Any color suggestions for painting this large nearly built kit: https://www.walthers.com/valley-cement-plant-kit ? I’ve seen some great work using one color for all the structures; some also have used different colors too. Using a spray can of dull gray is one option. Given the large size, should I use a spray can over a brush since I don’t have an air brush? If using a spray can, how to avoid the buildings from sticking to the paper unerneath to catch excess paint?
I plan to cover the windows and masking certain areas (iff needed).
Many of the discount stores or even a grocery store will have bamboo skewers in several lengths. These things are handy for lots of Model RR tasks.
Lay them out so your parts rest on them. They will keep the paint from sticking. I use them to slip truck frames onto for painting, too.
As for “rattle can” painting, I would suggest Rustoleum Camouflage Khaki color as the base concrete color, then very light mists of a light gray primer over this.
Primers vary considerably. I like the way Krylon sprays but their gray is a quite dark shade. There is a WalMart brand that is a nice, light gray called Home Shades, SKU 20066 21350 that I like. Rustoleum primers are heavy bodied and go on thick, IMHO.
Additional streaks and fading/weathering can be done with weathering powders, Pan Pastel type and a fine sponge or make up brush.
For the corrugated metal, you can choose just about any color but if you want to represent a bare galvanized look I like Rustoleum Metallic Matte Nickel, 7277830.
Because I do any spray painting outside, or in the garage, I usually double over strips of painters tape, sick them to pieces of cardboard, and/or the cardboard flats that 12 packs come in, stick the parts to the tape, and then paint. With the parts tapped to the cardboard, you can hold on to it and move it around, if needed, while you paint, and the part stays secure to the cardboard.
It’s kind of a pain in the winter, but as soon as I’m done spraying, I get the stuff back inside. My work area is in the basement, so I do not use spray cans inside.
Ed’s idea sounds good, too, with the skewers.
I don’t think you’ll be putting on such a heavy coat that would cause the panels to stick that bad.
As far as weathering techniques, I do pretty much what Ed suggest, along with dry brushing.
The Rust-Oleum textured spray paints come in a variety of colors. They produce a rough surface, which I like because it scatters light rather than reflecting it.
I would paint the metal parts rattle can silver. Then dullcoat or rattle can matte finish to cut down the sheen.
Thinly brush on streams of reddish brown and also dark gray to represent weathering that gathers in the ribs. Using mineral spritis to thin a pallet of paint to water colors consistency is all it takes really. Mix the colors right on a piece of scrap cardboard as you go. Some will have more red than brown, and might tend to mix themselves again right on the building, which helps to vary the weathered look.
The concrete buildings can be painted a biege/gray mix. Krylon and Rustoleum used to have a color called Putty that looked like concrete, IMO. They should still have something similar.
I would sort the parts and paint them right on the sprues before assembly, making sure that I then lightly sanded the edges that were to be glued in order for the glue to bond to the plastic. (do the weathering part after assembly)
That is also the method I use for small parts, Mike. I “presumed” he was refering to the large wall and structure assemblies that wouldn’t have a tendency to blow away from the nozzle blast. That’s why I suggested the skewer sticks.
One thing to remember abour silver is how it can craze plastic and ruin the surface. It doesn’t happen every time, but the lack of predictability encourages me to take precautions. I apply a base coat of gray primer first, and spray the silver on after that dries. That’s been 100% effective in preventing crazing.
I have a large cement plant with various kitbashed and scratchbuilt structures. All of the major painting was done with spray cans. Some of it was a color called “Stone Gray” from the craft store (I forget the brand). When that ran out I switched to Testors “Camouflage Gray,” which makes a nice brownish gray concrete color.
Most of the parts intended to represent metal were painted with a Krylon almond color. It was satin or semi-gloss, which didn’t matter after flat finish was applied using Treehouse Studio acrylic flat from Hobby Lobby.
I touched up the railings with some safety yellow from acrylic craft paint.
Weathering was accomplished with acrylic washes and pastels, including the banding effect for the slip formed concrete on the silos.
Cool, this post brought out pics from Rob Spangler, as we all enjoy what Dr. Wayne shows, and I love it when you post pics, Rob. Between you two guys, is the realism I aim for.
Great suggestions everyone! The photos posted are top-shelf. They provide one fantastic method of achieving fanstic results. I have Rust-oleum Granite satin spray paint. It’s item #249078. Would that suffice this structure or is the sheen too shiny?
I have some of that, too. In my opinion it is way too dark. It looks like freshly rolled steel plate color. Under our model lighting you want to lean toward lighter shades.
Spray a sample and place it where your cement plant will be and see how it looks. I’ll bet the Granite Gray might be good for the calciner tube, though.
I put this plant in place over ten years ago and kind-of forgot about it [:$] Now that I look at the photos I believe I’ll have to dust the silos with a little light gray Pan Pastel to tone down the tan color a bit. Pretty sure I used Polly Scale Aged Concrete. IIRC the blue/teal of the metal sheds is GN Big Sky Blue with some gray added to it.
Sheen makes no difference if the color is what you want. I used a semi-gloss for part of my cement plant too, but you can’t tell because of the flat acrylic overspray.
The late Art Curren would kill the inherent plastic shine, which allowed him to use the originals cast in colors, and give a better surface “tooth” for painting if he did paint, by scrubbing the plastic parts with a toothbrush and an abrasive cleanser such as Comet or Ajax or Old Dutch Cleanser.
I am leary about some of the textured spray paints that are out there - sometimes they look good to the eye but not so good in photography, plus the nozzles are more prone to clog.
The MR staff seems to be using the Rustoleum 2X Painter’s Touch rattle cans for primers more and more. This might be a good use for the Ace Hardware coupons they send since Michaels and Hobby Lobby (with their 40% and 50% coupons) don’t carry the line, at least not the ones near me. That is where I get my DullCote however.
kasskaboose
What I found that works is craft white paint with a few drops of gray mixed together. The result is an off-white look. I need to get more craft paint but like the first coat. Interesting to note that some of the buildings look slightly different, which is quite common in a large facility.
Whatever color you pick, it seems that avoiding dark and bold colors makes sense.
The Rust-Oleum sprays have varying textures. The black speckled-and-textured spray has a coarse texture, while cans like “sand” have the finer texture more suitable for structure walls. I like the black stuff for simulating asphalt roofs.
For GERN Industries, I mixed the colour using Pollyscale Reefer White with some Pollyscale brown (don’t recall which one) and some yellow, too. I didn’t keep track of the proportions, either, since the plant was meant to look as if it weren’t all built at the same time. I think that I had two or three bottles of the stuff, all slightly different, as there’s lots of places to use a “concrete” colour on many layouts. As the paint was used-up, I simply added the remnants to one of the other bottles…
Another thing to keep in mind is that some concrete structures did, over time, get painted - I recall some curtain-wall type buildings where the concrete portions were definitely not bare concrete. Most of them, unfortunately, have been torn down.
I used a similar colour for the station in Dunnville, even though it’s meant to represent one clad in ashlar. Depending on where the limestone is quarried, though, the colour will vary, and I liked the warmer tones as opposed to grey…
…the scribed-in “mortar joints” don’t show all that well in the photo, but those were usually quite narrow on the real ones, too.
I’m not sure, but I think that this one was probably done with Pollyscale’s “Aged Concrete”, likely with dollops of a couple other colours added…brown and/or yellow, perhaps…
This one is also a custom-mixed colour, starting with Reefer White. When first painted it had a distinct greenish cast (who’da thunk adding green to the mix would make it look green
Those additions you see in the photo are more for grain use than cement, but at the time, late 1990s, that’s all there was. What you see in the photo is the Grain Surge Bin 933-2935 and parts of the Grain Leg 933-2936.
Since then there has been several kits useful for aggregate transport and storage.
[:^)]This is a silo complex I built years ago, and I left it the color it came in. I have decided to seal the longitudinal crack and paint it concrete this weekend. I’ll take aother picture when I am finished to see the difference.
