Paint Stripper recommendations, please...?
Hi, Guys!
I recently acquired a Stewart RS-3 kit, and have been trying to remove the factory paint job so I can paint and decal it for the Flint Hills Northern. In my 55+ years of model railroading I have never come across a paint as tough to remove as this stuff. I started out with isopropyl alcohol - 2 days soaking - didn’t touch it. Though I was leery of using it on this plastic, I next tried DOT3 brake fluid. After 14 hours of soaking, the lettering came off, and the base coat had softened slightly, but not enough to completely remove.
Is there a powerful paint stripper out there that is safe for plastics? Chameleon, ELO, or something similar? I want to get it down to bare plastic…
Try Scale coat’s Washaway. I’ve used it on tough paints on plastics that nothing else would work on. Stripped them down fast.
The Chameleon stripper works really well for plastics but I am fairly sure that it is no longer available.
I think that the next stripper in line with what you have already tried may be the Citrus stripper that you can buy from Wal-Mart. I am not certain if it is safe for plastics, but it is not a strong paint stripper. I would advise if you try it, test it on an old plastic model first.
Others should chime in shortly.
I’m afraid that all the really good strippers are extremely hazardous and are no long sold.
I personally, have great success with ELO, but if your paint is impervious to brake fluid, I’m not sure you’ll have any luck with ELO either.
Use ELO or Wash Away - like others have mentioned, Chameleon does not seen to be available anymore. I still have a couple bottles left, but will need to look at Wash Away after that is gone.
Brake fluid is the worst for plastic - it sucks the oils out of the plastic and makes it very brittle.
Jim
try 99% alcohol. rambo1
Thanks, Jim. However, I’ve not found brake fluid to be that bad. From what I hear, the only plastic that it really affects badly is the plastic used by Kato. I don’t have any Kato products, so it’s not been an issue with me. And I strip a LOT of models, since I need to repaint most of them - especially locomotives. I’ll have to look into the Wash Away…
Thanks again…
The plastic in Kato engines really gets affected by brake fluid. Athearn shells seem to fare better. The ‘leach-out’ of the oils in the plastic can be seen by the white residue/dust that sometimes appears. With Kato shells going for $35 and up, using Wash Away is a no-brainer.
To be quite honest, I have not done a lot of stripping loco shells for a number of years. The plethora of correctly painted models has resulted in adding road specific details and minor paint touch-ups. The major kit-bashing/painting/decaling/weathering has really slowed down(at least for me). I have even converted to acrylic air brush paints unless the only correct color is a solvent based paint. I have some BNSF GP38/39 engines that still need ditch lights(if DW ever gets them out again), but the paint jobs are quite good. I enjoy adding the engine specific details(like the ex-ATSF roof top details).
I do have some freight car projects that will involve entire rebuilding/metal stirrup steps/grabs/details and of course painting/lettering. It’s not like the 70/80’s where everything was a complete bottom to top project!
Jim
Believe me, Jim, if I could get locos painted in FHN colors, I’d grab 'em in a heartbeat. However, since it’s a freelance road, I’m pretty well stuck. And I have already initiated inquiries at my LHS for Wash Away.
Athearn, Rivarossi (AHM) MDC and others are very tolerant of DOT3 brake fluid. The new DOT-4 stuff, however, is deadly, from what I’ve heard and read…
Thanks to all who replied - I have obtained and tested the Scalecoat II Wash Away, and it looks like it’ll do the trick. I learn more from these forums than from anywhere else, and it goes to show you’re never too old to learn. [:D]
Been there recently with an old swap meet shell. Get Super Clean in a purple bottle at Walmart. I get the gallon size (purple bottle), but a smaller spray bottle is also available. This stuff you use by soaking the shell for 24 hrs, although it works quicker usually. I then scrub crevices with a toothbrush, although a recent suggestion on this forum is to also use a toothbrush where the bristles are cut down to make it stiffer as a scrubbing tool. I wear household cleaning gloves when handling the already soaked shell and scrub into the continer, to rewet areas where needed. I recommend this specifically if you did not get results from a 91% alcohol soak bath and still have the paint untouched or unaffected. Cedarwoodron
