Outside-Frame Standard Gauge Locomotives
Hello everyone I’ve gotten into the habit of modelling some strange steam locomotive prototypes and was wondering if anyone was aware of any standard gauge north american outside-frame locomotives. So far I’ve only had luck with finding narrow gauge locomotives with outside frames such as the ones that served the Oahu Railway and Land Company, Deadwood Central Railroad, and the D&RGW. Although I have been able to find a few British standard gauge locomotives with outside frames and inside cylinders with several railways operating a variety of different classes of locomotives with these characteristics like the GWR, Midland Railway, and Rhymney Railway. I hoping someone here more knowledgeable than I am would be able to point me in the right direction. Thank you and all the best.
I can’t think of any, might have been a few in the 19th century? Generally ones I’ve seen are in effect standard gauge designs adjusted to outside frame so they could run on narrow gauge track. In the UK inside cylinders were more common so would make sense they would have some standard gauge engines with the outside frames.
Outside frames were already obsolescent by the time of standardization of the American type into inside Stephenson, outside valves and rods, and division of the frame into front and rear sections for maintenance.
By the time of cast bar frames and then cast engine beds, the necessary thrust was in excess of practical outside cross-bracing, even with Woodard’s ‘central machinery support’ cylinder location and mains ‘inside’ tandem side rods. You see outside cast frames a lot with motor drive (as in the GG1 or those GE Steamotive turbines of 1938) and of course the B&O constant-torque W-1 would have had them, but the transition to driver roller bearings in cannon boxes, and effective lateral-motion bearing on hub liners really required ‘inside frames’ to work right.
Closest thing to an ‘outside’ frame might be the Timken bearings applied to the early N&W A 2-6-6-4s. You almost need a 3D model to figure out how these worked: the actual roller bearings were outboard of the frame, actually inside the rim of the driver, in an assembly cross-reinforced by a hollow tube; the drivers were joined (and kept quartered and parallel) by a heavy axle which did no supporting of the frame at all. This got around the large openings in the frame that would be needed for roller-bearing boxes in the usual place…
I’ve seen photographs from what’s been called the “Pioneer Era” of American railroads of locomotives with outside frames but as Overmod said by the time the 4-4-0 American type of locomotive was pretty much standardized the outside frame was obsolete. Some hung on through the Civil War period but were certainly retired by the 1870s.
I know this is a rather late reply but thank you for the help.
A recent post in a 19th-Century railroad Facebook group had an interesting M&StP ;business car’ which was being pulled by 4-2-2 locomotive ‘Messenger’ (with outside frames, inside cylinders, and traction increaser. (The tender had been removed and fuel and water were carried on the car!)
This picture had to date between 1863 (when the M&StL was established as such) and 1874 (when it became the CM&StP) – predecessor railroads go back into the late 1840s, and the locomotive looks as if it is from no later than the early 1850s,
The Shaw locomotive had an outside frame between the cranks, but I thought it also had inside framing. Someone should check Development of the Locomotive Engine and some of the contemporary descriptions of the engine in the trade press to be sure.
When I was 15 or so, I worked up a high-speed locomotive design that reinvented the Shaw locomotive as a simple eight-cylinder design: with zero overbalance: two cylinders arranged as on a type-1 Vauclain compound ‘inside’ and two more ‘outside’ 180 degrees acting 180 degrees apart. Rods were thin-section (and you can imagine the fun involved in dropping a main driver). At the time, I was pretty sure that you’d need zero overbalance coupled with very compliant guiding to reach over 150mph safely with reciprocating steam, and this was a way short of individual-axle motor drive to provide that.
Yes, if you thought the T1 engine beds were a foundry achievement, the ones for this locomotive would have been a foundry miracle. And no, they weren’t better than Ingalls-style diesels for comparable high-speed passenger work…
