Weight is not the shipping cost, it’s the size. Also, it needs protection from handling in transit, set something heavy on it, when it is not on a flat surface and it could easily snap. Even a large enough quantity to have some strength would be subject to bump damage, as it is soft.
I love working with the stuff, nice thing is that less than three miles awayis a yard that brings in several tt loads a year. One bundle would do most modelers for a life time.
Never have counted, hard to tell when they are stacked up on the truck. I think they are 4’x4’x8’ which would be 12 sheets of 2". May be down that way tomorrow, will try to remember to check.
Buy a bundle and sell the excess to other modelers.
I used the blue foam (from Lowe’s) for the first phase of my layout about 15 years ago. WOW has it gotten expensive. I can’t remember exactly what I paid for it but I’m thinking it was around $25-30 and even that seemed expensive to me. No way I would have paid $50 then or now but if it’s what you want, I guess you have to pay the going price. I switched back to good old fashioned 3/4" plywood for the rest of the layout. Yes it’s cumbersome but I don’t figure on ever moving the layout so I don’t mind handling it one time.
Great… I try not to offend anybody. I’m a little cocky like my dad. Cocky is hard to decipher reading text. You can’t see the person’s facial expressions.
I actually went back and reviewed my posts here.
I gotta say there was a couple of gray areas, no pun intended. Chuckle chuckle.
I think you’ll really like working with pink foam if you can just get your hands on some.
The thing I like about pink foam is you can do so much with it.
This was a little experiment. I stabbed a random line accross the corner of 2 inch foam with a steak Knife about 8 10 times then just broke it and half, then I picked the tops with my fingernails on the perforations that were already there and this is what I got.
The process took about 30 40 seconds. It’s not the effect I want for rocks on my layout but I think it simulates the stone formations in the western states.
Even though I I have no use for it I think I’m going to color wash and dry brush it. I’m curious to see what it will look like.
I gussed right. Checked with the yardman at the local lumber yard. All the foam comes in 4’x4’x8’ blocks, wrapped in plastic, 48 pieces of 1", 24 of 2", 18 of 3" and so on. The 2’ wide sheets still come in the same size blocks.
True. But in many areas of California and other relatively mild-winter states, a layout built from plywood will be cheaper than the equivalent one built from extruded foam – just because the foam is harder to find and generally more expensive here than in other places.
Extruded foam is fine, plywood is fine, gatorboard is fine, etc… But availability and price factor in.
I go around to the construction sites to get mine. They usually give it to you to save room in the dumpsters, I have enough to do 2 layouts. Last haul was 3 truck loads for free and I use both blue and pink. Just make sure if it has the thinplastic layer pull it off glue wont stick to it, it has the little squares on it…
I use joint compound to cover the foam after I shape it. I put the compound in a coffee can and add water to mix it into a thin paste that I can brush it on. You can add your ground color to it as you mix it just in case it gets chipped the white don’t show thru.
