Pastel chalk weathering and Dull Coat?
I have had the colors vanish problem like the rest of you when overspraying with DullCote. Quite by accident (I ran out of DullCote) I used my wife’s hair spray. Much better. The spray I use is Aqua Net, but I hardly think it matters. The best part of this is that the hair spray is water soluble. You don’t like the way the weathering turns out, wa***he car in warm, soapy water. Everything goes away and you can do it again. I have tried art fixative and find the hair spray works just as well and smells 1000% better. Just my two cents worth.
I just watched the newest episode of Rehab My Railroad and David had this problem. If you are weathering and you are using pastels don’t use dull coat until after the base layer is dry. What David did was he painted the road with Apple Barrel Black Asphalt and placed the pastels on top of it while it was still wet. This is where he made his mistake powdered pastels and water based paint can desolve if sprayed with dull coat because dull coat contains solvent and any powder or water based paint can disappear if you spray dull coat on it. Pan pastels contain a binding agent and acrilics if you spray dull coat on them they will stick and stay there. So for weathering if you are using pastels and water based paint don’t use dull coat it will destroy it use pan pastels and oil paints.
I want to know if anyone tried the fixative?
I recall reading that chalk weathering tends to fade or disappear if oversprayed with clear finishes, such as Dullcote.
However, I’ve used oil-based pastels (they come in stick-form, and are wrapped in paper, much like crayons). I use mostly earth tones, along with black, white, and grey and rub them over fairly coarse sandpaper, then dump the resultant dust into small open containers, each colour separate from the others.
Next, I use a suitable brush (nothing high quality…old worn-down ones work fine) to apply the various colours, in-turn, to achieve whatever effect I have in mind. Missteps can sometimes be wiped-off, but soapy water might work better in some cases.
While a clear finish can be added, I’ve never bothered, as the pastels tend to not come off if items are handled carefully.
While I do weather pretty-well all rolling stock and locomotives, most are done with a fairly light touch, and I probably do more weathering with an airbrush than with pastels.
Obody mentioned AIM. Or pigment powders from AK interactive and Vallejo. All of which hold well when over coated. I have good success with them and have stopped using chalks all together
shane
I haven’t used chalks in years and pastels I’d liked years ago but haven’t used those in a long time. When I discovered Monroe Models weathering powders, I had no interest in pastels or chalks. I’m sure other weathering powders are great, but I’ve not used them. The Monroe models powders do self adhere and I think do well in that regard, but flat clear coat before is a must, and afterwards certainly would help keep the weathering work from being worn off from handling. I also like weathering with washes and dry-brushing. I haven’t tried much weathering with an airbrush yet though I’d like too.
Alvie
Anyone interested in fixitives might want to read the Fixative Shootout at TrainOrders: Parts 1, 2 and 3
https://www.trainorders.com/discussion/read.php?3,5069479
https://www.trainorders.com/discussion/read.php?3,5086356,5087648#msg-5087648
https://www.trainorders.com/discussion/read.php?3,5116682
