Hey Guys, likely this has been addressed elsewhere, but… i’m building a new layout because I’m switching over to DCC and am too “electrically challenged” to make the old one work RELIABLY without the fits, stops and hesitations. I prefer using Peco turnouts. So my question is…do I want Electrofrog or Insulfrog for my DCC locomotives? Thanks in advance for your shared wisdom…
If you have smaller, or older, locomotives with trucks specializing in one rail pickup, you might have stalling on insulfrog turnouts because their frogs are inert and made of black plastic…at least I think it’s plastic. With really tiny locomotives, the frogs on a #6 and higher could be problematic if they are not energized.
If you are running locomotives made since about 2000 or so (?), they tend to have better pickup design so that, if one truck or item is on the dead frog, the other truck will get power to the motor/decoder. For steamers, the tender gets all rail pickup between the various axles even if the locomotive’s pickups are stranded in dead territory on the frog.
That said, I have a small SW-8 diesel switcher and a Life-Like Proto 2000 0-6-0 switcheer that do well on my dead frog hand-made #8 turnouts, and have no trouble with my Peco Insulfrog #6’s.
If you have older stuff, or smaller stuff with a short pickup base, you might prefer the electrofrog, but you’ll have to provide switchable power to the frog in some cases.
If you use Electrofrogs and make the suggested mods shown on the package, or at Wiring for DCC, you will have a turnout that has no dead spots, or potential dead spots. You will need to provide power to the frog though, either through switch machine contacts, or with something like the Frog Juicers from Tam Valley. You can sort of cheat and use just the Frog Juicer without modifying the turnout but if you are using switch machines that have contacts like the Tortoise, modifying the turnouts will be far less expensive than adding a lot of frog juicers.
The current Code 83 Peco turnouts have gaps cut in the plastic ties underneath where you need to cut the factory jumpers and install new ones, so it’s not terribly difficult.
The modelers I know that use DCC swear by Peco Insulated Frog turnouts and set them up for non-power-routing, so all rails (except the from) are live all the time.
As mentioned before, if you use modern locomotive models, the dead frog should not cause problems.
-Kevin
Electrofrog PECO have a metal frog and can be set up for DCC friendly use.
I am planning on switching from the old Atlas code 100 #6 I used in my last staging yard pictured below, to a new larger staging yard using PECO electrofrog turnouts - in planning stages presently.
selector and riogrande5761:
Are you sure the Peco Insulfrog turnouts have plastic frogs? Based on what the Peco website shows, the frog rails appear to be metal on the Insulfrog turnouts. In some cases they are showing an Electrofrog turnout when describing an Insulfrog, but they mention that in the picture.
https://www.peco-uk.com/prodtype.asp?strParents=3309,3322&CAT_ID=3327&numRecordPosition=1
To the OP:
My club was all set to go with Peco Code 83 Electrofrog turnouts on the new layout we are building but we ultimately decided to use Atlas Code 83 Customline switches instead. The reason was that the Peco switches (both Electrofrog and Insulfrog) use frogs that have sharper angles than the Atlas turnouts. The Pecos all use frogs with a 12 degree angle regardless of the frog number. An Atlas #8 uses a frog angle of 7.5 degrees, and IIRC a #6 Atlas has a frog angle of about 9.5 degrees. The larger the angle, the quicker the train changes direction and the less realistic it looks.
Note that the Atlas turnouts are longer than the Pecos so they take up more space (although the Atlas turnouts can be trimmed). The Atlas frogs can be powered if desired.
Dave
Dave, although you addressed this question to Crandell and Jim, I can tell you that the Peco Insulfrog turnouts have a plastic frog. There is no way to power the frog.
The two little pieces that form the wing rails of the frog are metal, they are just embedded in plastic with no power going to them. ANd the very pint of the frog in an Insulfrog is a plastic piece. Compared to other plastic frog turnouts, they’ve kept the plastic bits to a minimum size, but therein lies the issue, if you have a slightly wider than standard wheel it can easily bridge that narrow gap which will cause a short. Paint or nail polish solves the problem - temporarily. It has to be renewed periodically as it wears off.
A properly wired Electrofrog is absolutely bulletproof, there are zero dead spots and zero places for a slightly oversize wheel to cause a short. They end up wired as shown in the instructions for building your own all-rail turnout like Fast Tracks. Nothing dead, no adjacent pieces at opposite polarity.
Dave, yes, I am sure the insulfrog vs the electrofrog, the “point” of the frog does appear to be plastic. Others have replied confirming. Compare them and you will see.
I have Peco ElectroFrog on my DCC layout. All I do is isolate the diverging rails from the track that they are going to. No wire cutting, no frog wiring, no juicers, The switches are used as they came out of the box. My Shinohara code 100 switches from 20+ years ago are installed the same way. I didn’t change a thing when I went from DC to DCC.
I have 4 Shinohara code 100 double crossovers on my layout too. To use them with DCC, all I had to do is throw all 4 switches at the same time. Simple.
Why make it more complicated than it has to be.
Dave, your club is making a mistake here. What you are describing apply only to Peco code 100. Peco code 83 follow the North American way of designing turnouts.
So the Peco code 100 large turnouts are a bit sharper than the Atlas #6. But for staging, appearance is less important. But my question is, will all long wheel base trains, (89’ auto racks, 89’ flat cars, passenger cars and long engines) operate reliably and gracefully through the Peco code 100 large turnout?
Sounds like the Peco large may be somewhere between a standard #5 and standard #6?
I think we all get the difference between Peco code 100 and Peco code 83 (which are north American style and designed different than the old code 100)
Dave, I have been installing the various issues of Peco Insulfrog Streamline Code 83 turnouts for several years, three removed from packaging just within the past three months. I use the #6 frog.
The points, stock rails, closure rails (including frog guards), and points rails are metal. The frog, itself, is black plastic, including its bed to help support flanges passing from closure rail deviation to the frog point. There are metal strip jumpers under the turnout to link the closure rails, or the stock rails, to the points rails, thus making them truly power routing, but based on where the switch-points lie…against which rail.
-Crandell
Have you painted your track? If you installed the Electrofrog as you described, the ONLY source of power for the point rails on through the frog and the diverging rails up to the insulator is the point rail being pushed against the stock rail. It doesn’t take much dirt or dist gathering in that space to cause power pickup problems.
Thanks Crandell.
I was looking at the rails and not the tip of the frog.
Dave
Jack, I had a brain fart. You are correct. It is only the Peco Code 100 turnouts which have the 12 degree frog angles. Thanks for correcting that.
We started looking at Code 100 only and that is where the frog angle issue came up. Once we realized that we would rather have the smaller frog angles that opened the discussion up to include Code 83. We compared the Peco Code 83 turnouts with the Atlas Code 83 Customline turnouts. We decided to go with the Atlas Customlines simply because of price. Despite the fact that we had been offered some pretty decent discounts for both products, the Atlas turnouts worked out to be about $1000.00 Cdn. less expensive than the Pecos. That was more than 10% of the budget for the whole layout. The Pecos didn’t offer enough advantages to justify spending the extra money.
Dave
I have Peco code 100 Medium turnouts on my layout and my full length passenger cars have never had an issue running through them. Can’t comment on 89’ freight cars though. Still, if you go with the large turnouts, I can’t imagine you having an issue. My longest engines are E units and 2-8-2’s, so nothing massive.
I would say this is true for the mediums, or maybe mediums are closer to a #5 and large are #6?
Apparently the truth is a bit fuzzy on the Peco code 75 and 100 turnouts. According to a PDF document, small, medium and large Peco turnouts in the above code rail types are 12 degree’s.
http://www.pcrnmra.org/pcr/clinics/Kolm-TurnoutsWhatYouNeedtoKnow-PCR2008-handout.pdf
Yet it appears the small have a sharper curve radius, medium less sharp and large, the broadest of the three. So OTOH, the frog angle is actually sharper than a #5 according to the chart provided. But a Peco 100 large must have rough equivelent to one of the standard turnouts even when taking the sharper frog angle into account? Of so, what is the Peco large code 100 nearest too. Many have said #6 but that isn’t strictly true based on the data, but it must be “operationally” close to something.
The dimensions in the following table are for HO scale from NMRA RP 12.3. The lead length and closure radius were specifically determined for model railroad purposes and may not be directly scaled from prototype standard dimensions.
Turnout #, Lead, Frog Angle, Closure Radius
#4 5.06” 14° 15’ 15”
#5 5.69” 11° 25’ 26”
#6 6.25” 9° 32’ 43”
#7
Fuzzy indeed! Looking at the documentation on Peco’s website, and judging by the plans/photos there and what I know, I believe the 12° is only describing how far away from tangent the diverging route becomes at the end of the turnout and not the angle of the frog itself. This way it becomes easier to determine what crossings are needed in given situations and having all the turnouts end up 12° off tangent simplifies the number of crossings you need to offer to match potential geometries. Consider this, it is widely known that Peco turnout in code 100 continue their curve through the frog, unlike North American prototypes. Combine that with the different curve radii apparent in the different turnouts, and you cannot help but have different frog angles. Continue the curve long enough through the frog to hit 12° from tangent and call it finished. I’m sure that’s what the designers did. Also, just eyeballing the templates on Peco’s website, it appears the medium turnouts have a roughly 6” lead which would put them right between #5 and #6 on the chart you provided. The larges appear to have a roughly 7-1/8” lead, putting them between a #6 and #7. If you look too at the templates, the rails continue past the frog further on the large, than on the medium, curving all the way I’m sure, yet still diverge the same 12°. Tells me the frogs are indeed different, but Peco is not sharing what the true frog angle actually is. Again, this is my personal speculation, but I find it impossible to have three
