I live in So. California and went to the Homedepot to buy the owens corning 4’ x 8’ x 2" ridgid foam board. They no longer stock it. Just the styrofoam type. I called around and found an 84 Lumber that can get it for $50 a sheet.
I saw some blue ridgid foam board on the internet. Has anybody used the the blue stuff?
I wanted to ask those who used foam on their layout, what type of foam and how much the cost?
Maryland Home Depot foam, I would call purple, branded Fomular 2" x 2’ x 8’ is $29, Lowe’s is called Kingspan, is blue green and the same price so $50 for a 4 x 8 isn’t a bad price.
You might check plastic distributors, big warehouse facilities in industrial parks, the kind of place where you might also buy a 4 x 8 sheet of styrene.
The pink is an Owens Corning product. On line Home Depot shows it as being carried in the Sacramento area stores. Entering a Los Anges zip code in their search yields no results.
I used blue (not sure of brand) 20 years ago. It and the pink were considered equal by model railroaders at that time.
The blue you refer to is probably the Dow product, competitor to the Owens Corning.
Pink (Owens Corning), Blue (Dow) and Green (Kingspan) are competing XPS (extruded polystyrene) products. Probably all would work.
They are all the same. For whatever reason, I have seen some Owens Corning pink that looks more purple than pink - messed up batch ooof dye or what I don’t know. Maybe the stuff comes out blue and mixed with pink dye you get purple. Foamular is the trade mark of Owens Corning, so purple or pink, if it syas Foamular, it’s theirs. Dow is blue, and for a while my local Lowes carried the green stuff - that in 4x8 1" thick sheets, while they had the full range of pink but all in 2x8 sheets.
There are insulation contractors in the mid-Atlantic. I’m sure there must be some in the parts of California where it gets really hot, which would be closer to you than the high Sierras. Maybe they could sell you a couple pieces.
I’m not personally familiar with polyshield – note that the pink and blue foams are extruded, polyshield is expanded. Looking at the spec sheets for each, the pink extruded foam is significantly more rigid than polyshield. I have no idea how easy or difficult the polyshield is to cut or shape.
The Polyshield that the Original Poster is talking about is not extruded.
Homasote has no structural strength, so it’s not a substitute for extruded foam. And it may be just as hard to find in So Cal.
Plywood also works great for subroadbed (cut in cookie-cutter style) and is available everywhere. It worked great for model railroad layouts for the 50 years or so before extruded foam became widely available - and still does.
polyshield is### Expanded Polystyrene Foam Board Insulation. styrofoam.### The extruded foam board can handle more psi therefore holds more weight.### There is a youtube show “whats neat this week” Ken Patterson makes the pink stuff look easy…
I agree homosote is not a subsitute for extruded foam, its a different construction technique all together and more complicated then extruded foam stacked and sculpted.
I have gone full circle and will draw up plans using wood…and maybe some styrofoam…
I am in Florida (northern part) and the 2" foam is rather hard to get here.
But in my research it appears as though with proper glue someone can simply glue 2 sheets of 1" together and get the same result.
In my case where the studs are 24" apart in my shed I believe I would want the 2" stuff. In a house where the studs ar 16" apart. I think 1.5" would be fine.
I also saw the recommendation that a 1/8 thick masonite/plywood be glued to the bottom of the foam. I thought this to be a very good idea,…little extra stiffness, mounting surface for items underneath, and supposely helps with the nasty transmission of sound that comes with foam subroadbed.
I’m going to utilize foam on my upper deck level of my new layout.
BTW I looked over craigslist and found several folks selling off surplus foam insulations they had.
Oops I pissed you off somewhere. That was not my intent. You definitely have it spelled out though the pink stuff is better. I would have to agree with Ken Patterson it is very easy to work with.
If you Google Menards Owens Corning pink extruded foam insulation. This is where I have found it definitely the cheapest.
It can’t be that much to ship the stuff is so lightweight.
OP asked if anyone has used the blue foam. Yes! When I lived in Texas any foam was semi-hard to find and Homasote was IMPOSSIBLE to find. “Homa What?” and “Homa Who?” were the normal responses from big box stores and building supply places. Pretty much the same when asking for foam sheet products.
I finally called a plastics company in the yellow pages. He sold the Dow blue foam in lots of thicknesses in 4x8 sheets. I got some in 1, 2, 4, 6 and 8" thicknesses. It’s been quite some time so the price eludes me but it wasn’t as expensive as you would think. He also had a lot of scrap pieces and damaged sections he threw in as a bonus.
So don’t rely soley on Lowes, HD or whatever big box store you have locally.
The blue foam worked well for everything I used it for on my layout. It cut, carved and glued well. I glued it together with yellow glues like Titebond and Bordens…whatever I had available and some pieces are still stuck together after at least 10 years.
