I currently have a switching layout that will eventually be plugged into a larger around the room layout as a peninsula. At this point, I control the Tortoise turnout motors from one side of the layout with DPDT toggle switches connected to bi-color LEDs. However, I would like to be able to control the turnouts from both sides of the peninsula. How do I do this?
Can I continue to use DPDT toggle switches or do I have to use momentary DPDT ON-OFF-ON toggle switches on both sides of the layout? Do I have to use push and release momentary button switches? Will Tortoises work with momentary switches? Can I wire the bi-color LEDs to operate correctly using two switches? Can one of you kindly point out any drawing for this kind of situation?
Keep in mind I might have a PhD, but I am not an electrician, so you have to explain this to me in simple terms. Any help is appreciated.
Try here: https://model-railroad-hobbyist.com/node/16272 Maybe of some help.
The way that you have already wired the Tortoise is sufficient to control it from both sides of the layout by simply adding a second DPDT toggle switch. You do not need to change over to momentary switches.
Let me find a wiring schematic that I drew up for myself, and I will post it.
Yes, I’ve done this at several places around my layout.
Any number of Double-pole, Double-throw switches in series with the DC supply to the Tortoise will reverse the polarity at the 1 and 8 terminals. You can have a hundred if you wanted to.
No reason at all to use momentary or center-off switches.
I usually have my toggles arranged so that when the lever is in the down position the track is routed to the “normal” route through the turnout.
To remind operators that the specific turnout is controlled from multiple points I have the toggle set to flip side-to-side.
I use LEDs in series with one wire going to the Tortoise. To get a remote LED you will have to run an additional pair of wires back to the location of the remote toggle. I use cheap, flexible 22 ga. four conductor telephone wire. Gives me a pair for the Tortoise and a pair for the LED.
Some operators get fancy and use a key switch at the remote location in order to have “authority” over the dispatcher to operate the turnout. That is an option if you really want to get into rule-book operations.
Hope that helps, Ed
I use a latching relay to accomplish this. Here is the basic diagram. I actually ended up making a circuit board so that I could mount it directly on the tortoise machine using a edge connector.
I got the idea from this gentlemen’s website.http://www.lkorailroad.com/tortoise-printed-circuit-boards/
Here is the link to relay I use. https://www.digikey.com/short/zp0j8b
Basic idea is that the pushbuttons activate the relay. Since it is a latching relay, when you let go of the pushbutton it stays in the position that it was set as. When you push the other button it set it the other direction. The nice part about this is you can have multiple inputs (different control panels).
Interal to the relay its pretty much a DPDT switch and wired the same way. The center poles of the switch go to tortoise/LED’s and the outer ones are crossed over.
I hope this helps.
Here is a simple wiring diagram:
BUT, if you want/need to know which way the switch actually is at both locations becasue you likely cannot see the track from both locations, you need lights or you need to use the pushbutton circuit above, or a similar circuit using two non latching relays.
This circuit uses two non latching relays and normally open pushbuttons which can be lighted to show turnout position. You can have as many locations as you desire.
I use this and similar circuits to control all my CTC/mainline turnouts from both the CTC panel and local tower panels.
The lighted pushbuttons are in the track diagram so they actually show light up the selected route on the “map”.
Sheldon
Sheldon, based upon the OP’s initial statements, I suspect that you are going to have to simplify this schematic somewhat, as I did.
Well, if the OP is interested, I can provide additional help. But I don’t have a library of drawings already drawn showing the physical layout of the devices and point to point wiring.
And I don’t have any photos that would provide any more clear explaination.
Ladder diagrams like this have been the standard of relay logic control diagrams for 100 years. The symbols are not that hard to understand.
A circle labled R1 or R2 is the relay coil. Two lines creating a gap in the wire is a normally open contact, labeled to match its coil. A slash across that contact symbol indicates a normally closed contact. A break in the wire, with two dots, and the upside down “T”, is a normally open push button. The smaller circles labeled “LED” are, LED lamps.
Again, the circuit is similar to the latching relay circuit also offered, and provides the same function.
Sheldon
I believe the OP said he has LEDs in series with the Tortoise.
I use bi-color LEDs red/green for the main or red/yellow for secondary routes. Plain and simple, in series with either wire going to the Tortoise. If the indication is not right, flip the LED 180°.
This is the main panel at the East-end of Hickam Siding:
Hickam Siding by Edmund, on Flickr
This is one of my remote panels at the West end of Hickam Siding:
IF the operator at the East-end dispatchers panel flips HIS toggle the indicator lights on this west panel reflect that change — and vice-versa.
(digital cameras don’t like LED colors too well)
[url=https://flic.kr/p/2iScCcA][img]https:
[quote user=“gmpullman”]
ATLANTIC CENTRAL
from the MRH thread
I normally prefer toggle control to DCC control of turnouts, but if you really need to control turnout position from multiple points, DCC will do the job.
Well, I know several modelers who built big layouts and connected all their switch machines to DCC and had mixed feelings about it later.
I would rather not push five buttons to throw one switch. I will stick with my approach that lets me throw multiple switches from multiple locations with one button.
Sheldon
I believe that if a device like the NCE SwitchIt is used to throw the Tortise machines, they have a provision where a single normally open push button can be used to activate the Tortise. I see no reason why any number of normally open push buttons in parallel can’t be used and eliminate all that relay stuff.
so you’d replace a single relay with a circuit board?
from Renegade
Well, a NCE Switchit costs $35 retail, $30 street price and does two turnouts/routes, two inputs/outputs.
While a single turnout does requires me to use two relays, any expansion into a more complex interlocking (even a simple crossover) only requires me to use one relay per route, which averages one relay per turnout.
My relays cost a maximum of $2 each.
I don’t use DCC and therefor don’t need or want the DCC part of the Switchit.
To provide indicator lights, the Switchit actually requires MORE wiring running around the layout than my relay circuit.
And my relays also provide extra contacts used for signal system interlocking logic, and frog power.
So, between $2 and $4 vs $15 per route, and LESS long runs of wiring, I think I will stay with the “relay stuff” rather than spend 5 times as much…
Sheldon
If you want solid state, Rob Paisley has a circuit with a 556 time IC, 1 capacitor, and 2 resistors that will use pushbutton inputs to drive the Tortoise. Multiple sets of pushbuttons can be used. The whole thing, minus the buttons, will cost under $1 in parts.
Dunno. I find all of this talk confusing, and unnecessary, about latching relays, relay coils, Switch-Its, and momentary pushbuttons. And, I suspect that the OP will too.
Operating a Tortoise from two locations is no different in principle than a 3-way switch in household wiring to control a ceiling light from two locations. Being anal, I like all of my wall switches to be toggle (or rocker) down when OFF and up when ON. That’s fine for single pole switches, but doesn’t always apply to 3-way switches. If I turn the wall switch ON from one location and then OFF from the other location, one toggle will now be up and one toggle will be down. No problem with that because you can see if the ceiling light is ON or OFF.
The same will be true on a layout if the protocol is, say, toggle down for a straight through route and toggle up for a divergent route. But, I agree that you may not be able to visually confirm the route, so you need indicator lights.
Using the wiring diagram that I drew earlier, I have added bi-polar LEDs at each DPDT location and wired the LEDs to the power tabs on the Tortoise. The LEDs at each DPDT location will be green for a straight through route and red for a divergent route regardless of the up or down position of the toggle on either DPDT.
I tested this arrangement on the workbench and it works just fine.
Yes, I would. I have DCC and I’m using the SwitchIt anyway. Plus it is something that I understand. Or maybe I should say I don’t need to understand it to get it to work.
in addition, time is money. I don’t have to build it.
