration!?!
Stephen, I haven’t started work on it yet, but I’m intending to modify mine to represent an engine of the FCAntofagasta-Bolivia. I’ll post some photos when I get going. Cheers, Mark.
Sounds interesting - is there going to be a lot of work to be undertaken to convert to the desired locomotive?
I think my conversion will be based around one of the 2-8-0’s at Rafael Freyre - seeing as they have pretty much the same boiler dome formation as the model, so I will not have to cut the boiler around too much. I think the biggest jobs for me will be cutting the cab about a bit, a new chimney, new oil tank for the tender and of course the RF paint-job and weathering. Depending on how (and when) it all goes, I would like to perhapse then have a go at a Mal Tiempo version with two tenders!
G’day, Stephen, How much work will depend on which version I decide I want. Some of the later FCAB engines were quite similar in appearance to the model and need little change. But the earlier engines had either typical Baldwin wood cabs or steel-sheathed versions of the wood cabs, quite different tenders with fireman’s shelters, Stephenson valve gear, box-shaped oil headlights, and peculiar saddle-shaped sandboxes that wrapped around the front course of the boiler. They also had the compressor and air reservoirs mounted in a different location to the model. I’ve even seen a photo of one engine with the reservoirs mounted across the top of the boiler, C&S style. I’ve posted a link to a photo of FCAB No.79 here. Sorry to say you’ll have to cut and paste this - I use a “non-compliant” browser. :-
I think I’ll probably do the early version. It’s more work, but the end result is a much more individual looking loco. A friend and I are working on a simple exhibition layout to run this and other South American engines on. We think it will be a bit different, and hopefully eye-catching!
Sounds good to me. I’ve always had a soft spot for the RF engines, to me they are the classic Cuban narrow gauge power.
These 2-8-0’s are making my life miserable!!! I want one so bad but do I want to do On30? I can make a plausible line in On30 of my home area ( what I want to do in HO) but I dont know if I have space.
Love the old time engines and HO really doesnt have what I am looking for ( you know RTR and cheap) so who knows
I used to model in HO and OO, and after purchasing one fo the 2-8-0’s I have not looked back. They are just so well made and perform faultlessly. The detail is second to none and the haulage capability is astounding.
If I could justify purchasinf more, Iwould love to have a fleet of these beasts all done up like Cuban prototypes, but until my layout is built I need to keep things in perspective.
The two I have are permanently on display though - even the ex-misses was impressed with the detail…can’t say much more than that!
